Z06 front brake conversion on GXP
#121
ok actually im finishing everything up. finally found a rotor that seem to work gotta mock everything up and see. everything looks good on paper but well see. looking to put together some brake kits if you guys are interested.but as for now im almost done . its been a while and been busy with work but doin the best i can. il take lot of pics and show you the progress.
#124
Got a chance to work on the swap and il just let the pics speak for themselves still not installed was late and didnt have time to bleed the brakes and needed some washers which was to late to go buy. but almost there. il keep you guys posted. but was tryn to show you guys the mounting and how much grinding i had to do. wouldnt line up right and also had to make sure the pads would work and fit evenly .
#130
I think this still might be doable for us GXP folks.
Basically, do what DrunkieTheBear did but with a modification: 4 piston Brembo calipers with our stock ~13" rotors.
Hopefully, our OEM wheels will clear since it seems those 6 piston Z06 PBR calipers cleared.
DrunkieTheBear's thread (no machining, just washers and whatnot): http://www.grandprixforums.net/offic...kes-46217.html
