I'm interested in this setup and I'd like to know the pros and cons from going to these 21 deg heads over ported stockers.
__________________ selling my trany more info here.
Johnny's
'93 Z-28 M6
AI Custom Cam, 1.6rr, LPP, K&N, 4.10, UD pulley, svo 30, Walbro, MSD OTVC, PCM ForLess Tune, Free Mods
well it would help if a mod deleted all the sidetracked useless post about the lt4 hot cam
Johnny's
'93 Z-28 M6
Because the angles are rolled on the new TFS 21 heads, wouldn't that be similar to angle milling without changing the deck and intake surface angles? If this were the case would it be possible for you guys to hit the 600rwhp mark with what it takes to hit 560rwhp mark on the TFS 215s? In other words, could you guys work these heads to one up the 215s you have by 40-50hp across the board?
I see that these heads have 54cc chambers, but how much further could these be milled down safely to increase the compression ratio even higher? I plan on using these on a 385 E85 build and want some high compression.
Also, I know these are already 21*, but would there be any gain to say rolling them just one more degree to have 20* heads since they will be milled anyway, or would that make the header and intake fitment too much of an issue to be worth it?
__________________ 1995 TA M6 E85
Power mods: Lost oil pressure, haven't started since E85 13-14:1 385 coming next!
Suspension: Koni SA's 600/175lb GC, 35/21 sways, poly everything, C5 brakes.
Appearance: LS1 tails, CETA mod, Corsa clones, custom 10-spoke SS wheels.
323rwhp, 338rwtq On E85 with bolt-ons, 1.7RR, very mild ported heads, and 2 fouled plugs.
