04-01-2009, 01:33 PM
#1 On The Tree
Procharged 383 LT1 vs 382 LS with 200 Shot I know this video has been on streetfire for a while. But for those of you who havent seen this video check it out, its one of the best I've seen in quite a while. I would like to have seen a 3rd run though.
http://videos.streetfire.net/video/B...28s_187925.htm
__________________
95 Z-28 3.42s T-56,10 bolt. CPE Forged 383, SLP LM2, ATI Super Damper, LT Headers, Center Force DFX Clutch, 52 mm TB, Trick Flow 30lb Injectors, K&N FIPK, Trickflow 195cc Heads,1.6 RR, Manley Hardened Pushrods, C.C. 503, MadTuner PCM.
04-01-2009, 01:54 PM
#2 TECH Enthusiast
Badass cars. Would like to know the gearing on each. Also, I'm surprised at the head choice for the LT1.
__________________
1994 Z28 convertible - Gil Davis built 396ci LT1, T56, 9" build underway...
...UMI, Wolfe, Corbeau, LPP, Advanced Induction, etc...see you this summer...
DD: '00 BMW 540i M-sport 6-speed - 13.91 @ 100 MPH
04-01-2009, 03:56 PM
#3 TECH Resident
yeah its a sick vid. CALL911 is actually on here. has a thread about this and a few other vids.
__________________
Quote:
Originally Posted by
tee-boy maybe you should have stuck with the 10 bolt, put in a good stereo system, and cruised college campuses picking up on the babes.
04-01-2009, 04:14 PM
#4 On The Tree
I wish I could find that thread. The search function is messed up right now.
__________________
04-01-2009, 05:21 PM
#5 TECH Fanatic
yep thats call911's car. I have a similiar setup as him.
04-01-2009, 06:13 PM
#6 TECH Enthusiast
great races, both badass rides
__________________ 95 Formula
LE1 heads...Custom grind...SS4000..............
Tags 383 , flow , forged , le1 , ls , lt1 , lt4 , performance , procharged , procharger , specs , speed , trick , video , videos
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
