Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 07-20-2009, 02:14 AM   #1
GUGdaTHUG3's Avatar
Trader Rating: 4
Default DOES NOT START; new opti
NEED HELP. I have a 1995 m6 z28. its been sitting 4 almost a year..i replaced the timing cover gaskets & seals, water pump, opti distributor. spark plugs & wires. few pulleys. ac delco parts.
mobile 1 oil and filter.
put it all together and it would not start up. cranks but no start.
the only thing i can think of is distributor not properly installed. took it back apart to the distributor again. trying to get it running monday or tuesday..
can someone help me diagnose??
GUGdaTHUG3 is offline   Reply With Quote
Old 07-20-2009, 03:00 AM   #2
LT1
LT1's Avatar
Trader Rating: 0
Have you replaced the ICM? Has the PCM ever been tuned or replaced or messed with?
Whats the last thing you did before it wouldnt start?
How is the fuel pressure?
Have you checked spark to the plugs?
__________________
_______69 Firebird A3______________95 Z/28 M6_______________
LT1 is offline   Reply With Quote
Old 07-20-2009, 03:22 AM   #3
Moderator
BizZzatch350's Avatar
Trader Rating: 16
Send a message via AIM to BizZzatch350
Agreed, also was the car not running before it went down a for a year? Unfortunatley, the opti is not the root of all that is a non start.
BizZzatch350 is offline   Reply With Quote
Old 07-20-2009, 07:08 AM   #4
1996 Pontiac Firebird
Formula96's Avatar
Trader Rating: 0
if you figure it out let me know, i am in suck bowl of shit as well with my LT-1
__________________
2008 Silverado Crew Cab 4.8 (stock) slow
1996 Formula Convertable (not broke anymore 8-4-09) (( BROKE AGAIN 8-15-09)) DEAD slow
http://videos.streetfire.net/video/8...0101231dc5.htm
Formula96 is offline   Reply With Quote
Old 07-20-2009, 09:59 AM   #5
1997 Chevrolet Camaro
Trader Rating: 0
check for spark off of the plugs, and it very well could be your fuel pump. Pull your fuel lines(you will need a special tool for this get at any auto store) off and see if you have fuel dripping when you turn the key
30thAnvSS is offline   Reply With Quote
Old 07-20-2009, 12:10 PM   #6
ss.slp.ls1's Avatar
Trader Rating: 30
Send a message via AIM to ss.slp.ls1
If your car has been sitting for a year, I hope you used stabil or drained your tank and refilled it with fresh gas.
As stated check your fuel pressure and check for spark at both the coil, and the plugs.
__________________
I am kind of a big deal...people know me.
Dishing out reality checks, one person at a time...
ss.slp.ls1 is online now   Reply With Quote
Old 07-20-2009, 02:22 PM   #7
GUGdaTHUG3's Avatar
Trader Rating: 4
the z28 was running strong till the water pump went out and took this distributor out with it @ 148k..
the tank was 3/4 full.
took it apart put it together. took it apart. gna check spark, fuel..
Old 07-22-2009, 12:27 AM   #8
GUGdaTHUG3's Avatar
Trader Rating: 4
got her started. adjusted the dowel pin on the opti distributor. put it back together. she started up nicely..good oil pressure and fuel.
AFTER ONE YEAR lol.
Old 07-22-2009, 12:48 AM   #9
Trader Rating: 7
1. check spark at your plugs
2. check spark at your coil
3. check fuel pressure
4. make sure icm is good
5. make sure all your wires are hooked up properly
__________________
94 Z28- 355..new updates coming soon.....79 TRANS AM 10th ann- numbers matching 61,000, in restoration...79 formula...81 trans am still in the original paint, but soon getting updated...85 camaro Z28 its mean, enough said....
jarretthise is offline   Reply With Quote
Old 07-22-2009, 01:27 AM   #10
GUGdaTHUG3's Avatar
Trader Rating: 4
& make sure your opti is on properly..
Old 07-22-2009, 01:42 AM   #11
ss.slp.ls1's Avatar
Trader Rating: 30
Quote:
AFTER ONE YEAR lol.
Glad to hear it.
__________________
Old 07-22-2009, 11:23 AM   #12
Formula96's Avatar
Trader Rating: 0
thats what i am going to check tonight, it seems like the only thing to make sense at this point on my ride...
was it pushed in or what???
__________________
Tags
opti, start
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
