Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-17-2009, 06:46 PM   #1
Trader Rating: 0
Default TFS 21 degree heads and cam help
Hi
This is my first post. Bought a 96 SS Camaro M6 a couple of months back and would like to add a little more to it. I have been reading here and other forums and have an idea of what I might like to do. I am thinking of the TFS 21 degree heads and Kooks LT headers, but not sure on cam. I am looking at the CC503 224/230 .536/.544 112 LSA, AI 218/226 .540/.540 112 LSA, AI226/234 .569/.570 110 LSA with 1.6 RR's, and a local speed shop custom ground 224/230 .573/.533 112 LSA with 1.6/1.5 RR's. The car is driven as a non daily street car but would like to be able to drive 2 to 3 hour trips etc. Any input would be greatly appreciated.
Thanks
Brad
P.S.
I am thinking of the buying the new heads (running as sold now and porting later) V's porting stock heads for future 396 build for car.
brad3579 is offline   Reply With Quote
Old 09-17-2009, 06:55 PM   #2
pyro719's Avatar
Trader Rating: 1
I would go with the biger AI cam
__________________
94 Z28,CPT RACE 4l60E,Fuddle 3000, 146,000 miles, 3.42's, free mods,160 stat,LT4 hotcam kit, Homemade CAI , BR7EFs@0.035, stock injectors,Pacesetter LT"S,2.5" true duals , Nitrous Outlet plate kit 150 shot, walbro 255lph.tuned by me,Stock suspension, minor weight reduction 13.92@98mph/12.0@112 1.72 60ft 318RWHP/461RWHP @ 7800 DA
pyro719 is offline   Reply With Quote
Old 09-17-2009, 07:21 PM   #3
Trader Rating: 0
Pretty new to the car engine stuff. How streetable would the bigger AI cam be as far as driving on the highway at 60-65 at low rpm's say 1700.
Thanks
Brad
Old 09-17-2009, 07:40 PM   #4
pyro719's Avatar
Trader Rating: 1
Check out the AI group purchase thread! Its stickied at the top of the page. I would go that route If I had the money.
__________________
Old 09-17-2009, 07:57 PM   #5
Trader Rating: 0
I was thinking of getting the TFS 21's as I am planning on building a 396 down the road and thought I could have the TFS heads ported by AI at that time as they look like they flow as much now as the AI 190 GM heads and could get better later.
Old 09-17-2009, 08:53 PM   #6
pyro719's Avatar
Trader Rating: 1
True that! They should flow some impressive #'s when ported. I want to get in on the AI GP But wont have the funds unfortunately So I might be getting a set of trick flows as well and seeing how they with the hotcam and some 1.7 rockers
__________________
Old 09-17-2009, 09:27 PM   #7
Trader Rating: 0
I am looking at the stroker maybe 2 or 3 years down the road as I would like to put a few miles on the stock bottom, as it only has 17,000 miles right now.
Just trying to use as many parts as possible that can be re-used on the 396.
Thanks
Brad
Old 09-18-2009, 11:29 AM   #8
LS1Tech Sponsor
Advanced Induction's Avatar
Trader Rating: 0
Smile
Quote:
The stated flow #'s for the 21deg TFS head are not comparable to our flow #'s for any of our heads. Different type flow benches, different fixturing, etc.
On the same bench, fixturing, etc. our CNC'd 190cc GM head is well above the TFS part at the same port size. However, it is not fair to compare an as cast head to a higher end CNC'd head. The as cast head will have good ports and bad ports due to core shift, and the CNC'd head will typically always be consistent. Additionally, without qualifying the port style, size, etc. the flow numbers are useless and really shouldn't come into play when shopping for heads. If you will have them ported in the future, the 21deg head is pretty nice. If you will not be putting $ into porting the TFS casting in the future, then you'll likely make more power with something like our CNC'd GM castings. Good luck with your project!
__________________
Advanced Induction
CNC Ported Cylinder Heads | Private Label Development & Production | Valvetrain Systems
Advanced Induction is offline   Reply With Quote
Old 09-18-2009, 12:28 PM   #9
myltwon's Avatar
Trader Rating: 1
Send a message via AIM to myltwon Send a message via MSN to myltwon
whoops
__________________
1994 Trans Am GT A4 - 383, LE custom cam, HPS ported heads/intake, Formato tuned, etc.
myltwon is offline   Reply With Quote
Old 09-18-2009, 12:31 PM   #10
Trader Rating: 0
Do you know what the flow of the stock 21 degree is @ 185 is on your bench and what you can make it go to @ maybe 215.
I am going to end up with a 396, thinking about the new Dart block when it comes out.
Would the 21 degree as stock be an ok fit for the 350 CI (with the smaller runners than buying heads big enough for the 396 and running them on the 350) until then.
Just thinking about if I can get more flow from the 21 degree later it might be worth it.
Old 09-18-2009, 12:32 PM   #11
Trader Rating: 0
M6 tranny
Old 09-18-2009, 12:52 PM   #12
myltwon's Avatar
Trader Rating: 1
for some reason I thought it said impala ss...ignore my post lol
__________________
Old 09-18-2009, 01:14 PM   #13
Trader Rating: 0
Sorry
It did'nt say one way or another when you posted. I added Camaro and M6 after.
Thanks
Brad
Old 09-18-2009, 02:09 PM   #14
pyro719's Avatar
Trader Rating: 1
Here is the flow comparison From AI Before and after They CNC'd Them. Looks to me that there is not much gained from .500 and under but from .500 to .700 there are great gains. Most People will Be under .600 lift so The gains from .600 to .700 are irrelevant. http://www.ls1tech.com/forums/10707537-post34.html
__________________
Old 09-18-2009, 02:35 PM   #15
Trader Rating: 0
Would be nice if AI had the numbers there with the graph, but it looks like the the TFS numbers are really close to what they have advertised.
Is that AI CNC'ing leaving it at 185cc?
Thanks
Brad
Old 09-18-2009, 02:55 PM   #16
pyro719's Avatar
Trader Rating: 1
No! You can clearly see in the pics that the cnc port is bigger.
__________________
Old 09-18-2009, 07:09 PM   #17
Trader Rating: 0
The benefit of the 21* heads out of the box is that they give you better performance then most as cast heads without costing you compression. Out of the box they are outperformed by quality ported stockers - but if you then port them too, watch out!
__________________
>>>Lotsa LTX Goodies for sale cheap!!!<<<
93 Med Pat Red Z28: 11.72 NA Stock Shortblock, Soon to be one *NASTY* All motor, GTP Ported AFR 220 headed, LE cammed, 23* hydraulic roller 383...eventually >.<
07 ZX6R Ninja: Bottom 10's w/ only gearing+exhaust...
\/\/\/-Stock 10-bolt F T W-\/\/\/
Apparently from the Street Racing section everyone and their mothers Honda beats crotch rockets now lol.
Puck is offline   Reply With Quote
Old 09-18-2009, 08:42 PM   #18
TravisMcGill2000's Avatar
Trader Rating: 0
not trying to hijack you thread. Can these heads make 400rwhp as cast. On a stock short block, custom cam, ported intake, and all the supporting mods.
__________________
94 Ta A4 bolt-ons,stall,spray...8.08@85 1.69 60ft..7.34@92 1.54 60ft 125shot..272rwhp 328rwtq motor. 425rwhp 503rwtq on 125 shot
TravisMcGill2000 is offline   Reply With Quote
Old 09-19-2009, 11:06 AM   #19
pyro719's Avatar
Trader Rating: 1
Trick flow says they will make 500hp so I would imagine 400rwhp would be possible.
__________________
Old 09-19-2009, 01:24 PM   #20
Trader Rating: 0
Sorry Pyro
I must have had a brain fart.
My main question on the heads is would it be better to run these heads as stock on the 350 and then port them for the 396 instead of using GM ported heads.
My thought being that these may work very well with the stock 350 having the smaller ports, more velocity and good flow and then should be able to be ported better than the GM heads for the 396.
If I was to go with larger 200 cc GM ported heads right away would I not give up something when using them on the smaller cammed 350 because of less port velocity.
Thanks
Brad
Tags
21, heads, tfs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
