Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-07-2009, 01:56 AM   #1
BLK,97,T/A,M-6's Avatar
Trader Rating: 0
Default LE2 Heads and 226/230 Cam dyno results
Lots of people ask for this kinda stuff so, here you are. If you notice, there is some 'choppiness' at low to mid rpm's. This is cause the timing is a little off, it is also reflected in the air/fuel graph at the bottom. This is going to be rectified once the tuner shows up here. Vince @ Trifecta is awesome to work with. I will be returning to KDR speed center shortly after the tuner arives, as Dave assures me there is more left in the motor once the lower end of the rpm's is straitened out. He believes there is another 10 to 15 left in it. I am not really chasing #'s, or dyno racing, but it would be nuts to crank out over 400 ft lbs! Enjoy!
http://s931.photobucket.com/albums/a...dynosheet2.jpg
__________________
97 WS6 - LE2 Heads - LE Ported Intake - 226/230 @ .050 - Racetronics 37# - AS&M 58mm TB - Trickflow Pushrods - Proform 1.6 RR's - RAM suregrip HD - LS1 D/S - Pacesetter coated LT's - ORY - SLP LM1 - Pro 5.0 - Energy Suspension poly motor mounts
Last edited by BLK,97,T/A,M-6; 10-07-2009 at 01:59 AM.. Reason: Didnt get the link in there
BLK,97,T/A,M-6 is offline   Reply With Quote
Old 10-07-2009, 02:07 AM   #2
CamaroRacing12's Avatar
Trader Rating: 1
Send a message via AIM to CamaroRacing12
i like what i see! congrats! stock 350ci?
__________________
Tony "Mr. Camaro" Quadros
~ 95 z28 350ci LT1 ~
"Just another bolt on only LT1 that can kick ur LS1's a$$!"
Special thx: Frank Cahill, Noyzee Racing, Coastal Customs, Shon Herron, John P. (1slowformula)
NED - 12.42 @ 107mph 1.68 60ft
CamaroRacing12 is offline   Reply With Quote
Old 10-07-2009, 02:09 AM   #3
Trader Rating: 0
Yes sir.
__________________
Old 10-07-2009, 02:12 AM   #4
Trader Rating: 3
Not possible, your setup is all wrong. Lloyd can't make power.
Congrats. Glad to see yet ANOTHER strong running LE combo
__________________
-'94 Z-28 M6 AZSM Headers, Custom XFI Baby Cam, Borla
4:10's, Built T-56, MT ET Streets, UD Pulleys, LT4 KM, SLP Lid
TPIS FPR, Dynaspark, N20 Outlet Plate Kit
12.75 Best ET | 112.96 Best MPH | 1.91 Best 60' | 5800ft Elev
Quote:
Originally Posted by wrd1972
That head aint worth shit. Your valves are not even straight.
gregrob is online now   Reply With Quote
Old 10-07-2009, 02:19 AM   #5
Trader Rating: 0
I was really astounded by the 'plateau' of torque. And the strait flat climb of HP. Not to mention, it didnt just spike at 405, it leveled off there and held it till the fuel pump started to fall off at 6300.
__________________
Old 10-07-2009, 02:20 AM   #6
Trader Rating: 3
Certainly. It must be a handful to drive, but fun as hell
__________________
Old 10-07-2009, 08:30 AM   #7
Trader Rating: 6
Very nice
__________________
Black 96 Z28, M6, hardtop, LT1
Forged 350ci, Strange S60 w/4.30s, NA for now.
current best 1/4 mile et (run on my old 10-bolt w/4.10s).....11.88 @ 118 mph
Colin91Z is online now   Reply With Quote
Old 10-07-2009, 09:50 AM   #8
wrd1972's Avatar
Trader Rating: 9
They are good numbers, but to be fair and to fairly compare your results to others on the board, you should show the numbers with SAE correction. You can see on your chart that they are STD correction.
STD will yield 2-2.5% higher numbers than SAE depending on outdoor temps and humidity.
Again the numbers are still good and right where they should be. And near identical to mine too if I still had the 10 bolt rearend. My chart is in my sig.
__________________
1995 Z28 Convertible, M6 355ci LT1 built by Kennedy Performance. DYNO 384 RWHP/361 RWTQ SAE thru the 9" Truetrac
Performance Mods 6" rod Mahle pistons, LE2 heads w/ Patriot xtremes, 224/230 LE1 billet cam, LE ported intake, Midwest 9" w/4.11's, K&N CAI, BBK 58MM TB, LPP Long tube headers w/ cats, Pro mag 1.6 RR's, Tuned by BLUECAT.Pic top down. Pic top up. Pics of my True Dual exhaust.
wrd1972 is offline   Reply With Quote
Old 10-07-2009, 09:52 AM   #9
Trader Rating: 2
Excellent numbers man, it gives me great anticipation of what my setup should do, all forged 383 with LE3 heads, LE ported intake, Holley 58mm, 847 cam, Pro Mag 1.6rr & caddy racing lifters, ewp, Pacesetter LT's, 3" true duals, SLP lw flywheel & spec 3+ clutch and Racetronics 42# injectors with a MadZ mail order tune to start with thru a stage 2 rebuilt T56 and a S60 rear.
97Z28SS is offline   Reply With Quote
Old 10-07-2009, 10:11 AM   #10
dlk1950's Avatar
Trader Rating: 0
Very nice numbers...Congrats
__________________
1997 Z28 A4, LPE CAI,SLP SFCs,UMI LCAs,PHR,TQ arm,KYBs,3:73,Yank SS3600,BUILT A4, HOOKER LTs, CC305 & top build,SLP line-lock,MT DRs,DMH,PCMforless dyno tune,12.73 @ 106.9
dlk1950 is offline   Reply With Quote
Old 10-07-2009, 11:16 AM   #11
Trader Rating: 22
Awesome numbers man, I gotta go back to Vince Come spring time to get a few things tweaked.
__________________
94 Z28 Hardtop M6, LE2 H/C/I emissions cam, 391RWHP 369RWTQ.
airfix is offline   Reply With Quote
Old 10-07-2009, 11:37 AM   #12
AChotrod's Avatar
Trader Rating: 10
Congrats!!! Very nice!!!! I keep seeing more and more killer LE set ups!
My STD numbers were like that also, but my car had like 425hp. Do have the corrected numbers? Any plans on hitting the track??
__________________
LE2, Speedinc, Bedroom built 355, T56
LE2 H/C/I, Speedinc tuned, LPP, UMI, BMR, Dana S60, Street twin, blah blah blah.......
2nd place EX NA at LTXshootout
AChotrod is online now   Reply With Quote
Old 10-07-2009, 11:39 AM   #13
StealthFormula's Avatar
Trader Rating: 28
Very nice! I too have 390ft/lbs. of torque, alot of fun on the street
__________________
'97 Formula WS6
18k Orig. Miles - Stock Shortblock - LE2 Heads - LE1.3 Cam - Most Bolt-Ons - PT4000 - Some Suspension - 3500#
11.71 @ 115.36 w/ 1.56 60'
StealthFormula is offline   Reply With Quote
Old 10-07-2009, 12:59 PM   #14
Trader Rating: 0
I have no idea how to 'correct' the #'s.
__________________
Old 10-07-2009, 01:02 PM   #15
wrd1972's Avatar
Trader Rating: 9
Ask you tuner for the "run files". E-mail them to me and I will send you the images or I can host them.
__________________
Old 10-07-2009, 02:30 PM   #16
AChotrod's Avatar
Trader Rating: 10
the dyno shop should have given you them, not the std#s
__________________
Old 10-07-2009, 03:35 PM   #17
Trader Rating: 0
any body wonder how far off wud LE1s be with that same cam?? HP wise
LT1WS6 is offline   Reply With Quote
Old 10-07-2009, 03:49 PM   #18
wrd1972's Avatar
Trader Rating: 9
Quote:
10-12RWHP or so.
__________________
Old 10-07-2009, 05:43 PM   #19
robsquikz28's Avatar
Trader Rating: 76
very nice and once again another please LLoyd customer making damn good power!
robsquikz28 is offline   Reply With Quote
Old 10-07-2009, 05:56 PM   #20
AChotrod's Avatar
Trader Rating: 10
Love the new avatar pic Rob!!!!!
__________________
Tags
226, 230, 350ci, 355, cam, ci, dyno, hd, heads, le, le2, le3, lt1, performance, pulley, results
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
