That's correct. The LTCC system will not work with any MSD product other than their OptiSpark distributer, if you wish to use it.
Each LS style coil has all the needed electronics in them for dwell and charging.
The great thing about the LS coil system is that at higher speeds, one coil per cylinder has much more time available to charge vs. one coil firing eight cylinders.
__________________ -1999 Trans Am A4, 2.73 rear, ZR1 wheels 17 X 9 & 17 X 11, UMI front end EVERYTHING, SSBC 13" 4 piston stoppers, truck coil conversion. -71 Monte Carlo SS454 496 CID, 600HP |
