Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-01-2009, 10:54 PM   #1
Rick804's Avatar
Trader Rating: 0
Default Can somebody show me pics of all grounds on a Lt1?
I need locations of every ground wire on a 94/95 Lt1. I need to make sure I haven't accidently severed a ground with my swap. As some of you all may know I am having some crazy problems with my car at the moment. Refer to my $$100 Dollars if you can fix it post. TIA
__________________
94 Camaro Z28 M6. MSD Opti, OTVC spark plug wires, RAM Clutch, Hurst Short Throw, Full custom 3" exhaust with pacesetter longtubes, electric cutouts.Spohn adj. panhard bar, front and rear sway bars, strutt tower brace, spohn adjustable LCAs, Spohn tunnel mount TA. Have but not installed: 3.73 Richmond gears, Richmond mega rear end rebuild kit.
Rick804 is offline   Reply With Quote
Old 11-02-2009, 09:10 AM   #2
1995 Chevrolet Camaro
the_merv's Avatar
Trader Rating: 36
One of the Cables off of the Neg Terminal of the Battery goes to the Passengers side Motor Mount on one of the Bolts. On the Drivers side there is a Grounding Strap that goes from the Drivers side Frame Rail to the Block somewhere, I had it bolted to where the AIR Pump was. On the Drivers side Head there are Grounds bolted to that from the Engine Harness.
There are a couple of grounds bolted to the Front Core Support, one on each side.
__________________
1995 CAMARO "STRIPPER" HARDTOP Z28
CAR WEIGHT: appx. 3325lbs 408ci LQ4/L92 STROKER with 3" X-PIPE & TRUE DUALS
BUILT T56 6spd|TEXTRALIA OZ 700|B&M RIPPER|MOSER 9 INCH|EIBACH PRO KIT|SLP BILSTEIN SHOCKS
the_merv is offline   Reply With Quote
Old 11-02-2009, 09:40 AM   #3
RamAir95TA's Avatar
Trader Rating: 1
Send a message via AIM to RamAir95TA
If you have any doubts, install some aftermarket grounds yourself. That's what I did. You can see one of them on the driver side, just below the cylinder head:
__________________
-Joe-
95 T/A.
Advanced Induction 383 - 11.1 @ 122
Video clip.
RamAir95TA is online now   Reply With Quote
Old 11-02-2009, 09:42 AM   #4
myltwon's Avatar
Trader Rating: 1
Send a message via AIM to myltwon Send a message via MSN to myltwon
yeah I def need to add some grounds
__________________
1994 Trans Am GT A4 - 383, LE custom cam, HPS ported heads/intake, Formato tuned, etc.
myltwon is offline   Reply With Quote
Old 11-02-2009, 11:22 AM   #5
the_merv's Avatar
Trader Rating: 36
I use the 6ga Cable..them Grounding Straps arent that great.. yea they work but it's nice to have something heave on there from the Engine to the Frame.
__________________
Old 11-04-2009, 05:11 PM   #6
Rick804's Avatar
Trader Rating: 0
So how about this? I disconnected the grounds going to my coil/Icm studs and fired my car up and it runs just the same. I also disconnected the PCM ground and it runs the same. What gives here? I thought maybe one of my grounds was bad. Turns out the car likes running without them too. lol
__________________
Old 11-04-2009, 07:55 PM   #7
robsquikz28's Avatar
Trader Rating: 76
Where was the ground located for your pcm and what makes you think it was your pcm ground? Also if your talking about the ground cables that go to the icm thats for the engine harness and really shouldnt run at all.
robsquikz28 is offline   Reply With Quote
Tags
36, code, end, fix, lt1, plug, rear, wires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
