Upon heavy breaking and/or stopping, my oil pressure gauge drops to zero and check gauges light comes on. So I changed the oil and flashed some light in the pan... sure enough there is the pickup tube rolling around at the bottom.
What have you all found to be the easiest way to drop the oil pan?
Depending on what exhaust you have you might have to drop the y pipe. You have to take off the starter and oil cooler if you have one to get the pan off. It's easier to do on an auto car than a 6 speed car. It can be done w/o dropping the k member.
__________________ 95 LTx Z28 Quasar Blue
BMR Suspension, Strange Dana 60 w/ 4.56's, AI TFS 215cc CNC Heads, AI SR Cam, QA1 Coil Overs, 385c.i. Callies Magnum, Oliver Billets, SRP Pro Series 13.9:1, Ported Intake, Pro Built Auto's 4l60e MVB Pro Street Trans 4000 Vigilante, Self Tuned FAST XFI #3515---10.70 @128.4 Spinning 1.56 60'
06 GTO M6
CAI, Stainless Works Headers, Self Tuned w/EFI Live, B&M Shifter, BMR DB's, Bassani CB 13.13@109.3 on 235/40ZR18 Bridgestones 2.20 60'
You're lucky. When that happened to mine, it spun the #4 rod bearing. Luckily for me, I was still under warranty and got a replacement long block...4 bolt mains for me
I don't know why they never welded the pickup on. Mine wasn't the only one in at the dealership also, a 95 TA came in with the same problem. This was back in '00.
How does the car still get oil pressure with no pickup? Other than during heavy braking, pressure is normal.
could be enough oil in the pan to reach the pick up hole in the pump but when you jack on the brakes it all sloshes forward and you suck air instead of oil.
06 GTO M6
