Location: windsor, ont. canada - Home of the fastest LT1 6spd.
jeremy i dropped you a PM
__________________ 1996 SS 399 ci LT1 Harshaw Race Engine, Full BMR suspension. Best 60' 1.27/MPH 155.66 Quickest & Fastest TRUE T56 F body
First LT1 6spd f-Body in the 8's & 9's. N2O:8.97@ 155.23,1.34 60'/3600lbs.
Thanks to: Liberty's Gears, BMR Fabrication, Bryan Harshaw - HRE, McLeod Ind., FAST, Madman, Applied Nitrous Technology, and Eric Bradby ~ EB Porting.
I'm hoping dual intank pumps will do it for my turbo car. Is something like the MSD voltage booster necessary or is something like the Racetronix hot wire kit adequate?
what are yall doing about one of them failing? i keep hearing people mention that what if one fails but i dont hear and responses
__________________ LATE MODEL PERFORMANCE
94 Artic White A4 Z...The Toy | 95 Polo Green 6 Speed/99 NBM S10...The Daily's | 1994 Polo Green Z, cam only toy
Sold...1998 Black Z, 1999 NBM Z, 1999 Red Z, 2000 NMB Z, 1994 Black Z, 1996 Polo Green Formula, 1996 Artic White Formy, 1999 White S10
My advice. If you are spending the money to make 800 rwhp do not slack on your fuel system. Spend the money on good stuff such as an Aeromotive A1000 pump and regulator, -10 feed line, -6 return, sumped tank, fuel cooler.....etc.
i wanna go big and sump it...but its not for a f-body, and i dont want that aftermarket stuff sticking out like BAM LOOKEY HERE IM SUMPED
To address Walbro failures, I have been building double pumpers for Racetronix for over 3 years without a pump failure.
As for power capability, I have replaced A1000 pumps, that could not feed the motor, with my Double pumper kits. These have supported well over 900rwhp without any type of volt boosters. The A1000 is usually good for about 800 flywheel hp when it comes to forced induction EFI applications at elevated fuel pressures.
Sumped tanks definitely have their place, but for most applications that are street driven, the dual intank setup is queter, does not require a pump controller on the street & will likely feed most cars well into the 8sec range.
Since Jeremy already has the pump system, there is no reason to change it. Add lines, rails & regulator & it should meet all of his needs.
I have a Ricks stainless tank in my second gen running two gs340 walbro pumps ,the second pump comes on only when fuel pressure drops, done with hobes pressure switch, running two 6an lines to a y block than a 8an line with 6 an return, my ls-7 has 711 flywheel hp works great
