What all is needed to put 98+ Brakes on a 97 or below?
I know I found a how to thread and now I can not find it anymore. A friend has a set of front calipers and brackets he says and it has my interest.
I would like to get better braking since I am playing around from time to time. So if anyone has kept the link around or just wants to tell me that would really be nice.
Ok after some feedback everything for the rear to include e-brake setup woudl be nice to know too... what all do I need? (And if anyone has some good stock ls calipers they want to let go of for the front that is now all I am missing...)
You can re-use your lines, but you might end up replacing your ball joints. When I did my conversion I ripped my ball joints. They were only like 10 bucks at auto-zone. Your going to need a front end alignment also.
Make sure when you get the calipers and brackets that you get the metal clips that hold the brake pads on. There are 2 for each bracket and one for each caliper.
1oo% correct and you will love the results from the swap...
i NEVER had a problem with the Lt1 brakes,they worked nicely!
the main reason for me doing the swap was due to me warping the rotors front and rear was gonna cost 350.00 to replace the original Lt1 parts so i did some searching and found the rear Ls1 brake set up for 75.00(52k)and the front spindles,calipers,brake lines etc.with only (21k)for 85.00 latsly i purchased 2 bottles of castrol syntec synthetic brake fluid 16.00 so i save a butt load of cash on this deal!
Is there really any difference with the rear ls1 and lt1 brakes?
The backing plates put the calipers on the opposite side. E-brake cables are different. From all the reading I've done there is no performance increase so upgrading is pointless.
Thats it .You will love the LS1 brakes.
__________________ Ben
2002 Z06 bolt-ons (for sale)
1994 B4C Camaro -forged 355(9.4 comp ratio),232/236 568/581 114 cam, accel gen 7,ported trickflows,true 3'' duals into cme, and a D1R ...much more.
Yes there is! 1" more contact surface on the Ls1 rears as well as the front...
it is a matter of opinion,similar to some people that cannot tell the difference between a clear stereo at a high volume and those that cannot hear/understand what distortion sounds like!
Good luck!
I have most of this stuff for the swap, but think I lost these metal clips, can you get them locally anywhere? Also I believe I have the brackets, but they have no spindals installed in them. Can I just swap out spindals from my 97? (the circular part thats pressed in correct?)
__________________ Motor blown! Snapped rod.
(LE3/4 Forged 383 in the works)
The spindle is the whole arm like unit that holds the caliper, rotor, and wheel bearing. There are 2 ball joints that attach to it, one at the top and one on the bottom. The spindle is considerably large.
I disagree with that.. The rear parking brake on my LT1 worked for crap! It wouldn't keep the car from rolling no matter what I did New calipers, adjustment, Pads & rotors NOTHING! So I switched to the LS1 rears because the were bigger and incorporated a "Mini Drum" System inside the rotor and since the swap I've had no issues with the parking brake and it works 100x's better then trying to put more clamping force on the rotor like the LT1 setup did.
Ok then what all is needed for the rear. The front rotors I traded for ended up being off a 98Z so I am now getting everything but I need a parts list for the rear. I am giving him the front one now.
Recommend getting the whole rear if possible. It will swap with no issue just make sure you get the parking brake cables & Brackets
Reason I say that is because it will be alot easier then trying to find every part needed to convert the rears.
Also guys keep in mind when swapping the braking performance is improved but if you plan to run drag wheels you will have to grind the calipers or run spacers to get the wheels to fit correctly as with the LT1 brakes you will not!
yes you would be good to go then...
side note:
i did my rears before the front and i noticed the car stopped a bit better,the e-brake works much better
especially on inclines!
when i did the front it totally completed the conversion.
I also have issues with the parking brake. I just recently did calipers, pads, and rotors in the rear with no luck either. Is it as easy as getting the calipers, pads, and backing plates for the rears? I know the axles have to come out but that is no biggie. Other than that I just need the rear cables correct?
Good luck!
Can I get these clips from the parts store?
