Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 01-08-2009, 11:53 AM   #21
drz
Trader Rating: 1
I'm not suggesting that the procedure should ever be skipped - all aftermarket bellhousings require the alignment checked, but the Mcleods seem to need physical realignment with acentric dowels often when others are more consistently within spec from the start with straight dowels.
I agree anyone with an alignment problem did not follow the instructions. But anyone who DOES skip the alignment procedure is more likely to have an alignment problem with a Mcleod than other brands. That's all I'm saying.
__________________
Derrick
drz is offline   Reply With Quote
Old 01-09-2009, 11:35 AM   #22
Trader Rating: 8
Nice set-up... Glad its all working out!
ABadMother1999 is offline   Reply With Quote
Old 07-21-2009, 02:34 PM   #23
Trader Rating: 0
Send a message via MSN to stevieturbo Send a message via Yahoo to stevieturbo
Quote:
Originally Posted by speedracer5532 View Post
Racing liter motorcycles from 50-150 is hard on that head set gear.
I'd use 4th gear for that
__________________
9.85 @ 144.75mph
190.7mph standing mile on a poorly 346 with YSi
181.9mph standing kilometre
http://www.youtube.com/watch?v=XgWRCDtiTQ0
stevieturbo is offline   Reply With Quote
Old 07-21-2009, 03:33 PM   #24
speedracer5532's Avatar
Trader Rating: 7
Send a message via AIM to speedracer5532 Send a message via MSN to speedracer5532
Quote:
4th gear won't go to 150 on a 26 inch tire and 3.70 rear gear.
__________________
John
2000 SS Camaro 6-speed
LSX 427 with F1A - 940 rwhp, 809 rwtq on 15 lbs
9.78 @ 150.52 with a M6 @ 3900 lbs race weight on 16.5 lbs.
speedracer5532 is offline   Reply With Quote
Old 07-21-2009, 03:40 PM   #25
1BADAIR's Avatar
Trader Rating: 1
sure it does. at 7200rpm
__________________
WWW.MOTOWNMUSCLE.COM
Mcleod master cylinders=FAIL
1BADAIR is offline   Reply With Quote
Old 07-21-2009, 04:10 PM   #26
Trader Rating: 0
Mine does on 255/40x17's with 3.27 though
__________________
9.85 @ 144.75mph
Old 07-21-2009, 04:41 PM   #27
Trader Rating: 7
Quote:
I am not going to spin my engine that high.
__________________
John
Old 07-25-2009, 03:42 AM   #28
ms4z28's Avatar
Trader Rating: 0
I think it all looks pretty cool great job!
__________________
00 red Z28-MS4, PRC stage 2.5, ls6, forged pistons and rods, slp long tubes, ORX, slp lid and flo-pack
- stock tranny, spec stage 3
- stock rear 3.42
12.0@120, 2.0 60' first time out I was afraid of breaking the rear ?rwhp
ms4z28 is offline   Reply With Quote
Old 07-25-2009, 09:52 AM   #29
hotrodscrap's Avatar
Trader Rating: 8
Cool, do you have a picture of a cutaway for the t-56, just to see where the best spot would be to place the inlet fitting for best lubrication? Did you have a way to see what the temps where before/after? Thanks.
-SS
__________________
1925 Ford roadster p/u build in work/1985 Chevy S10 race truck, back halfed w/ 9", LSx swap in work, | 1993 S10 Daily driver | 1994 9C1 (Cloned) Impala SS, 6-speed, bolt on's | 1995 T/A vert. project | 2005 Cummins 3500, hauler
hotrodscrap is offline   Reply With Quote
Old 07-25-2009, 03:44 PM   #30
Trader Rating: 7
Quote:
-SS
No I don't. I just kinda eye balled it and drilled a hole in the side of the case where I thought would be best. Then tapped the hole for a bulkhead fitting and then ran a tube through the fitting and bent it to the angle I needed to spray on the gear where I wanted it to spray. No I don't have any temps before or after. All I cared about was that the gear was always lubricated.
__________________
John
Old 07-25-2009, 03:56 PM   #31
Trader Rating: 8
Alright, I'll just need to examine carefully, thanks!
-SS
__________________
Old 07-26-2009, 05:28 PM   #32
mlr
Trader Rating: 0
I like the pump set up seen it on allot of stock cars too
mlr is offline   Reply With Quote
Old 10-20-2009, 08:14 PM   #33
Trader Rating: 1
What pump are you using, and where can you get them?
lsx3rdgen is offline   Reply With Quote
Old 10-20-2009, 11:00 PM   #34
Trader Rating: 7
Quote:
Search "RB Racing Electric Spur Gear Oil Feed and Scavenge Pumps" and it will bring up the site for them.
__________________
John
Old 10-21-2009, 01:30 AM   #35
1BADAIR's Avatar
Trader Rating: 1
http://www.rbracing-rsr.com/oilsystems.htm
Tags
6speed, faceplated, fluid, gear, high, hp, input, liberty, lt1, overfilling, rating, shaft, t56, transmissions, tremec
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
