I removed 8 bellhousing to engine bolts. Triple checked and could not find any more bolts. It seems to be stuck on the dowel pins. Has anyone else had this problem before ? This is on a M6.
That can't be right. If you lift on the tail of the transmission it should flex. If not there is either another bolt in the very top that is a SOB to get to, or you will need to just play with it alittle to break it free.
__________________ 1999 WS6 M6 Lid, SLP 85MM MAF, Fast 90/90, Kooks longtubes (race headers), Kooks Y-pipe, Flowmaster Catback, Centerforce clutch and Fidanza flywheel, Pro 5.0 and Lou's short stick.
first time pulling it apart? you'll get that
I always use a pry bar, or even a flat blade screw driver and gently work it on both sides to push it away, and then slowly work it back, both sides just a bit at a time
the dowl pins are on the bellhousing into the trans, you sure you unbolted the trans or the bellhousing?
incase you do this again, sand down the dowl pins before putting everything back together.
__________________ 1987 Chevy Iroc-Z28 - clean and original
2002 Pontiac WS6 - "stock"
2007 C6 Z51 - ECS Car - 730rwhp
2008 HHR SS - 320hp 33mpg DD
Also if this is your first time you will need to be extremely careful with the slave cylinder! Don't just try ripping the tranny down. Unbolt the slave cylinder then lower it. I believe it is only two bolts that are either 8mm or 10mm. Also do yourself a favor and buy a miti-vac to bleed the hydraulic system when you are done.
This is the first time coming apart. Is it normal to pull the trans without the bellhousing ? I've always pulled as an assembly. Thanks for the replies.
You can pull it without the Bell Housing..that's how I do it. You may have to get a small Pry Bar and break it loose.
Quote:
That's for the LT1 T56.. you won't be able to get to the Slave with the LS T56.
Yup, mine was a major PITA. Pull the tranny off the bell housing first, makes manuvering things a bit easier. Your bell housing is stuck because you probably have some corrosion built up on the bellhousing dowles. Mine were horrible, make sure you have all the bolts out and try to pry it off everywhere you can a little at a time. My passenger side was really stuck, dont pry all in one area at a time or you might crack the housing. good luck
__________________ Why does the quarter mile no longer interest me?? oh yeah... Milemarker1.com, car #2002 clocked at 157mph
Thanks for all the replies. Finally got it apart. Sanded the dowel pin holes alittle. Maqde it awole lot easier putting back in. Now the problem is the slave is not disengaging fully. I've bled a big bolttle of brake fluid through it and still can't shift into gear with the engine running. I can get a good feel on the peddle, but as soon as engine is running, loose peddle. Going to try and bleed some more.
