Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-18-2009, 05:29 AM   #1
1963 Maybach 62S
grobb284's Avatar
Trader Rating: 7
Default Is a C5 clutch master compatible to Camaro LS1 slave?
I'm attempting to mount a set of Corvette C5 clutch and brake pedals in my Avanti. I'm using a 2002 Firebird WS6 motor and transmission (T-56). It is my understanding that the C5 clutch master cylinder and and the F-body slave cylinder are both 3/4 inch bore, is that correct?
Are their any compatibility problems between these two items? Also, can I make or purchase a braided line that connects to both the Corvette clutch master and the F-body slave? I'm not sure if the C5 master cylinder has the same connectors as the F-body master cylinder. Can you specify a length?
Are all C5 clutch master cylinders the same? I see some offered for 1997-2004, and others 1997-2000?
Thanks for the help.
__________________
Additional Studebaker photos available in "my garage".
grobb284 is offline   Reply With Quote
Old 10-19-2009, 12:08 PM   #2
LS123's Avatar
Trader Rating: 5
The slave cylinder on the C5 and the F-body are the same. The only difference is the C5 slave has a longer lead in line (steel braided line). When I was doing a C5 engine swap (upgrading the clutch/slave at the same time) for a friend, the slave he bought was a F-body unit. I just swapped line going into the slave and worked perfectly.
Don't have a clue on the line length.
__________________
99 C5 FRC M12 3.42
99 C5 Vert A4 3.42
08 HHR SS
LS123 is online now   Reply With Quote
Tags
2000, 2002, 2004, bore, braided, camaro, clutch, cylinder, cylinders, line, ls1, master, size, slave, steel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
