If you didn't disconnect the hydraulics you shouldn't need to bleed. In fact most of the time even if you do pop the quick disconnect, air wont make it into the system (that's why they use the disconnect). Either way, doesn't change things much. Pop the disconnect. Check for a hard pedal with it disconnected. If you can move the pedal your master cylinder has air in it and needs to be bled.
My bleeding technique which works everytime is....
1.) Connect master and slave
2.) Do the normal bleeding procedure. Depress pedal, open bleeder on slave, close bleeder, release pedal. I do this about 5 or 6 times until I don't get any air out of the slave. This is mainly to fill the slave with fluid.
3.) Remove the master with the reservoir connected and full. Move the master in several different positions and wiggle/tap on the sides until you see no air bubbles escape into the reservoir. Check the linkage to make sure you can't depress it.
4.) Reinstall the master with the reservoir connected. Connect the master to the slave and you should be good.
I suppose you could use the mity vac on #3. I've just heard mixed reviews, and don't own one. |
