Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
Old 09-14-2006, 10:14 PM   #1
Trader Rating: 6
Send a message via AIM to kyles2000z
Default gears are gettin hard to get into......
i drove my car all weekend last weekend, it drove perfect like always, but i noticed that the trans tunnel was puttin off a little heat, i could feel it gettin real warm around my legs when i was driving. parked the car sunday night. got the car back out yesterday to drive it to the strip. when im backing outta the garage i notice how low the release point is on the clutch, it was about an inch off the floor. usually the release point is about halfway through the pedal.
i drive it around for a little and the gears start gettin hard to get into, the longer i drive it, the harder each gear is to get in. it does it with all gears 1-6 and reverse. but now the car isnt puttin off the ehat from the trans area like it ws sunday. when the car isnt running, itll go through the gears like butter, no problem at all. the resevoir is full of fluid too.
FYI the car has a spec stage 2 with the zo6 slave and master cylinders (all replaced last november, which was about 10,000 miles ago). i hardly ever drive the car like i stole it either, so whats wrong here?
__________________
Upstate F-Body of SC
Comp 232 cam, LTs, true duals, 4.10, HP TUNERS. 377 rwhp
kyles2000z is offline   Reply With Quote
Old 09-15-2006, 02:04 AM   #2
CamTom12's Avatar
Trader Rating: 1
Send a message via AIM to CamTom12
Similar problem on a friend's car, turns out his pressure plate bolts backed out of the flywheel...
Don't drive it until you fix it!
__________________
--Cameron
2002 WS.6 M6 - Christine
H/C
"F***ing Titties"
MTFBA LS1 Mafia
Motorcycle for sale!
CamTom12 is offline   Reply With Quote
Old 09-15-2006, 08:38 AM   #3
Trader Rating: 6
but i have to drive it somewhere TO get it fixed
__________________
Old 09-15-2006, 09:08 AM   #4
Trader Rating: 0
Send a message via AIM to quiksilver9531
I'm having a similar problem with my car, I replaced the clutch with a ram powergrip, also replaced the throwout, pilot, and slave cylinder. Was perfect for a few months now recently the pedal isn't returning all the way up and its engaging like an inch from the bottom. I think I just have to bleed it, hopefully. But when the pedal doesnt return to the top I can just lift it up with my foot, and the clutch disengages at the normal point again till the pedal does it again. Check to see if you can lift the pedal up when thats happening.
__________________
2000 Trans Am WS6
quiksilver9531 is offline   Reply With Quote
Old 09-15-2006, 11:29 AM   #5
CamTom12's Avatar
Trader Rating: 1
no you don't... just trust me it'd be cheaper in the long run not to
AAA tow
__________________
--Cameron
H/C
"F***ing Titties"
MTFBA LS1 Mafia
Old 09-15-2006, 12:12 PM   #6
Trader Rating: 6
the clutch pedal isnt what im worried about.....the gears are gettin reaaaal hard to shift into. it isnt a fluid issue i dont think...when the engine is off, the gears shift fine.
__________________
Old 09-17-2006, 04:09 PM   #7
Trader Rating: 6
now 3rd and 4th gear are grindin pretty bad. would this be the master cylinder?
__________________
Old 09-17-2006, 10:02 PM   #8
CamTom12's Avatar
Trader Rating: 1
Check your pressure plate bolts and quit driving the car!
__________________
--Cameron
H/C
"F***ing Titties"
MTFBA LS1 Mafia
Old 09-17-2006, 10:11 PM   #9
Trader Rating: 6
if the bolts were backin out that would result in a slipping clutch wouldnt it?
__________________
Old 09-18-2006, 09:59 AM   #10
Trader Rating: 0
Quote:
I think you should listen to him! He sounds like he knows what he is talking about!
__________________
2002 Hardtop NBM SS
Hooker LT's/B&B Catback/QTP cutout/Air lid/Moser 12-bolt with 4:11s/Textraila 0Z700/BMR Non-adjustable trans relocated TA/ BMR adjustable control arms/ Spohn adjustable panhard/sub frames/Strange Chromoly D.S./B&M ripper
1/8th mile time:7.89@89
1/4 mile:12.28@112.42 with 1.77 60' on 295/40/17" Mickey Thompson drag radials/4000 RPM launch
Full weight including spare and jack
TeEnAgE pHeNoM is offline   Reply With Quote
Old 09-18-2006, 11:25 AM   #11
CamTom12's Avatar
Trader Rating: 1
results in a non-disengaging clutch.
__________________
--Cameron
H/C
"F***ing Titties"
MTFBA LS1 Mafia
Old 09-18-2006, 02:05 PM   #12
Trader Rating: 6
well the car's in the shop now.....gettin the master cylinder replaced and they're gonna give everything a once over.
__________________
Old 09-21-2006, 07:31 AM   #13
Trader Rating: 6
the master cylinder was reaplced, and the problems are still there, just not as severe as before. so the system got bled yestreday and today we'll see if its all fixed.
__________________
Old 09-21-2006, 01:16 PM   #14
2KThunder's Avatar
Trader Rating: 3
Send a message via AIM to 2KThunder
Im noticing a lot more noise in my tranny to, shifts getting harder, and im also getting some grinding in like 3rd and 4th. Let me know if you solve it. Ive got a new Slave, new clutch, and flywheel.
__________________
2000 Chevrolet Camaro SS
Cammed LS2 M6
423RWHP / 400RWTQ
2KThunder is offline   Reply With Quote
Old 09-22-2006, 01:12 AM   #15
Trader Rating: 6
Quote:
what kinda clutch and slave ya get? if its an aftermarket clutch like stage 2 or greater, you'll need an 02 slave cylinder.
__________________
Old 09-22-2006, 11:14 AM   #16
2KThunder's Avatar
Trader Rating: 3
Yeah i upgraded to the 02 slave, didnt swap master. Clutch is ls6
__________________
Cammed LS2 M6
423RWHP / 400RWTQ
Old 09-22-2006, 11:33 AM   #17
Trader Rating: 6
yea it isnt required to swap the master, mine was just goin out when i swapped the clutch so i changed it all.
__________________
Old 09-26-2006, 02:23 PM   #18
Trader Rating: 6
well they just dropped the transmission, and just like CamTom12 said, it was the bolts backing out of the pressure plate. when it was installed last year, no locktuite was put on the bolts for some reason?!? i didnt think thi was the problem bc the clutch wasnt clipping, i just wasnt driving the car hard enough to make the clutch slip. so, PROBLEM FIXED and im a happy man!
__________________
Old 09-26-2006, 03:24 PM   #19
CamTom12's Avatar
Trader Rating: 1
Glad you found the problem!
__________________
--Cameron
H/C
"F***ing Titties"
MTFBA LS1 Mafia
Old 09-26-2006, 10:24 PM   #20
Trader Rating: 6
yea when it ook it to the first trans shop, i asked them if that could possibly be the problem ad they laughed and acted like i was stupid and didnt know what im talkin about. im gonna call them tomorrow and tell them i coulda saved them 3 blled jobs if they would just listenneed to me!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Burkhart Chassis
Advanced Induction
Midwest Chassis
Xtreme Horsepower
SLP
Livernois Motorsports
World Products
Cunningham Motorsports
Nitrous Express
Specialized Stainless
Faster Proms
LM Performance
Speed Engineering
Painless Performance
Spohn Performance
Forced Inductions
Performance Auto Fabrication
Six Speeds Inc.
Rapid Motorsports
Afterthoughts Auto
Nasty Performance
Century Transmission
Late Model Racecraft
ByunSpeed
Texas Speed & Performance
Slowhalk
VFN Fiberglass
West Coast Cylinder Head
Air Flow Research
CarsDirect
Straightline Performance
Performance Oil Technology
Exotic Performance Plus
Edelbrock
Katech Engine Development
Fast Toys
Finish Line Performance
Futral Motorsports
Nitro Dave's Nitrous Outlet
Car Shop Inc
Harris Speedworks
Lonnies Performance
Dyno Tune
Competition Clutch
Trifecta Performance
LSx Tune
School of Automotive Machinists
Xtreme Powersports
MPH Motorsports
Strano Performance Parts
WS6 Store
Finish Line Transmissions
Total Engine Airflow
Tropi-Care
Race Proven Motorsports
G-Force Motorsports
Southern Car Parts
Shock Warehouse
Scoggin-Dickey Parts Center
Speed Tweekerz
Madman Racing
Comp Cams
Speed South
Quick Time Performance
Mast Motorsports
Diablo Sport
Discount Tire
APS Turbo
UMI Performance
TomZ Wheels
Kooks Custom Headers
Patriot Performance
American Racing headers
PerformaBuilt Transmissions
Horse Power Engineering
Nitrous Oxide Systems
Nano Nitrous
Full Throttle Speed
Redline Goods
Maryland Speed
Late Model Engines
Yank Torque Converters
Circle-D Converters
SJM Manufacturing
Wolfe Racecraft
CompStar Components
Race Engine Development
New Era Performance
Fuel Air Spark Technology
TT Performance
EFI Alchemy
Racetronix Fuel Systems
Speartech Fuel Injection Sys
LG Motorsports
Speed Inc.
Masport Speedshop
Vengeance Racing
HP Tuners
Kee Audio
Redline Motorsports
Tick Performance
Cartek Racing
BMR Suspension
Canadian Performance
Pavlock Performance
Auto Parts Firm Online
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
