11-14-2006, 10:58 AM
#1 | | 12 Second Club
| High RPM vibration I get a light vibration at rpms in excess of 4k, It has been doing this for about a year now so I'm starting to wonder if it is the tranny, wouldn't it of died by now?
I have a SPEC 3 clutch w/SPEC steel flywheel, which besides occasionally giving me fits on getting the car into a gear from neutral it works fine.
__________________ 96 M6 Trans Am |
11-16-2006, 10:13 AM
#2 | | 12 Second Club
| ttt
Also, I recently discovered it does it while revving the car in neutral as well.
11-17-2006, 11:39 AM
#3 | | 12 Second Club
| ttt
11-17-2006, 11:49 AM
#4 | | 12 Second Club
| What transmount are you running? Also crawl underneath and check out your torque arm mount for cracks. A failing pilot bearing could also cause this because the mainshaft of the trans spins inside that bearing. In my case the bearing was completley gone and I would get bad vibrations above 4k even with the stock clutch setup.
__________________ 1998 Z28 Ls1 M6 [SOLD] 12.51@114.6MPH - 370rwhp 373rwtq
1993 Z28 Lt1 M6 [383 w/ 12:1 Compression, ZERO TRACTION] |
11-17-2006, 12:00 PM
#5 | | 12 Second Club
| I have just a rubber trans mount. If it is the torque arm mount it will be fixed when I throw in the new torque arm and mount Sunday...but I don't see how it could be, because it vibrates in neutral with or with out the clutch engaged.
Thanks for the reply.
11-17-2006, 08:20 PM
#6 | | 12 Second Club
| Oh it does it in neutral as well. It could still be tranny mount although very unlikely in neutral. Being that it is a 96, motor mounts could also be and issue but I would never rule out the possibility of a blown pilot bearing.
11-17-2006, 09:11 PM
#7 | | 12 Second Club
| pretty new LT4 pilot bearing. I'll check the motor mounts though.
11-18-2006, 12:15 AM
#8 | | TECH Regular
| Take a close look at your crankshaft balancer for abnormalities. The steel flywheel a recent install? Maybe threw off the engines natural recipricating balance. I have accually purchased and installed an aftermarket flywheel that had a bad balance. |
11-18-2006, 12:28 AM
#9 | | 12 Second Club
| I plan to take a look at the balancer tomorrow, it's a cheapy autzone one.
11-19-2006, 12:35 AM
#10 | | 12 Second Club
| Any word on this?
11-20-2006, 12:40 PM
#11 | | 12 Second Club
| Not yet, we ran into some problems and didn't get the car back up and going yesterday.
11-27-2006, 10:37 AM
#12 | | 12 Second Club
| The balancer looks fine..
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
