02-15-2007, 02:25 PM
#1 | | Launching!
| Push clutch to start car question???? On a 2000 Firebird V6 5-speed is there a way to disable what ever devise that makes you have to push the clutch in to start the car?
I think the switch is going out, I had the same thing happen on my 92 F150 manual and my dad's friend rigged something to bypass that feature and it fixed the problem. Unfortunately that friend moved away ....lol
Any info would be appreciated!
Thnx David
__________________ 96 Z28 Hard Top N/A Who cares if a car is quick, if it doesn't look slick |
02-15-2007, 02:32 PM
#2 | | Teching In
| clutch safety switch, kinda like park/neutral saftey switches on auto's. ive read you can bypass it with just a paperclip before. search im sure your'll find it, ill look around for you too. |
02-15-2007, 02:45 PM
#3 | | TECH Resident
| the switch is on your clutch pedal. It's the black switch on the top I believe. The white one is for your cruise shut off. Just connect the two wires together. The switch isn't that expensive though and it's a good safety feature to have. I've accidentally gone to start the car a few times without the clutch in just not realizing and without that switch the car would have jumped into the other car in front of me. But it's up to you
__________________ Old Setup ~399 RWHP 376 ftlbs -Cam, Headers, Corsa cat-back, FAST manifold, MTI CF Lid, Tuned, and other goodies
New Setup ~? -LS6 347 Forged shortblock, 205cc DartPro1's, FAST 78, 37# FI's, F14 CAM, SLP ported oil pump, Rollmaster timing set, AR LT's, Corsa cat-back, LID, 11.? CR |
02-15-2007, 02:49 PM
#4 | | 12 Second Club
| time to use the parking brake alot more. lol jk i think i've accidentally popped the clutch with the parkign brake on once while the car was just idling and it does still; jump quite a bit. the only reason i would by pass this is so runa remote start lol but i don't drive the car in winter i would replace it. unless you trying to figure out if the switch is bad and that why you want to by pass it. just make shure to hook it up again. i could be wrong tho
__________________ 2001 Trans Am WS6, SLP Flow Pak Intake, SLP Lid, SLP MAF, Flowmaster 3" Cat Back, Pro 5.0 Shifter, Kooks 1- 3/4 LT's 3" OFY y-pipe, QA1's, Strano springs |
02-15-2007, 03:12 PM
#5 | | Launching!
| Thnx for the fast response guys! I will take a look and see what I can do. Keep the feed back coming!!!!
Thnx David
02-16-2007, 10:27 AM
#6 | | TECH Resident
| there should be a part number on the switch if you take it to a dealership, otherwise just tell them you need a clutch safety start switch. I think it was 20 bucks. well worth the insurance of not ramming another car when you try to start it.
02-16-2007, 12:55 PM
#7 | | BADA BING BADA BOOM!!!!!!
| Just go to the dealer and get a new neutral safety switch. Shouldn't be more than $30-$40
It's worth the money and it's nice to know that you won't run somebody over because you were to cheap to replace an inexpensive switch.
__________________ Owner, Detailer Richie's Custom Detailing An Authorized Adam's Polishes Dealer
06 Black SRT8 Charger 13.53 @ 103.83 2.03 60' Stock
376 RWHP 378 RWTQ |
02-16-2007, 03:23 PM
#8 | | Launching!
| Quote: |
Originally Posted by Richie Carbone Just go to the dealer and get a new neutral safety switch. Shouldn't be more than $30-$40
It's worth the money and it's nice to know that you won't run somebody over because you were to cheap to replace an inexpensive switch.  |
You're right, and while I am at it I might as well install a heads up display in the ol' fireturd so I won't run someone over the 1/2 second I am looking down at the speedo
Thnx for the feed back everyone, I think I can handle it from here...
Thnx David
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
