Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
Old 02-16-2007, 01:44 PM   #1
Infantrymarine's Avatar
Trader Rating: 0
Default shifter removal help
I need to add some fluid in and I can't seem to get the shifter off of the tranny itself. I removed the 4 bolts holding it(Pro 5.0) and it won't budge. I'm not forgetting something am I?
__________________
***SIG EDITED!!! 8 SINGLE-SPACED LINES OF TEXT --OR-- 500W x 150H PIC & 3 SINGLE-SPACED LINES OF TEXT IS THE MAX!!!***
>>>Signature Policy - Click Here<<<
VIP1 - LS1TECH.com Staff
Infantrymarine is offline   Reply With Quote
Old 02-16-2007, 04:46 PM   #2
Trader Rating: 8
there is a fill hole in the trans itself. jack the car up and it is the higher of the 2 pluggs. one for drain and one for fill.
__________________
2000 z28 M6: HEADERS AND MOTOR MOUNTS AWAY FROM FULL BOLT ONS!!!.
bigti99a is offline   Reply With Quote
Old 02-16-2007, 05:24 PM   #3
pro2low's Avatar
Trader Rating: 3
rtv sealant.....mine was a pain too. but there is a fill hole crack that open and fill it until it starts coming out
__________________
99 NBM Camaro SS Hardtop.....4XXrwhp (cam only)http://youtube.com/watch?v=s09l0UxlY-0
1964 Chevy II- LSX Swap in the future
HTTP://WWW.CHICAGOLSX.COM
Quote:
Originally Posted by Chase22 View Post
My friend thought it would be funny to throw a bouncy ball at my car when he was going 55mph and mine was going 15. I thought it would be funny to have sex with his sister.
pro2low is offline   Reply With Quote
Old 02-16-2007, 07:58 PM   #4
Trader Rating: 0
I tapped mine lightly from underneath the car and it broke loose, but it sounds like you're trying to do yours without going underneath. I don't know if I'd fill the transmission from the shifter hole since it may overfill. The fill plug is somewhat in the middle of the transmission and you're supposed to fill until it starts to dribble out of the hole. Filling from the shifter is the highest point and it may be difficult to determine where the proper level is located.
__________________
2000 Black Z28, Borla, SLP Lid, Pro 5.0, 17" Ronal Gottis, NGK TR55
MrEddie is offline   Reply With Quote
Old 02-16-2007, 11:53 PM   #5
Trader Rating: 0
Yeah I am trying to do it from inside the car. I know all about the fill hole but I was trying not to go underneath this time. I appreciate the input fellas. Love, Peace, and Chicken Grease!
__________________
Old 02-17-2007, 01:18 AM   #6
SSmokin 01's Avatar
Trader Rating: 14
It's just the silicone/sealant holding it on. Just take a box wrench, large screwdriver, or equivalent to pry the base off.
Use the edge of the trans tunnel as the fulcrum point and place the tip of your prying tool under the edge on the base of the shifter. You may need to place a block or handle of something at the fulcrum point to get the necessary height to pry. At the same time your prying, use your other hand to put pressure on the stick and base in the direction your prying.
It takes a good bit of effort, but it'll "pop" off.
Quote:
__________________
2001 SS #0758 RIP 12-23-01 (hit from side and flipped)
2002 SS Onyx,M6,D1-SC,TTS Longtubes,Borla,TT II's,315 Nitto DR's
Wife's car
2002 SS Pewter,A4,Direct-flo lid, AS S2 heads, TR224 112lsa,TTS Longtubes,
Borla,Vig 3200,TT II's,315 MT DR's
L.I.F.B.A #36
www.LIFBA.com
www.FastLS1.com
http://i103.photobucket.com/albums/m...lsupavatar.jpg
SSmokin 01 is offline   Reply With Quote
Old 02-17-2007, 10:20 AM   #7
Trader Rating: 3
It actually very easy to fill from the shifter port. The ONLY prob. is not dripping oil inside the car. Just dump in 4qts and you're golden. It will drain into the sump of the trans easily. As to getting the shifter off, the RTV can have quite a grip. With the 4 bolts off, do several high energy shifts( may want to put the handle back on for more leverage) and it should break loose.
calhoon is offline   Reply With Quote
Old 02-17-2007, 01:33 PM   #8
Trader Rating: 0
Well I did it inside w/o taking the shifter off. I took the fill plug out(so yes I had to get under it) ran about a 2 & 1/2 foot section of rubber hose down to the plug from the inside, and filled it that way. Took about 10 mins, no spillage either. But it was low, it took a quart and a half of royal purple. Glad I decided to check it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Lonnies Performance
Auto Parts Firm Online
Straightline Performance
Shock Warehouse
West Coast Cylinder Head
Redline Goods
Specialized Stainless
ByunSpeed
Mast Motorsports
Tick Performance
Spohn Performance
PerformaBuilt Transmissions
Trifecta Performance
Six Speeds Inc.
Wolfe Racecraft
Quick Time Performance
Diablo Sport
WS6 Store
Edelbrock
School of Automotive Machinists
Nasty Performance
Cartek Racing
Tropi-Care
VFN Fiberglass
Xtreme Powersports
LM Performance
Nitrous Express
Madman Racing
APS Turbo
Strano Performance Parts
Burkhart Chassis
Maryland Speed
Finish Line Transmissions
Race Engine Development
Canadian Performance
Car Shop Inc
MPH Motorsports
CarsDirect
Speartech Fuel Injection Sys
Harris Speedworks
Speed South
Afterthoughts Auto
Horse Power Engineering
G-Force Motorsports
Cunningham Motorsports
Forced Inductions
LSx Tune
LG Motorsports
Air Flow Research
Racetronix Fuel Systems
TT Performance
Exotic Performance Plus
American Racing headers
Scoggin-Dickey Parts Center
Vengeance Racing
Nitrous Oxide Systems
Slowhalk
Fuel Air Spark Technology
Speed Inc.
Xtreme Horsepower
Midwest Chassis
Comp Cams
Speed Engineering
Painless Performance
Dyno Tune
Fast Toys
TomZ Wheels
Total Engine Airflow
Pavlock Performance
Speed Tweekerz
Finish Line Performance
Century Transmission
Competition Clutch
Katech Engine Development
New Era Performance
World Products
Late Model Racecraft
Faster Proms
Futral Motorsports
Southern Car Parts
Rapid Motorsports
Kooks Custom Headers
Masport Speedshop
Circle-D Converters
CompStar Components
SJM Manufacturing
Yank Torque Converters
Performance Auto Fabrication
Livernois Motorsports
Advanced Induction
Redline Motorsports
Kee Audio
Performance Oil Technology
Patriot Performance
SLP
EFI Alchemy
BMR Suspension
Nitro Dave's Nitrous Outlet
Nano Nitrous
Texas Speed & Performance
Race Proven Motorsports
Late Model Engines
Full Throttle Speed
HP Tuners
UMI Performance
Discount Tire
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
