__________________ 1988 Mazda RX7 - Forged 347" LS1/T56 - Wiseco pistons, Callies Rods, Stage III heads, TC76 Turbo, Alkycontrol, Lingenfelter 2 Step, Custom C4 Dana36 rear, 2950 lbs.
Thanks to Bob and Drew @ EPP, Ryan @ Lingenfelter, BeasTT Performance and JPH!
2006 Crew: Team Spiderman/Hulk Top Fuel Motorcycle
10 Time World Champions, World Record Holders for 1/4 E/T: 5.746 Seconds
[quote=SS1875;11756282]Called and left you a message this morning....got home late last night and didn't have my phone with me. 11.64 @121 1.73 60 ft. was the best I could do. Hot, heavy air, greasy track and clutch issue. I'm just given JPH a hard time about it....better all around but doesn't pull hard on the big end like the GT1-1 did. Nitrous isn't wired and may never be....thinking of selling it and getting some better heads.
___________________________________
Even if you got a kick ass short time, like a 1.50 60 ft, you would only be in the 11.20 in the 1/4 mile at probably the same mph. Not bad, but that is assuming a dead hook on real tires (28 in tall I imagine). I wouldnt spend a dime more on that current engine, sell it and get a whole motor from a vendor, like a nasty 403 LS2 setup with 235 cc Trick Flow heads that will make 500+rwhp. Dont be scared of the nitrous!!! Spray the bitch and keep the current setup and just drive it!
DId you have rubbing issues with 28 in tires in the past? Did you grind your rear calipers to clear 15 in rims? What clutch would work out do you think??????
__________________ Used to streetrace when people streetraced...now I just go to the dog park. I sit around and watch dogs play instead of sitting around watching cars in a parking lot!
This setup is not for NA so I should be happy that it was even close to the old setup MPH/Time wise...but you know me. I think better heads on this combo would be a better choice than an entire new LS2 setup...this motor makes power but needs to breath a bit more and my LS6 heads are as far as they can go.
I'm only leery of the Nitrous because of the clutch issues with these cars....doesn't seem to matter what you do to fix it,new hydro's, master cylinders, clutch etc., they are never right and with my luck something would happen and I would spray through a shift and pop the motor. I want to see what it is capable of doing however I need to be cautious at the same time.
Yes had rubbing issues with the 28" tall tires but only after some heat cycles on them...would rub at the front and back of the tires outer wheel well area. I ran 16 inch wheels with ET Streets that I borrowed from Snapps Sunday. looking to getting some Billet Specialty or Bogarts but have to get working and generate some cash flow first.
__________________ 2000 Camaro SS Pewter M6 #1875 LPE 383 Stroker...466HP/460TQ
JPH/Crane Cam
Midwest Chassis Fab 9"
Best Time 11.49 @ 122.48 1.85 60Ft. (old setup)
Huh?...you lost me 1.5mph and almost 2 tenths and my 60 was better than when I ran my best time with the other setup I'm not doing a 3-4k tranny swap just to make you feel better pal
Clutch was/is the issue right now, the rest will work itself out
What are the cam specs of your old cam and new cam? I thought your new cam was on a tighter lsa and was bigger? I'm sure a 28" tire will make a big difference also
Old cam 229/242 .631/.631 114
New cam 236/242 .624/.609 113+3
28" tires would help the 60 ft.
JPH/Crane Cam
DO NOT buy Billet Specialties from The Billet Spot (dragwheelz.com is his user name and web site). He is a sponsor on here. Thats where I ordered mine from almost 7 weeks ago. Paging Dragwheelz Dragwheelz.com
I finally have all four wheels but still don't have my lugs or valve stems. That guy has lied to me so many times in the past couple weeks
__________________ 2002 Z28 - H/C/I
2000 S10 Xtreme - bagged, under construction
Thanks for the heads up.....it will be quite awhile before it happens...besides I need skinny's to clear my c5 brakes up front and Billet Specialty doesn't make them yet. Bogart's might be the way to go.
I hope they get you squared away soon....sucks when companies want your money and then don't follow through on the goods.
JPH/Crane Cam
Yea night vid=hard to see lol but it was fun. We'll be experts at this editing stuff before to long (hopefully)
As for the kickdowns I wanna say 40ish??
1. It's going to rain
2. If it's not raining, the air will suck
3. Track prep seems marginal
4. Julie works, so I'm "Daddy Day Care" (Her mom did offer to watch the kids, though)
5. I'm a pu$$y, I know.....
__________________
2000 Z28: LME iron 403, AFR 225, RPM 4L60E, Vig 3800 triple disc, NX 200 with NANO,
17 inch M&H DRs, C6 front brakes. (Under construction)
