enjoyed the video but alittle sad when I saw that ws6 with custom cam stall and 100shot run only 3 tenths and 2mph faster with a cam and a stall, more than me
__________________ 2002 ws6 auto 329.1hp@5300rpm 335lbft.@4500 N/A 12.646@110.20,
NOS 100 Dry Shot@1100lbs. 11.76@118.51
were at a retarded altitude here in abq. Da is about 8000ft usually. And i finally figured out why the supra beat the mustang that bad. The supras numbers were uncorrected. It made 612rwhp actual and 757 corrected. Mustang made 604 corrected
Sweet vid, and yeah thats nuts if that mustang is making that kind of power at 9psi. He would have to be at extremely high rpms to pull those numbers at such low boost and have a wicked h/c setup.
Before the heads and cams he make 650 over spinning the blower. It sounded like a lot to me too but i have personally seen it dyno and thats what it made
It's got nothing to do with RPM, unless he was making 9 PSI at 4000 RPM and taking it up to 6000+ (to make more boost). 9 PSI through that small of a motor I don't see making so much power unless he's got one hell of a set of heads with an ideal cam. Agreed.
__________________ 2000 TransAm WS6 Lid | Ported MAF | Ported TB | 1 3/4" Pacesetters | 3" True Duals (X-pipe) | Dynomax Mufflers | LS7 Clutch | Pro 5.0 w/ short stick | !CAGS | Konis | Strano Sway Bars | BMR SFCs | TunedByTad | Proud member of PHK
