03-18-2009, 06:27 AM
#1 Teching In
GM Hot Cam? When replacing a stock cam in a 98 LS1 with a GM Hot Cam Kit do you need to replace the stock pushrods with shorter one's.
Thanks
03-18-2009, 08:29 AM
#2 10 Second Club
Yes. I would also do springs as well as a timing chain.
__________________
Chris
03-18-2009, 10:03 AM
#3 Teching In
GM Hot Cam? I've replaced the timing chain and the valve springs. The instruction with the cam did not mention changing the pushrods. Any idea on what pushrods I should use with this cam. I think the lift is between 515 and 525?
03-18-2009, 10:26 AM
#4 TECH Junkie
my guess would be that they designed the cam to run stock pushrods.
HOWEVER...stock pushrods are not the strongest pieces. so i would change them out of reliability concerns.
__________________
ARREST-ME RED 99 Z-28, M6 - TSP Torquer V1 (233/233 .589" 112*), HS rockers, Flowtech LTs, 3" TDs, magnaflow 4x9s, FAST 90/90 ported, Mez EWP, 160 stat, SSRA, TSP lid, ASP pulley, Hurst w/LSS, Spec 4, Fidanza FW, ATE rotors/hawk pads/SS lines, Koni 4/4, BMR springs, lca w/ brackets, TA bracket, phb, stb, 32/21mm swaybars, sfc, ZR1s w/ Nitto radials 408.6 hp, 379.5 torque
03-19-2009, 02:17 PM
#5 TECH Veteran
1998 Pontiac Trans Am
I am 99% sure that cam has a stock base circle size so no you don't have to go shorter. Some good stiff chromemoly P-rods would deflect less and be an upgrade though.
__________________ Just an average LS1
Strano springs and sways, Koni 4/4's, UMI PHB .
417rwhp/383tq
12.02/113 on heavy 17/9.5 ZR1 OEM Concepts + MT/DR's WTB: A set of Speedlines...
03-19-2009, 02:23 PM
#6 TECH Apprentice
if your doing a cam swap and already replaceing the springs and pushrods then i'd get a better cam then a Hot Cam. Go big or go home!
__________________
2001 Z28 SOM -150 shot
| 3200 stall
| built trans
| LT's
| ORY
| Spiralflow dumped
| SLP Lid
| SLP maf
| 160* stat
| BMR springs
| BMR adj. phb
495whp 549wtq
03-20-2009, 10:29 PM
#7 Teching In
GM Hot Cam! Thanks guys for your input.
Tags base , cam , circle , gm , hot , hotcam , kit , l92 , ls1 , ls2 , pushrods , replacing , springs , stock , valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
