I have 313,000KM 98 Trans Am 305hp version, runs like a top, pulls mirror-to mirror with buddys 35th SS 345SLP 35th Camaro. Bout to do cam/chain/pushrods/valvesprings/headers-cats-y/tune. Doesnt use ANY oil and runs balls out
In miles this would be :
194 489.183 miles
__________________ Current Summer : 1998 Trans-AM NBM WS9
Ls1 - SLP Lid, K&N Filter, Free Ram Air Mod, Egr Tube Cut, Magnaflow Muffler // T56 // Semi-gloss black CETA panel **Jan 4th-8th 2010 gets Comp Cam (222/224, 112LSA) and OBX-R Longtube Headers/Ypipe, Magnaflow Catback, Tint, Sportline Lowering Springs** Current Winter : 1995 GMC Jimmy
4.3L 4X4, White
I am looking at one with ~150,000 miles on it. before dropping it in what would be some suggestions to freshen it up? I was going to have the heads looked at and upgrade the intake. Put a new cam into it (still researching). I will have an electric water pump so no worries there.
i have 160K on mine and am going to do 241 heads with a 227/224 cam and a 3400 stall. i started having valve float around 80K and haven't fixed it yet since brand new heads are going on anyway. only thing i'd check is the fluids really: oil, coolant, tranny fluid and rear end fluids
This is pretty typical. You should check out the whole drivetrain. The rear and tranny are both kinda weak in these cars....
Yep, hence built tranny (basically a stage 2 rebuild of sorts), chromoly driveshaft, and a 12-bolt. The 12-bolt is giving me troubles, but that's a whole other story...
I bought my car last May, in June it threw a rod...at start up one morning.
It had 81K on it. But I only owned the car for 3 weeks so I cant say how the car was driven by the last owner. The motor was clean internaly except for the rod dust and hole it put in the side of the block.
anything over 100k imo is hi mileage on a modern hot rod
__________________ 99 Z28 mystic teal roller,rear qa1's spohn adj ta,adj phb,eibach pro kit,4.11's,th400,4xx stroker coming january 2010
01 tahoe 20's screens,LT's,etc...
99 trans am LT's,3"Y pipe,waiting on-cam,springs,stall,4.10's,fast intake
I NEED A FAST INTAKE PM ME IF YOU HAVE ONE FOR SALE
