Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > WELCOME TO LS1TECH > New LS1 Owners - Newbie Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-29-2009, 04:41 PM   #1
Trader Rating: 0
Default o2 sims make car run bad
I've been driving around for months with the SES light on. So I decided to get the o2 sims to put the light out. Plugged them into the rear, I took the car for a ride and it instantly ran bad, like it had a real bad miss. I went home, unplugged them. Took it out for a second ride, ran fine. Anyone have any ideas? BTW. Its a 99camaro ls1
pabansheematt is offline   Reply With Quote
Old 10-29-2009, 04:44 PM   #2
2000 Chevrolet Camaro
TooLateVTEC's Avatar
Trader Rating: 2
Sorry im not much help, but I have simms in my rears right now and it runs fine.
__________________
Allyn
2000 Camaro SS A4 # 3535,milled 243's with Cometic .045,custom Comp XE 230/236 cam,Hookers with catted Y,flowmaster catback,LS6 intake,FAST 36# injectors,3400 Vig. stall
'86 IROC-Z race car - 565",TH400, 5.60@127 so far
http://i32.photobucket.com/albums/d1...Picture001.jpg
TooLateVTEC is offline   Reply With Quote
Old 10-29-2009, 06:12 PM   #3
klujan13's Avatar
Trader Rating: 11
Quote:
my car has been running fine for 2 years on O2 sims? This may sound stupid but you sure you plugged them in the rears and not the fronts because if you did that would definitely make it run like @$$
__________________
1998 Trans Am
Tuned by Frost
Lid, !AIR, !EGR, LS6 intake, New Era ported TB, FIC 28.8lb injectors,
Mac Mids w/ORY and Magnaflow muff, LS2 timing set, LS6 oil pump, Taylor wires,
PerformaBuilt Level 2 4L60E, TCI SSF3600 stall, 24k cooler,
Eibach ProKit, Poly motor/tranny mounts, Black C5 wagon wheels, Drilled Slotted rotors w/Hawk pads.
klujan13 is offline   Reply With Quote
Old 10-29-2009, 07:56 PM   #4
Unertl42's Avatar
Trader Rating: 19
o2 sims don't affect the air/fuel ration, they just tell the computer that the cats that aren't there are functioning properly. If you put them in the front o2 bung, that will make your car run like shit
__________________
2001 NBM SS #2537
M6, LPP Headers w/ORY, GMMG, VRX3 Cam, Patriot Stage 2 LS6 Heads, Comp Hardened 7.350 Push Rods, LS7 Lifters, LS2 Lifter Trays, LS2 Ported Oil Pump, LS2 Timing Chain, Underdrive Pulley, Ported TB, Auburn diff, MGW shifter, Bilstein's w/Hotchkis Lowering Springs, SLP sub-frame connectors, Hotchkis tower brace
Unertl42 is offline   Reply With Quote
Old 10-30-2009, 12:36 AM   #5
Trader Rating: 0
I don't think the O2 sims are your problem. Suggestion go to auto zone, advance auto or something and have them scan the code. Then go from there. But I'm assuming you have headers which that doesn't matter. But when you put the headers on
1.) Did you change the plugs?
2.) One if not both of your 02's in the front might took a crap.
__________________
98 Red Camaro SS M6, 226/228 .585/.588 112 LSA, P&P 241 Heads, GMMG Catback to CME, Kooks LT's and Catted Y, FTP 85mm lid, SLP 85mm MAF, SLP Flow Pac, LS6 Intake, Shaner S3 P&P TB, TB Bypass, SLP UD Pulley, 160 degree Thermo, LS 6 Oil Pump, LS2 timing chain, American Racing TTII 17X9.5, Hurst Billet Competition Shifter with Speed Dawg Ball
425rwhp/407rwtq
06 Cobalt SS/Supercharged Stage 2 Kit, 5-speed, GMPP Catback this is my DD.
thewholefnshow1 is offline   Reply With Quote
Old 10-30-2009, 01:03 AM   #6
klujan13's Avatar
Trader Rating: 11
I don't see how the plugs or front o2's could be an issue being that he stated he went home unplugged the sims and went for a second ride and it ran fine, if they were the problem his car would still be running like crap. No matter the code the simple fact is he plugged in the sims it ran like crap he unplugged them and it ran fine again.....hence my theory he plugged them in the front on accident. Just my 0.02 cents
__________________
1998 Trans Am
Tuned by Frost
Old 10-30-2009, 03:16 AM   #7
hitmanws6's Avatar
Trader Rating: 7
O2 sims have no effect on performance, they are there to turn the SES light off only. ita an emissions code, so no performance is lost
__________________
353 CI LT1: OEM Ram Air Setup, SLP Airfoil, Ported Intake,TB Coolant Bypass, 160* Thermostat, 209/217 .465/.485 116 LSA ISKY Cam, .550 Lift ISKY Springs, LT4 Knock Sensor, Edelbrock Shorties, GMMG Catback, PCMforLess Tune, UMI Strut Tower Brace, UMI PHB, Rear SLP Bilsteins, Heater hose mod *** SPONSORED BY WS6 RACING***WESTBOUND-PHK
hitmanws6 is offline   Reply With Quote
Old 10-30-2009, 04:58 AM   #8
Trader Rating: 0
Quote:
But what if one of his front 02's is going out? Just don't even think about the 02 sims. I've always heard about people saying the front 02's if one goes out then it will make the car run like carp. But I tell you about 2 months ago I had one starting going out on me and one minute the car ran fine and then the next minute it ran like crap and when the 02 started acting right it would throw you back in the seat and take off. An yes one minute the SES light came on and then it went off and it keep doing that a couple of times and then later on it just stayed on. Let me ask you a question have you had a front 02 go out? If you haven't I can tell you a ricer will kill you on take off, that gives you an idea of how bad the car can run if one does crap on you.
__________________
425rwhp/407rwtq
Old 10-30-2009, 04:57 PM   #9
Trader Rating: 0
Thanks for helping the new guy out.
I'll make long story short. I got the car with no motor, trans, or wiring harness in it. Got a new shortblock, put it all back togeather. heres were I went wrong. I had a piece of the harness draped over the top of the motor. in other words, what I thought was the front o2 plug was the rear. I got it all straightend out..and now I have reverse light too. I also have a set of o2 sims I dont need. I found out the code was turned out in the pcm.
Thanks for the help.
Old 10-30-2009, 06:06 PM   #10
01SOMZ28's Avatar
Trader Rating: 0
This sounds exactly like what is going on with my car right now. It just started last night. Check out my thread Car started having problems (misfires and almost dies at idle)
__________________
2001 Z28 SOM -150 shot|3200 stall|built trans|LT's|ORY|SLP Lid|SLP maf|160* stat|3" cutout|tuned|BMR springs|BMR adj. phb
495whp 549wtq
01SOMZ28 is offline   Reply With Quote
Old 11-01-2009, 01:52 PM   #11
Trader Rating: 0
Did you get your car fixed and was it an O2 sensor? I had no idea how shitty they will make your car run if one of the front (upstream) sensor's went out. I had them go out before but it was only the rear sensor and not the front. Looks like your an A4 an if the car studders and stuff like that on you, image how I felt when I'm an M6 and don't know if it's going to die or not and then out of now here comes the 400rwhp out of no where like a 300 shot of nitrous.
__________________
425rwhp/407rwtq
Old 11-01-2009, 07:38 PM   #12
BlackScreaminMachine's Avatar
Trader Rating: 16
O2 sims just given a constant Mv range to let the car to think it is acceptable. Get the car tuned, have the rears shut off so they wont be an issue. O2 sims are not a cure all, they work in some cases but not all.
__________________
2002 Navy Blue Metallic Trans Am.
Pullin both wheels w/ 1.75 60's
-Aaron aka
The Machine
BlackScreaminMachine is offline   Reply With Quote
Old 11-02-2009, 12:39 AM   #13
01SOMZ28's Avatar
Trader Rating: 0
Yup, i changed the O2's and it fixed the problem. And i know what you mean with the car studdering, almost dieing, and then taking off like a huge shot of nitrous! haha
__________________
495whp 549wtq
Old 11-02-2009, 10:41 PM   #14
1998 Pontiac Trans Am
SOMbitch's Avatar
Trader Rating: 5
Kudos to you for figuring out your problem. Enjoy the LSx world
__________________
Just an average LS1
Strano springs and sways, Koni 4/4's, UMI PHB .
417rwhp/383tq
12.02/113 on heavy 17/9.5 ZR1 OEM Concepts + MT/DR's
WTB: A set of Speedlines...
SOMbitch is offline   Reply With Quote
Old 11-03-2009, 05:09 PM   #15
Trader Rating: 0
Quote:
I like my LS1 so much im thinking about putting one in my 71z28. Gotta sell my 406 first though.
Old 11-03-2009, 05:38 PM   #16
MillerTime85's Avatar
Trader Rating: 1
Something's not right here.Check where you plugging them into.Then also might want to check Coils/Wires
__________________
99 Silverado SCSS (DD)
99 NBM Camaro Z28 A4
SLP Lid|SLP Smooth Bellow|TB Bypass|Chrome C5 Y2K's|Slowmaster Catback
MillerTime85 is offline   Reply With Quote
Tags
02, bad, camaro, car, cobalt, ls1, make, mod, o2, pontiac, sensor, sim, simm, sims, ss, stall, trans
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
