Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > WELCOME TO LS1TECH > New LS1 Owners - Newbie Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-02-2009, 01:38 PM   #621
slayerized6's Avatar
Trader Rating: 9
Quote:
Originally Posted by 98trans am View Post
could i get the part numbers for the seat belt guide on the passenger side (the triangle with a hole in it attached to the headrest) and the plastic cover for the bottom, side of driver's side seat (the one with the seat adjustment buttons on it)?
front seat shoulder belt guide (93-96 coupe), graphite, RH = 16730218
front seat shoulder belt guide (93-96 coupe), graphite, LH = 16730219
front seat shoulder belt guide (93-96 coupe), gray, RH = 16730220
front seat shoulder belt guide (93-96 coupe), gray, LH = 16730221
front seat shoulder belt guide (93-96 coupe), beige, RH = 16730222
front seat shoulder belt guide (93-96 coupe), beige, LH = 16730223
front seat shoulder belt guide (96-02 coupe), neutral, RH = 16789714
front seat shoulder belt guide (96-02 coupe), neutral, LH = 16789715
front seat shoulder belt guide (97-99 coupe), gray, RH = 16799272
front seat shoulder belt guide (97-99 coupe), gray, LH = 16799273
front seat shoulder belt guide (97-02 coupe), pewter, RH = 16799274
front seat shoulder belt guide (97-02 coupe), pewter, LH = 16799275
front seat shoulder belt guide (00-02 coupe), ebony, RH = 16817200
front seat shoulder belt guide (00-02 coupe), ebony, LH = 16817201
front seat shoulder belt guide (97-99 convertible), gray, RH = 16799316
front seat shoulder belt guide (97-99 convertible), gray, LH = 16799317
front seat shoulder belt guide (96-02 convertible), neutral, RH = 16799318
front seat shoulder belt guide (96-02 convertible), neutral, LH = 16799319
front seat shoulder belt guide (97-02 convertible), pewter, RH = 16799320
front seat shoulder belt guide (97-02 convertible), pewter, LH = 16799321
front seat shoulder belt guide (00-02 convertible), ebony, RH = 16817202
front seat shoulder belt guide (00-02 convertible), ebony, LH = 16817203
http://www.ls1tech.com/forums/3064669-post24.html
__________________
98 Trans Am
slayerized6 is offline   Reply With Quote
Old 06-22-2009, 09:49 AM   #622
Trader Rating: 2
Send a message via AIM to Rhode Island Red
My stock jack went kaput and I'm about to drive across country ... Need the part number for the jack...
Need the part number for the rubber bumber for the drivers side wiper blade (may as well give the pass side # as well) - you know, the rubber thing that the wiper arms rests on ... they pop out too easy (for a TA)
__________________
2002 Firehawk #35 - All Known and hidden options... 382rwhp/366rwtq
|!CAGS | SLP bolt-on SFC's | STB | TB Bypass | Ported Throttle Body | SLP Aftermarket Dual/Dual | 160 T-stat | Airborn coated Kooks LT's | Custom Cam | UD pulley | !Air | LS7 Clutch pics and info
"Don't waste time or time will waste you" - Knights of Cydonia by Muse. Album: Black Holes and Revelations
Rhode Island Red is offline   Reply With Quote
Old 06-24-2009, 09:34 PM   #623
Trader Rating: 0
Default 6.0L Need Info Please Help
I just bought what the seller said was an LQ9 6.0L but I was toldthey only came out in Escalades is this true because this one has what looks like junkyard yellow writing on it that say GM 2500 HD. Does anyone know any casting numbers I can check to verify.By the way it has 6.0 cast on the block and the block is iron with aluminum heads.Thanks
67turboduece is offline   Reply With Quote
Old 07-08-2009, 10:05 PM   #624
blk97z28's Avatar
Trader Rating: 0
Send a message via AIM to blk97z28
1997 camaro PCM bracket that holds it down onto the car?
__________________
http://i80.photobucket.com/albums/j1...k97z28copy.jpg
1997 camaro Z28 A4 black 74,252 miles, chrome SS ten spokes, mangaflow catback, chrome metal Z28 emblems, chrome camaro lettering in the back, stock 10 bolt, painted chrome calipers, new opti, MSD 8.5 plug wires, NGK iridium plugs. 265 RWHP and 293.2 RWTQ, shorty antenna, under drive pulley,3 inch y-pipe, headers, tune, 245/40/17 tires all the way around!
blk97z28 is offline   Reply With Quote
Old 07-08-2009, 10:06 PM   #625
blk97z28's Avatar
Trader Rating: 0
should I use the 98 one?
__________________
Old 07-09-2009, 01:21 PM   #626
mike s.'s Avatar
Trader Rating: 2
Quote:
Vortec max was an LQ9 I believe, it was a stouter version of the 6.0 available for GM pickups.
Quote:
I dont know for sure if they are the same, but 97 is LT1 and 98 is LS1, there may differences in the way the PCM are mounted. I will try and look it up for you when I get to my home computer.
__________________
Mike
2002 A4 Z28 Hardtop 65K miles, Corsa Catback, MTI Lid, K&N Replacement Filter, Best of 13.3@108 Diboll, Texas with those mods. Since then: HP Tuners w/ C2O Tech Edge Wideband, LS6 Service Replacement Engine, March Underdrive, SLP LT, Drag Radials- no times yet. Dynoed 1-20-07, 340 hp, 395 tq
mike s. is offline   Reply With Quote
Old 07-09-2009, 11:00 PM   #627
mike s.'s Avatar
Trader Rating: 2
10195539 94-97 LT1 ECM Bracket
__________________
Mike
Old 07-09-2009, 11:50 PM   #628
blk97z28's Avatar
Trader Rating: 0
Quote:
thanks I found one used her for 25 bucks.
__________________
Old 07-09-2009, 11:50 PM   #629
blk97z28's Avatar
Trader Rating: 0
thanks I found one used here for 25 bucks.
__________________
Old 07-24-2009, 03:18 PM   #630
2000 Chevrolet Camaro
2000ssowner's Avatar
Trader Rating: 0
Key fobs for a 2000 camaro?
Thanks in advance
__________________
2000 A4 SS
Slp LId|K&N Air filter|Slp y Pipe|Slp LM1|Stock 3.23 gears
Future mods: m6 swap, 3.73gears,pacesetter longtubes,catted y, ls6 intake, msd wires with new spark plugs,and TUNE
2000ssowner is offline   Reply With Quote
Old 07-24-2009, 10:20 PM   #631
JoeMack's Avatar
Trader Rating: 12
Valve cover bolts (really just need rubber grommets) for 02 LS1. Thanks
__________________
Red 02 Z28,M6,iron 370,ProCharger pending,MidWest Fab9,FAST92,NW TB,85mm lid and MAF,30lb inj.,160*stat,Whisper CAI,Dynatech Supermaxx LT's w/catted Y,LM2,Textralia,Hurst Billet/Plus,JSS,Eibach ProKit,Cut Rear Stock Springs,LW APB,Bowtie Grill,SS Spoiler,!CAGS,SLP(style)SFC,SPOHN LCA,TT2's 17X9.5 & 17X11,Nitto 555 275/40 & Nitto 555R 315/35 12.03@117 [1.88 60']before 370
JoeMack is offline   Reply With Quote
Old 08-02-2009, 09:22 PM   #632
Nice4thgenZ's Avatar
Trader Rating: 10
Send a message via AIM to Nice4thgenZ
i need the numbers for the rear trim panels, on the right and left side in the rear that cover the spare tire area in ebony with out speakers
http://www.wolferacecraft.com/images...fbbulkns05.jpg
__________________
Pearson Racing
Herzog Racing Engines
1998 Z28 Carbed LS1
Nice4thgenZ is offline   Reply With Quote
Old 08-08-2009, 01:14 PM   #633
Konstantine16's Avatar
Trader Rating: 0
Exhaust Muffler Hanger (98-02) = 10407350
Does this include the complete hanger or just the rubber peice? I need the entire hanger because mine is gone and I have a ghetto rigged metal plate holding my whole muffler with one bolt and its not safe
Konstantine16 is offline   Reply With Quote
Old 08-11-2009, 01:57 PM   #634
AznMuscle's Avatar
Trader Rating: 7
Anyone got the part number for the air ram thing under the front of the car? For the radiator, so air will actually go to it at highway speeds.
__________________
1999 Trans Am m6-FTP lid||SLP 85mm MAF||P+P TB||ls6 Intake Manifold||Stock 243s||AZPS03||PowerBond 25% UD pulley||Hooker LTs||SLP LM||4.10s
c5 zo6 wheels: 18x9.5 in front and 18x10.5 back, nitto 555, 255 front/285 back. UMI LCA relocation brackets|| UMI on-car adj LCAs||UMI on-car adj PHB
LS1tech....The only place where 99_z28 can get banned for not running 11s.
AznMuscle is offline   Reply With Quote
Old 08-25-2009, 02:08 PM   #635
Trader Rating: 0
This thread has been super helpful... I found dozens of part number that I needed for my build.
here are the ones I still can't find:
for a 1999 Corvette (LS1):
-PCV hose that runs along the back of the motor
-AC Pressure Hose(s?) the hoses that attach to the back of the AC compressor
-AC Pressure Sensor the sensor that plugs into one of the above hoses
-TAC connector to i/p Harness the harness that goes between the TAC and the gas pedal.
-AC Compressor/Power Steering/Alterantor BeltS
-Fuse/Relay Block assembly for engine components
for a GTO LS2 (or any LSx motor really)
-the black front and rear plates that you can hook on to hoise the engine (the mount to the heads and are triangular in shape with 3 bolt holes and a loop on top)
apparently they don't come on the Corvette LS1 or at least mine didn't <_<
any help would be greatly appreciated
twistedsymphony is offline   Reply With Quote
Old 09-04-2009, 05:51 PM   #636
Trader Rating: 0
Default Part Numbers Request
For 2000 Firebird. (with jittery headlight syndrome)
What is the part number for the bushing that the pivot pin on the headlight motor actuator arm (right side - 16526060) goes through where it attaches to the headlight assy.? Also the part number for the retainer that holds this in. I'm sure many owners have this issue - most noticable with reflective highway signs. Thanks.
richdalenta is offline   Reply With Quote
Old 09-08-2009, 06:59 PM   #637
PedaltoMetal's Avatar
Trader Rating: 0
Need the #'s TAC module, DBW pedal assembly, and the harness between the 2 for a 2003 Chevrolet Silverado or interchange info. Thanks.
Edit: found thanks to GMpartsdirect
12588923 TAC module 03-05 trucks
15177923 accelerator pedal (with module & position sensor)
15118849 throttle position switch wiring harness
12586243 03 PCM changed to 89017739
__________________
95Z with some mods in the car between the intake and the exhaust. Here's a hint TCI3000, built trans, 3.23
Still need 03 truck ECM.
PedaltoMetal is offline   Reply With Quote
Old 09-12-2009, 02:23 PM   #638
White.Lightning's Avatar
Trader Rating: 43
Send a message via AIM to White.Lightning
4L60e related items:
The "tab" and bracket for the shifter cable.....and if they are LT1 or LS1 specific???
Shifter cable? Again, LT1 or LS1 specific?
Thanks
Andy
__________________
1998 Artic White T/A M6 H/C FQuick/Pics
1999 Artic White Z28 M6 SOLD FQuick/Pics
White.Lightning is offline   Reply With Quote
Old 09-19-2009, 06:22 PM   #639
Trader Rating: 3
Anybody have the part number for the little plastic triangle pieces that cover up access to the outside mirror nuts? I couldn't find it anywhere in the part number thread. Thanks!
__________________
99 Z28 M6: NBM w/ custom flames
ARH LTs w/catted y, GMMG, 3.73s, Pro 5.0, MTI lid, Spohn PHR, Spohn LCAs, Spohn solid mounts, Hotchkis 1" springs, Koni SAs, 17x9.5 TTIIs, stereo stuff
13.16 @ 112.70 2.2 60' (w/4.10s, stock manifolds, ORY, cutout)
My Z28
91 GMC Syclone #0113
MTN_Z is offline   Reply With Quote
Old 10-09-2009, 01:56 AM   #640
dnm12's Avatar
Trader Rating: 13
I need help with a few things:
LS6 valley cover gasket
LS6 valley cover bolts
Cam bolts the three that hold the cam sprocket to the cam on 98-02 ls1's
Thanks a bunch
dnm12 is offline   Reply With Quote
Tags
10411289, 10417037, 12335526, 1999, 1999366, 88899145, belt, bulb, cooler, gm, guide, part, parts, seat, trans
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
