| TECH Resident
| New Thread: Build Dates & Gm Claim History The old thread was a mess so I figured I would make this new thread a sticky and lock it so all PM's would be sent. PLEASE READ THROUGH THIS ENTIRE THREAD BEFORE SENDING THE PM TO ME!!
Beings I have access to GM Dealerworld, which includes SI and VIS, I can check the following:
Vehicle Build Date - GM build date date (not SLP or ASC build #)
Warranty Start Date - The day the 3/36 warranty started
Delivering Dealer - Where it was delivered from GM when new
Claim History - All history performed by a GM dealer
Service Codes - All build info (RPO codes & Descriptions) Some older cars (98-99) only give RPO codes w/o descriptions. If you need to know something particular like gear ratio or something like that I may be able to look it up for you.
All I need is the last 8 digits of your GM vehicle. I can get this info for any year between 96 and 07. Some cars VIS only gives the option codes rather than both the option codes with decsriptions.
Here are some guidlines that I would appreciate it if you would follow:
-PLEASE PM WITH REQUEST, ONE VEHICLE PER PERSON. IF MORE THAN ONE IS SENT, I WILL REPLY WITH THE FIRST VIN'S INFO.
-DUE TO THE HIGH DEMAND OF THIS SERVICE AND THE FACT THAT I AM DOING THIS IN MY SPARE TIME(PLUS 2 OTHER JOBS), PLEASE GIVE ME 3-4 WEEKS TO REPLY WITH YOUR INFO. IF YOU NEED IT SOONER, HEAD TO YOUR LOCAL GM DEALER.
Here is what your PM will look like (My car for example):
Delivering Dealer :
MOORE CADILLAC PONTIAC INC
15950 MANCHESTER RD
ELLISVILLE , MO 63011-2170
(636) 394-0300
Warranty Start Date : 02/01/2001
Build Date : 10/05/2000
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/06/2004 010894 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 67572 miles
04/23/2002 329239 # N1760 - FLASHER - TURN SIGNAL - REPLACE 26001 miles
12/22/2000 299008 # V0632 - INSPECT RADIATOR CAP INSTALL NEW CAP IF NECESSARY 5 miles
10/05/2000 A17531 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION
AG1 - POWER SEAT, DRIVER 6-WAY
AK5 - DUAL FRONTAL AIR BAGS
AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
BBS - HURST SHIFTER
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF
CC1 - LOCKING HATCH ROOF, REMOVABLE
C60 - AIR CONDITIONING, CUSTOM
DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - 3.4 RATIO REAR AXLE
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL
MN6 - TRANSMISSION, 6-SPEED MANUAL
NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT KNOB
NW9 - TRACTION CONTROL, ELECTRONIC
PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QFK - TIRES, P275/40ZR17 SPEED RATED
QF6 - 5-SPOKE 17" HIGH POLISHED ALUMINUM WHEELS
R6J - CDN
R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA
STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID
T78 - HEADLAMP CONTROL DELETE
UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
U75 - POWER ANTENNA
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V12 - POWER COOLING SYSTEM, STEERING
V73 - VEHICLE CERTIFICATION U.S.
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER
WS9 - FORMULA OPTION
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
Y82 - TRANS AM OPTION
1AY - ORDER MODIFICATION STOCK
1SA - OPTION GROUP - 1SA
19I - INT TRIM, EBONY
192 - TRIM, EBONY
41U - PAINT, BLACK
6ZM - COMPONENT FRT LH COMPUT SEL SUS
7ZM - COMPONENT FRT RH COMPUT SEL SUS
8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
__________________ 2001 WS6 #2137, AFR 205's (62cc), FM13, JETHOT LT's, GMMG, Tuned by yours truly
2005 R1 - Race Baffles, blockoffs, flushmounts...and f**kin fast!
"I know you understand what you think I said, but I am not sure if you realize that what you read is not what I meant."
GM Tech by day - ASE Master Tech, GM trained, blah blah blah
Reason: per user request 20071016
