Yella Terra Ultralite Shaft Mount Rocker Arms for L92 Heads Yella Terra Ultralite Shaft Mount Rocker Arms for L92 Heads .
For those of you looking for an alternative to running the stock rocker arm with your L92 head build up , now you have an alternative !
Yella Terra's shaft-mount rockers are an easy and economical way of boosting power, torque and reliability in late model engines. When Yella Terra bolt on rockers are used, the conversion can be performed in the vehicle with no head removal or machining required. Yella Terra's shaft style rocker arms are suitable for hydraulic roller camshafts and feature oversize shafts and bearings for massive strength, stability and long life. No more needle bearings in your engine! Simply bolt on to original 8mm rocker mountings with no valve cover clearance problems! Eliminates studs, guide plates and special pushrods. These are the new lightweight design which makes them the lightest rocker on the market for higher reving engines .
Thanks ,
Mike www.neweraperformanceparts.com sales@neweraperformanceparts.com
585-865-1832
__________________ www.NewEraPerformanceParts.com
Authorized distributor for STS turbos , BBK , RAM clutches , Motive Gear , Turbo Smart , QA1 Motorsports , SLP , Bassani Exhaust , Dynatech Headers , Pacesetter , Halltech , Spohn Performance , Powerbond , Aeroforce Technology , Patriot Performance , TA Performance , BMR , Yella Terra , SPEC Clutches , ET Performance , Trick Flow , American Racing Headers and much more !!
Order line 585-865-1832
