I will find one monday. Sorry i didnt get to it quick, i was very busy last week. I'll get with you on monday.
__________________ www.nanonitrous.com PM me your name and address for NANO info!!!785-331-2390
We also carry nitrous bottles, valves, nitrous parts and accessories!! Call me for recommended jetting.
Business Hours: M-F 8am-6pm Central Standard For after hour Sales or Technical Support please call Brad@913-626-4359.
brad, i know this is outside the norm, but would an empty nitrous bottle work for a system, if i replaced the burst disk?
nevermind that question, im going to build a pusher like from the sticky, and was curious about the difference between C02 and NITROGEN in the bottle, is there a difference? and what would the nitrous bottle need to be filled to as far as PSI.
I will tell you not to use co2. A nitrous bottle will not have enough pressure or capacity to support another. Our system is not a pusher system. Pusher systems have a non-variable type regulator and increase pressure going down track. These type systems are known to be dangerous on motors, as they are hard to tune. This is why NANO has several patents on our variable type regulator.
Could I use one of my acetylene tanks? or oxygen tanks? I guess it prob states the psi on the bottle that it will hold?
98373
Robert
It will need to support 5,000 psi or more. Check on the bottles for operating pressure.
__________________ Asian guy who drives an import and bmw, but secretly dreams about a big V8.
Home - Fcuk Iraq - Done playing soldier!
Nismo Exhaust/Dynotune Nitrous Wet Shot/NANO Kit/Motordyne 5/16th Spacer/mrev2/Other Stuff
Boynton Beach Dive Center - more info »
1550 N Federal Highway, Boynton Beach, FL - (561) 732-8590
You may need to call for address, it did not show up.
It looks like it is on Old Sappington Rd.
Let me know if these help. It is kind of hard to judge if there close enough for you.
Paintball Zone
2811 Dixie Farm Rd
Houston, TX 77089
Get Directions
(281) 660-0663
* approximate times
- paintballzone.net
^^They have 2 locations call for second.
Splatterhouse Paintball
1414 FM 359 Rd S, Brookshire, TX - (713) 515-1238
OPEN:Friday-Sunday 9am to dark
98373
Robert
Let me know if this works
Splat Attack Paint Balls
6224 114th Avenue Ct E, Puyallup, WA - (253) 840-6877
Open Monday-Saturday
Can you send me some towns that are close by to this zip?
07008 - Carteret, NJ - Near Pat Musi performance, I get my n20 filled there
08861 - Perth Amboy, NJ
Ok, i'll let you know what i find.
hey im in 85367 nitrous is 6.50 here crazy!!!i just got the set up installed on my car i found out my local welding shop could get 56lb bottle filled with n2o for 470.00 bought id just have to go back and fill it up which would cost 2.50/lb thtas a whole lot cheaper than paying 70.00 for a fill..i did it once but i really want to get my self a fill station..what else would i need besides the tank they will sell me and where can i get these parts..thank this is my first post here
98373
Robert
Robert just to answer your question (since you've answered so many in this section)...
Acetylene tanks are unique creatures since they actually have a sponge in there and the acetylene itself is actually dissolved in formaldehyde. They also are not designed for high pressure, only about 100-220psi in an acetylene cylinder depending on fill weight (and of course it becomes unstable over 15psi or so).
An O2 cylinder may work but typical working pressures for an O2 cylinder are in the 2000psi range, never seen one over 3000, so the rupture disk is sized accordingly. Of note the CGA connection is a 540, different from N2. You could use a helium cylinder as they are often designed for high pressure and have the same CGA. CO2 wouldn't work as its a liquefied gas with a head pressure of 900psi, a bit low for what you want in this application.
Technically any typical high pressure compressed gas cylinder would work with the correct rupture disk. They are only manufactured in 2 styles, high pressure and low pressure. High pressure cylinders are what you typically see on any welding gas and are formed from stamping solid steel. The rupture pressure assuming no exposure to high temperature (and thus weakening of the metal) is somewhere around 10-12,000 psi. The only thing that determines what pressure they can handle is the size of the rupture disk - so they are not stamped with max pressures. Low pressure cylinders are typical of what you see in propane or butane usage and have welded seem.
Also for future reference in this thread, you need a 580 CGA connection on your fill line to connect to a nitrogen cylinder.
And one thing, please be careful when working with gases, keep the cylinder secured with a strap and keep in a ventilated place - believe it or not in the compressed/specialty gas industry, pure nitrogen is the leading cause of death, as it will displace oxygen and asphyxiate you.
__________________ '01 Trans Am, NHRA Edition Engine: Direct flo, FTRA, Pace LS6 MAF, Mamo-ported FAST 90, SVO 30#'s, ASP, loudmouth, TTS headers w/cats, T1 cam, Accel 9000s, Eastside tuned, 160 Tstat, AFR 205s, Nitro Dave's Plate Drivetrain: Textralia clutch, Moser 12 bolt w/ 4.10s, 3" chromolly d/s
431rwhp/389rwtq on the motor
11.78@119.42 1.569 60'
We have used many CGA 677's and CGA 347's on the nitrogen bottles as well. Usually the cga 347's are on the 5,000psi nitrogen bottles and CGA 677's are on the 6,000psi bottles.
I would contact Nitro Daves Nitrous Outlet or Harris Speedworks for a fill station. They could point you in the right direction.
I will look today for some locations.
Paintball Zone
2811 Dixie Farm Rd
Houston, TX 77089
Get Directions
(281) 660-0663
* approximate times
- paintballzone.net
Thanks!
Paintball Zone
2811 Dixie Farm Rd
Houston, TX 77089
This place can do it, going back tomorrow as their tanks were too low to pressure my bottle to 4500psi today. After I move to west side of Houston I'll try the other location.
All I can find is a local paintball place but he only uses compressed air and can only fill my bottle to 3500 psi. This is kinda sh!tty. Cartek talked me into using Nitrous and this system because I wouldnt have to use a bottle heater and this is like "instant on" type nitrous. Now im stuck with a $600+ system that I an rarely use if I use it at all. When you guys made this system why didnt you let your custmers know that there is rarely NO shop that carries a machine that will pressurize nitrogen to 4500 psi? Was/is it because you wouldnt sell anything. I feel I have been ripped off in the worst of ways!
__________________ '99 Vette FRC: LT headers, Bassani X pipe, Borla Stingers, Cartek 4X heads, Cartek 2X cam, Ported FAST 90/90, 25% ud pully, 4.10 gears, NX Nitrous wet kit, custom tune and a few other goodies!
10.54 @ 134 with the 100 shot and a 10.3 AFR! 9's on stock bottom end or BUST!
You DON'T need NITROGEN. All you need is someone that can give you compressed air to 4500 PSI.
If you used CARTEK, then you might be in NJ. Any welding shop (should be a bunch by Cartek) should be able to hook you up without a problem.
Good Luck
