You can search by using google with your zip code and paintball, scuba, fire safety, or welding supply. You may need a quick connect fitting if your source does not have one. They are $16 dollars from us.
(Shown at the end of the line in the picture.)
You can also rent a 5k or 6k psi bottle from your local welding supplier. Then you will need a trans fill line from us that range from 125-195 dollars depending on which one you may need.
You can also post in this thread your zip code and i'll find one for you.
Hope this helps.
Brad@NANO
__________________ www.nanonitrous.com PM me your name and address for NANO info!!!785-331-2390
We also carry nitrous bottles, valves, nitrous parts and accessories!! Call me for recommended jetting.
Business Hours: M-F 8am-6pm Central Standard For after hour Sales or Technical Support please call Brad@913-626-4359.
You will rent a 6,000psi nitrogen bottle. It is the same size as a 56# nitrous fill bottle. You will get about 20-25 fills from this bottle. They usually cost around $7-14 dollars a month to rent. Then you would need a trans-fill line.
I can get an estimate together on this if you like.
Brad
Black River Paintball
2500 Carson Gregory Rd, Angier, NC - (919) 567-9977
If you have a 3,000psi system this guy can do it for you-
Cape Fear Scuba, Inc.Write a review
5447 Yadkin Road, Fayetteville, NC - (910) 867-2844
Shoot me a PM for a fill line cost. I get home end of the week and am going to look into getting a bottle.
Does the fill line have a 4000 psi regulator on it to fill or do you fill to 4000 and stop when you see fit (risking overfilling) ?
Pm Sent
Quote:
Originally Posted by waterbug1999
-55420-
I have to drive clear across town to get mine filled to 4000 PSI, get charged 10 bucks too.
Is it possible to just buy one of those big bottles somehwere, if so what should we look for?
You need to look for a 5,000psi or 6,000psi nitrogen bottle. You can rent them from local welding supplyers, such as praxair, linweld, and american airworks. They usually cost $7-12 a month to rent. They are the same size as a nitrous fill bottle. If you get one, all i need to get get you a fill line (around $175) is the cga number off of the valve. You could then fill them from yourself.
I will do some searching here in a little bit for another fill source for you.
Brad@NANO
Capt'n Carl's Paintball
Write a review
63 Concord Rd
Chester, PA 19014-2902
(610) 364-9666
captncarls.com
Let me know if these work for you.
Both fill to 4500psi
Army Navy Outdoors
1649 N Military Trl
West Palm Beach, FL 33409-4711
(561) 684-5533
armynavyoutdoors.com
Let me know if this works for you.
Give me a little bit i'll try and find one for you.
brad, i know this is outside the norm, but would an empty nitrous bottle work for a system, if i replaced the burst disk?
nevermind that question, im going to build a pusher like from the sticky, and was curious about the difference between C02 and NITROGEN in the bottle, is there a difference? and what would the nitrous bottle need to be filled to as far as PSI.
