Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Nitrous Oxide
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-29-2009, 11:28 PM   #21
ericg69ss's Avatar
Trader Rating: 0
Quote:
Originally Posted by Ruckus46Gt View Post
does gary run his white turbo mustang lx in same class? Know he runs a 275/60/15 drag radial and well that car is a monster on the top end
I haven't seen it out there and don't know. All those Turbo cars are monster on the top end. Dave Bowman's turbo 4th gen Camaro went 5.027 @ 150.10mph. With that mile an hour it should be ET'ing quicker but its pretty tough to put all that power down on a 275 tire.
__________________
2002 Trans Am WS6
1969 Camaro SS- 350ci street/strip car, 10.80's Naturally Aspirated
ericg69ss is offline   Reply With Quote
Old 09-29-2009, 11:39 PM   #22
ericg69ss's Avatar
Trader Rating: 0
Quote:
Originally Posted by MelScrilla View Post
what size injector would you have to run to hold up to 4 dry stages?
Currently have 83lbs/hour injectors that are good enough for about 1300HP. That would be pretty much maxing them out to full duty cycle though. That would also allow me to use at least 2 stages and up to about 400HP and change of Nitrous. Most likely I will switch them out for some 160lbs/hour injectors when we put the new motor in. Anyone looking for some 83lbs/hour injectors??? LOL
__________________
2002 Trans Am WS6
Old 09-30-2009, 09:01 AM   #23
ATVracr's Avatar
Trader Rating: 4
High 90's-low 100's .... we are running 86's right now with room left in them.
__________________
Gangsta motor .... under constuction.
Thanks to Applied Nitrous Technology, Performance Induction Specialties, Kooks headers, Madman and Glen Burnie Racing!
ATVracr is offline   Reply With Quote
Old 09-30-2009, 09:04 AM   #24
ATVracr's Avatar
Trader Rating: 4
Quote:
I think the tuning would be alot easier if you could find something between 160 and the 83's.
Old 09-30-2009, 12:19 PM   #25
ericg69ss's Avatar
Trader Rating: 0
Quote:
Agreed. I threw the 160's out as an arbitrary number but as we get closer my tuner and I will discuss it further. Probably will use something closer in the 100-110lbs/hour. Usually a good rule of thumb for injector needs vs horsepower is the lbs/hour of the injector x 8cyl x 2= Horsepower Injectors can support.
IE, 83lbs/hr x 8 x 2= 1328HP
Of course you can play with the fuel pressure a bit to get a bit more but I would prefer going to a bigger injector.
__________________
2002 Trans Am WS6
Old 09-30-2009, 01:26 PM   #26
ATVracr's Avatar
Trader Rating: 4
I'm right there with ya.
We are looking at the same thing for next year.
__________________
Old 10-28-2009, 12:00 AM   #27
Nimitz87's Avatar
Trader Rating: 14
Send a message via AIM to Nimitz87
big ol stroke on that motor for sure...good luck with it!
just curious for the 275's what rim width do most guys run 10" or 12" rims?
Chad
__________________
Engine: heads/cam dart/torquerV2 stock bottom end HS rockers, ls6 intake
Drivetrain: M6(soon to be A3) Moser 9 inch, strange pro case 4.11's
Suspension: UMI LCA's/SFC's/PHB QA1's, midwest Chassis torque arm !front swaybar
Nimitz87 is online now   Reply With Quote
Tags
belt, big, build, car, drive, inch, jesel, ls1, lsx, motor, motors, nos, ram, sec, tunnel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
