need help with wiring a complex cos 5 set up I know i need to run Two relays and to ground out pin 56 red to engage the nitrous tune. I am running a stand alone fuel system as well and want everything to run off of one switch
Here is what i am running i just need to know how to wiring properly
msd window switch
wot switch
fuel noid
nos noid
stand alone fuel pump
fpss
cos5 red pin ( will run a relay from arming switch to convert from Pos to neg)
one armming switch
purge noid
purge switch
have a goo idiea on how its spost to be but rather make sure the first time
thank you |
