Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Nitrous Oxide
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-21-2009, 05:00 PM   #1
TA1364's Avatar
Trader Rating: 4
Send a message via AIM to TA1364
Default Couple questions before spraying first time
How long does it take you guys to heat your bottle up? Say from 650 to 950.
Also what kind of mph gain roughly will I see from a 100 shot. Mods are headers, intake, 4400 converter. It has trapped 109. Just making sure I'll have enough room to keep it in 3rd with 5900 shift points.
__________________
98 Trans Am-Sold
98 Formula- Bolt ons
n/a 12.33@109.74, n2o 11.37@120.65
TA1364 is offline   Reply With Quote
Old 10-21-2009, 05:45 PM   #2
tiresmokinV8's Avatar
Trader Rating: 0
Im running a nx kit and the time it takes to heat the bottle depends on the starting bottle temp. When I first got it it was maybe 65-70* out and to raise the pressure from 650- 1050it took maybe 10 mins but recently its been aroun 45-50* and even with a blanket wrapped around the heater and bottle it takes a half hr atleast to raise the same pressure. As far as trap speeds my s-10 is slow but you can read my sig to see the increase and that was having to let off for it to shift into 3rd since it wouldnt shift on its own under wot for some reason that run. Looking at my hptuners scan it showed I let off for a little over a second before I got back on it.
__________________
2000 Sonoma Zq8-2 Extcab 4.3 auto
Dual Spintech Prostreets, Magnaflow ypipe and cat, K/N FIPK, Ls1 e-fan, ASP Underdrive Pullies, Msd coil, 180* stat, B&M Transpak & vette servo, HPTuners, Narrowed 8.8 swap 3.73 gears disc brakes trac loc Caltracs, NX nitrous kit.Best N/A:15.78@88.07 100shot 14.56@98.2
tiresmokinV8 is offline   Reply With Quote
Old 10-21-2009, 07:13 PM   #3
2002t/a06's Avatar
Trader Rating: 2
Send a message via AIM to 2002t/a06
As far as bottle pressure it depends on what kind of heater you have, temperature outside, and how full the bottle is. trap speed's maybe 120-125mph i dunno.
__________________
02 T/A A4- A couple of things.
03 Grand Prix gt- the dd
Quote:
Originally Posted by Ruckus46Gt View Post
he's going to post pics then your going to break your other hand
2002t/a06 is offline   Reply With Quote
Old 10-21-2009, 07:19 PM   #4
TA1364's Avatar
Trader Rating: 4
Well today the bottle was full, 70 out side and I started at 650. It took 15 minutes to get to 900. I have a nitrous outlet heater.
__________________
98 Trans Am-Sold
Old 10-21-2009, 07:34 PM   #5
2002t/a06's Avatar
Trader Rating: 2
Quote:
That sounds about right man.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
