Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Nitrous Oxide
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-26-2009, 05:55 PM   #21
ericg69ss's Avatar
Trader Rating: 0
Default 1/8 mile time
6.07 119.17mph--1.42--300 shot (DRY)--ericg69ss--02 Trans Am--TH400--09/10--275DR
Hard to see on the video but this was the last pass I made before I sold the motor. Track was shit that day and had to footbrake it. Gunning for that 8 second slip when the new combo is finished and running. Night vision video FTW!
__________________
2002 Trans Am WS6
1969 Camaro SS- 350ci street/strip car, 10.80's Naturally Aspirated
ericg69ss is offline   Reply With Quote
Old 10-26-2009, 06:31 PM   #22
Trader Rating: 1
10.54@134--1.53--100 shot--Jdaniel--'99 FRC Corvette--MN6 6spd--16-Oct-2009--#22
I know that 2009 is almost over with but more times will come for 2010. Here is my time slip and a video!
Here is a break down of the mods and I was spraying a 100 shot!
1999 Corvette FRC
Cartek Stage 4X heads. Includes, full porting heads intake, exhaust, and combustion
chamber, Manley sever duty stainless valves, 2.02 intake, 1.57 exhasut, seals, Manley dual springs, spring seats, seals, titanium retainers, milled .030, cleaned and assembled.
Custom grind Cartek Stage 2X Cam computer verified.
228-232 582-598 116LSA
Cromoly hardened push rods.
Cometic heavy duty head gaskets.
ASP under drive pulley with belts.
Roll master dual roller timing chain.
Z06 ported oil pump setup for the roll master.
FAST 3 piece intake manifold ported to 4X with a 90MM throttle opening.
Ported LS2 throttle body.
ECU Reprogram 97-2004 LS1 full dyno tune.
Notch piston for clearance.
Complete NX system includes, NX wet kit with 10# bottle, purge, MSD digital RPM window switch, timing retard module, custom switch panel with micro switches and LED lights, all wires, Bosch relays. Also includes, blow down tube, full throttle switch, Kenny Bell Boostapump, and NGK TR6 spark plugs.
Nitrous Outlets Fully automated aluminum bottle heater
4.10 gears.
C5 passenger and driver side 300M output shaft with side gear.
C5 line lock kit includes pre-bent line with braided flex hose, inline line lock solenoid, and switch installed.
Vararam intake
Vararam Power duct
GM Racing spark plug wires
160* thermostat
New Coolant crossover
American Racing Headers (1 7/8 primaries 3" collector)
American Racing 3" X pipe
Borla Stinger 2.5" catback
Built tranny by Lethal Performance
Hurst C6 short throw shifter
Spec III Clutch and Billet aluminum flywheel
Brand new Slave cylinder
Upgraded Tick Performance Master cylinder
Innovate LC1 Wideband
__________________
'99 Vette FRC: LT headers, Bassani X pipe, Borla Stingers, Cartek 4X heads, Cartek 2X cam, Ported FAST 90/90, 25% ud pully, 4.10 gears, NX Nitrous wet kit, custom tune and a few other goodies!
10.54 @ 134 with the 100 shot and a 10.3 AFR! 9's on stock bottom end or BUST!
jdaniel is offline   Reply With Quote
Old 10-26-2009, 06:34 PM   #23
camscam02's Avatar
Trader Rating: 10
Quote:
Be sure to put them up in this format or it will not be posted:
ET@MPH--60'--size shot--Username--car--Trans--date--Post #
__________________
Cam only 10.97 at 123 w/a 1.46 sixty foot
Cam only+ a shot 10.10's at 135 and no traction
camscam02 is offline   Reply With Quote
Old 10-26-2009, 06:35 PM   #24
1994 Pontiac Firebird
Firehawk441's Avatar
Trader Rating: 3
If you want to add tire to mine. I run on Hoosier 30x10.5 radial. Also delete the #9 time slot. That is my old time.
__________________
9.4 N/A PASS... http://tinypic.com/player.php?v=259ied2&s=5
BEST ET... 8.65 @ 159 MPH
Firehawk441 is offline   Reply With Quote
Old 10-26-2009, 06:47 PM   #25
Trader Rating: 1
Sorry. All I read was the first post and the list. I didnt see the second post and your format request. Fixed.
__________________
Old 11-07-2009, 11:51 PM   #26
LS1SpeedAddict's Avatar
Trader Rating: 1
9.005@150.20--1.34--300 shot--Ls1speedaddict--'00 Trans Am--Glide--11/7/09--Post #25
__________________
2001 SS M6 224 cam, bolt ons
2000 WS6 408, Glide, TSP Giant, PRC 5.3 Heads & Some Spray
Best Time 9.005@ 150mph 60' 1.34 on a 300 Shot Thanks FBC!
LS1SpeedAddict is offline   Reply With Quote
Old 11-08-2009, 01:21 PM   #27
camscam02's Avatar
Trader Rating: 10
Quote:
Damn that baby is moving out. Congrats.
__________________
Old 11-11-2009, 08:59 AM   #28
BAKED's Avatar
Trader Rating: 9
9.44 @ 145----1.54--XXX shot--BAKED--99 Camaro--Glide--11/8/09--post # 28
Damn 60' killed me on that run. It usually cuts 1.3X 60's......
__________________
2001 SS A4 (part owner) 7.39 @ 93 1/8th
1999 Z28-Stock cube, Glide, 9", 2 guns
Best E.T. 6.03 @ 113 -- 9.36 @ 145
Lookin for crazy 8's
Tuned by BLUECAT
BAKED is offline   Reply With Quote
Old 11-15-2009, 02:02 AM   #29
Sofls1's Avatar
Trader Rating: 1
-Update-
Finally broke the 10 sec barrier!
10.89@125.05-1.56-150 Shot-Sofls1-98 Camaro SS-4l60e-10/7/2009-26x8.5 16 ET Street
__________________
.........................................just sayin
Sofls1 is offline   Reply With Quote
Old 11-17-2009, 01:47 PM   #30
Trader Rating: 1
10--9.061@153.8--1.35--350 shot--OutlawZ----- '95 Camaro--TH400--10/31/09-Post 30
__________________
THE OUTLAW
1995 Camaro Z28 1LE
West Coasts Fastest LT1 period..
CSM Racing Engines 383 LT1, AFR 227's, SR Cam, Jesel shaft rockers, Lunati crank, Oliver rods, sngl plane, Accufab TB, Nitrous Pro Flow plate, ATI TH400, Moser 9", FAST XFI
10.62@128 all motor
9.06@153.8, 1.35 60' ft on the bottle, 5.76 1/8th mile (aborted 8 second pass )
My youtube videos here--->http://www.youtube.com/user/tensecLT1
OutlawZ is offline   Reply With Quote
Old 11-17-2009, 06:20 PM   #31
Tony Shepherd's Avatar
Trader Rating: 3
12---9.28@144.21--1.33--275 shot--Tony Shepherd----93 z28 LT1------TH400--07/15/09 -Post 31
__________________
www.fast93z.com Nitrous Outlet FTMFW!
9.28 @ 144.21mph
2009 LTX SHOOTOUT OUTLAW CHAMPION
Tony Shepherd is online now   Reply With Quote
Tags
125, 18, camaro, combo, dry, duct, et, intake, ls1, mile, nitrous, shot, vararam
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
