Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Nitrous Oxide
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 02-10-2007, 01:38 PM   #41
blacktransam's Avatar
Trader Rating: 7
Send a message via AIM to blacktransam
shoot i hit it with 300 with 26* and 112 in the standalone..
i am not recomending this for other people.. but it has been working for me for a LONG time
Mike
__________________
Mike
tell him Mike sent you
02 GMC sierra escalade 20's.. and alittle bump.. 1200 watts of sound baby
93 Mazda RX7 Touring.. H/C/I LS1 6speed.. its coming..
98 TransAm 698/742 132+mph on one kit..a little of this a little of that and a Norris tune.. SOLD!!!
blacktransam is offline   Reply With Quote
Old 02-18-2007, 11:43 PM   #42
Trader Rating: 0
Well said. Through my own experience I would also like to add for those who are experimenting that a stand alone fuel system just for N2O is also a wise choice and piece of mind. Take the time to get all the right pieces in place don't cut any corners what so ever and over kill is not always a bad thing it can also save your engine. As the wise man said above "" If ya can't pay don't spray"".
NytMairLS1 is offline   Reply With Quote
Old 03-20-2007, 06:35 PM   #43
Driving in reverse
silver-mod-o's Avatar
Trader Rating: 11
been dumping a 150 wet hit on a camn only 5.3 and it loving it even with 100K on the motor.... its all in the tune...
__________________
9:1 347ci LS-West Coast Cylinder Heads-F.A.S.T.-Precision Engine & Turbo-Rossler-Yank-Trutrac-Hoosier
Think with your dipstick, Jimmy!!!
silver-mod-o is online now   Reply With Quote
Old 04-04-2007, 12:53 PM   #44
Trader Rating: 9
Im an A4 H/C/I and put down 417rwhp 407rwt.Im thinking of doing a 75-100 shot on top of what i got.should i be concerned or should i just go with a 50-75 shot.stock bottom ls1.Will rod bolts help,should i be worried about the stock pistons at those levels?
Okay,so I'm getting Katech rod bolts put in.Car is in the shop right now.Will I be safe for a 100shot? everyone says go for it,but want to hear from you guys
john563 is offline   Reply With Quote
Old 04-17-2007, 10:24 PM   #45
TAGIRL99's Avatar
Trader Rating: 0
Quote:
Originally Posted by 1 Bad Z
On a stock LS1 shortblock, as long as you know how nitrous works and how an engine uses it, You should "S-shape" bend all 8 rods and wristpins from the cylinder pressure of a big shot of nitrous like I did before you burn ANYTHING up. I have had 2 '98 vehicles with stock shortblocks and 300-350hp worth of nitrous with over 60k miles on the clock. Might of burned a strap on a plug every now and then that's about it. Was just seeing how far I could push the stock fuel system/Walbro pump set-up.
Tip: '98 stock pistons actually have a thicker top ring land than a 2001-up.
Heres a video of my 70k mile stock shortblock/300 shot car 1.30 60 footin on the back tires. It is a prime example of how far on the ragged edge the tune was. The air was so good out there that night I actually got on the lean side and burnt my first plug (watch at the end of the pass) Notice it looses a plug before the win light comes on and it still ran a 9.70 on that pass. I just got a little greedy and really wanted to beat the guy so I jacked up my bottle pressure to about 1175 after the purge!
http://www.iconautosports.com/media/...e_chevelle.wmv
__________________
TAGIRL99 is offline   Reply With Quote
Old 05-18-2007, 12:38 PM   #46
Trader Rating: 0
hello guys i bought this car and have a big concern of how much nitrous this car will handle. it currently has 250 jets on the direct port system. this is the list of mods that was given to me by the seller. can anyone help me with this?
Drivetrain:
CPT Pro Race 4L65E, 0 miles on it since refreshing "I currently hold CPT record for fastest car that has one of his 4L65E's in it" 9.7 @ 146mph. Has warranty on it!
TCI 3800 blower, NOS converter w/lockup
Stock 10 bolt w/3.73 gears, and a TA Cover this 10 bolt has been 10.4's in the 1/4. No whining at all!
Exhaust:
Hooker LT's, A.I.R Welded closed.....no emissions
Custom Y-pipe
3 inch cutout
B&B Tri-flow cat-back
Engine:
Jackson Motorsport Forged 347 shortblock
Diamond Forged 10.5-1 pistons
Eagle Rods
Comp Cam 234 236 on a 112 LSA
5.3 liter fully ported and polished heads
Comp 918 Beehive springs
Comp Hardened stock length push rods
Yella Terra 1.7 Rockers
LS6 Intake
Ported and Polished stock TB
Smooth Bellow
K&N FIPK "works amazing since the hood is fully functional!"
bigben77 is offline   Reply With Quote
Old 05-18-2007, 12:41 PM   #47
Trader Rating: 0
also the car has its own stand alone fuel system and this engine has never been sprayed.
Old 06-12-2007, 12:46 PM   #48
99WS7's Avatar
Trader Rating: 12
What kind of compression are you looking at? Seems pretty built, Id hit it with the 250 jets it has now and see how it does and make sure A/F is on point along with timing and it should be fine. Hell...Id hit it with a 300 if the 250 seems good!
__________________
99TA - Terrmy Heads / MS3 / 90-90 / Full Exhaust / Suspension / DLS 9" / TNT F1 / Fikse FM-5's
[SIGPIC]
04 Chevy Silverado Crew Cab - DD
04 Honda TRX450r - HRC cam, exhaust, jetted, K&N
99WS7 is offline   Reply With Quote
Old 06-30-2007, 10:36 AM   #49
Trader Rating: 7
10 bolt go BOOM
__________________
Mike
Old 06-30-2007, 12:12 PM   #50
Robert56's Avatar
Trader Rating: 2
My buddy's '03 Z06 is currently putting down 664rwhp and 564rwhp on bonestock longblock LS6, however this is with turbos. The reason I bring this up is, the torque of the turbo comes on so progressive and late in the rpms that you can get away with more over all hp compared to a nitrous set-up. Though a nitrous car can be set to mimick a turbo curve, as shown below. Really it is the low rpm torque that does the damage more often on stock blocks, not the HP. I finally busted a ringland on stockblock LS6 with 665rwtq @ about 3200rpm. So multi stage (my choice) or progressive can allow a higher overall HP by limiting the low rpm torque.
Here's my buddy's turbo set-up, check out how slow the tq comes on, and how late the torque peak comes, compared to some of us that have the mega tq spike down low.
and here's the turbo/nitrous overlay showing n2o can be set-up like a turbo (these are small hits just for reference, but you get the idea). Mine was dual staged, while Joe's was not.
Robert
__________________
'02 Z06, 408 LQ9, Direct Port Dry and 3-Stgs on stk PCM,
644rwhp 718rwtq-old setup
http://www.fquick.com/robert56
Robert56 is offline   Reply With Quote
Old 07-03-2007, 10:01 PM   #51
LS1Tech Sponsor
Frost's Avatar
Trader Rating: 32
Robert
I can't see the images; however, if they are dyno graphs, keep in mind that they do NOT represent how the turbo car will act on the street... In 4thgear on a dynojet, if I keep my catback on, I can only make 10psi, and that is at the very end of the pull.... in 4th gear ON THE STREET, I can make 15-16psi by the mid 2K-rpms....
But not to detract, I totally agree that the nitrous torque spike is much more violent.
Frost is online now   Reply With Quote
Old 07-03-2007, 10:07 PM   #52
Robert56's Avatar
Trader Rating: 2
Yea, it's my buddy's comcast site, and it keeps going on/off. His car currently is putting 664rwhp and 5xx torque on his TTx stock block and through the stock cats.
My 02 Z06 has 550rwhp and a best of 665rwtq, which do you suppose is the quicker car?
Robert
__________________
Old 07-28-2007, 02:14 PM   #53
Sam88Gta1's Avatar
Trader Rating: 12
Send a message via AIM to Sam88Gta1
Cam only 4.8 truck 49k miles spraying a NX single nozzle pilled at 200 bottle pressure 1050.
Pump gas,timing at 25.
Runs 7.9 @90 in the 1/8th in a 4800 lb truck with a sorry 1.90 60.
Going to pill it up till it runs out of fuel from the stock pump.
Never dynoed it.
Sam88Gta1 is offline   Reply With Quote
Old 07-30-2007, 08:46 AM   #54
Driving in reverse
Trader Rating: 11
25* on a 200 shot?? hmmm I guess I'm being conservative with my 24* and 150 pills... 100 octane fuel too... I guess its time for me to either pill up or add some spark.
__________________
Old 07-30-2007, 03:27 PM   #55
Sam88Gta1's Avatar
Trader Rating: 12
Quote:
The smaller bore and longer rod of the 4.8 allows it to take more timing.
I sprayed it with 31* on the 200 shot by accident and it didnt hurt anything.Didnt run very well or pull much past 5500.
Old 07-30-2007, 10:11 PM   #56
Robert56's Avatar
Trader Rating: 2
You guys that think gobs of timing is what nitrous likes, are dead wrong. On top of that, your pushing your luck with that much timing in a safety perspective. You'll learn after your first meltdown. Now, just because joe blow says, I was running 40* of timing and a 250 shot and it hurt nothing, yea maybe, once he lucked out. If ya plan on any serious dragging/runs, pull some timing out like your supposed to, or it could be fatal. Even N/A, you only put in enough timing to get max power, not until KR like most think. Max timing is not max power, or rather you don't need max timing to get max power.
Robert
__________________
Old 08-01-2007, 08:59 AM   #57
Trader Rating: 0
Am a new to NOS and have been absorbing all I can!
My question is in regards to the ecu's you guys use and the tunes. You would have a map/tune for the shot you are running at the track and do you use another map/tune for street duties?
I am about to embark on fitting an LS1 into my nissan 180sx and am thinking of using NOS to drag race with. My previous 4 cyl had an EMS 8860 ecu fitted and this can be setup run an LS1 and I am able to save various maps on the laptop and drop em in when needed!
Thanks Andrew
LS1802B is offline   Reply With Quote
Old 08-14-2007, 07:49 PM   #58
Trader Rating: 0
i run 22deg timing, 150rwhp nitrous, h/c/i/e ls1 and pump fuel... no problem... run consistent 10.6x@130.xx mph in my heavy 3800lbs transam!
__________________
1999 30th anniv. TransAm #877
Nitrous= 575+ rwhp, 575+ rwtq ** 1/4 ET=10.60 MPH=130.6
ET=11.71 MPH=117
Lid * Ported TB * TB stop grind * Ghann headers * ORYP * LS6 Intake * Magnaflow * Stage II heads * 230/230 .578/.578 112lsa * SLP double roller timing chain * GReddy catch can * Walbro 255lph * Nitrous * 37lb injectors * Carbon fiber ds * spohn rear suspension * Strange 12bolt 4.11 spool * built 700r4 manual shift * pro-ratchet shifter * vigilante 3600 3 disk (NA)
mulot30th is offline   Reply With Quote
Old 08-28-2007, 12:34 PM   #59
Speedin' Sam's Avatar
Trader Rating: 4
Give me some. I have a 99 we are setting up to drag. I can't get enough of the candy!
Speedin' Sam is offline   Reply With Quote
Old 10-07-2007, 12:34 AM   #60
01gtmustang's Avatar
Trader Rating: 0
Whats a good shot to run on a 98 auto z28 with a lid. He is running a dry 65 shot. Whats the safest amount he could go to without a tune.. 75??
__________________
2001 Zinc yellow GT
4.10 Gears | Flowmasters | Mac Off Road H | BBK CAI | March Pulleys
Predator Tuner | 75mm Throttle Body & Plenum | 75 Shot [b] 12.6 in 1/4
01gtmustang is offline   Reply With Quote
Tags
350, a4, adding, boost, bottom, end, handle, ls1, ls2, nitrous, nos, safe, silverado, spray, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
