True Street race Aug. 2nd (Wichita, Kansas) True Street
In order to compete, all vehicles and/or drivers are required the following:
1.Valid driver’s license
2.Valid vehicle registration
3.Valid license plate(s). Dealer plates prohibited.
4.Valid insurance “ID” card. Faxes and/or letters from insurance companies and/or brokers not acceptable.
5.D.O.T. Radials or D.O.T. Slicks on front and rear of vehicle.
6.Hood is required, may be made of lightweight material. Hood scoops permitted. Hood/scoop may be liftoff.
7.Any type of passenger windows permitted, but must be functional – up/down and in working condition.
TIRES: FRONT & REAR
DOT slick tires or DOT legal radials tires required for drive tires during the road tour AND the True Street competition and class run off. Racing slicks prohibited.
When we leave for the cruise we will be in a SINGLE FILE line...With a lead vehicle and a trail vehicle..competitors MUST stay in line behind the lead vehicle and in front of the trail vehicle..There will be NO passing, NO hot rodding basically you are required to follow the rule of law...If for ANY reason the trail vehicle passes you..they will take your tag number/car number down and you will be disqualified..
When we get back to the track we will go straight to staging lanes to start cool down..During cool down THE ONLY THINGS your allowed to do is to add fuel, add nitrous bottles, add ice to intercoolers, I will allow you to cruise on one set of tires and race on another so you WILL be allowed to change tires...THAT IS IT...Once the passes start the ONLY thing you can do to cars is take air OUT of tires...THAT IS IT..NO Spraying...NO Pushing NOTHING...Once you make your pass you are required to return STRAIGHT to staging lanes...We will keep track of running order nd if you outta order on your second or third pass you will be DQ'd...If the track officals shut you down your are DQ'd...You will make 3 passes and the qualifing order will be the AVERAGE of the 3 passes...If you red light and we are not able to get a time for a pass...that will be a 20 sec. run!!!
Entry - 50.00
PAyback - 80% to Winner, R/U and Semis
I am sponsoring a 13.0/12.0 and a 11.0 classes...
Here is how it will work..Everything will be the same and when we average your THREE passes the closest AVERAGE ET to 13.0/12.0/11.0 will win a pretty cool trophey...Now so that we are clear...IF YOU GO FASTER THAN ONE OF THE FORMENTIONED CLASSES THEN YOU ARE BUMPED UP INTO THE NEXT FASTER CLASS...
We will leave for the cruise around 3:00...
And if this is successfull I found some VERY cool tropheis for the next race!!!!!!
Now there is NO reason to not come out and have agood time and support MINE and the tracks efforts...
This class will run 1/4 mile |
