11-11-2008, 08:29 PM
#1 | | TECH Fanatic
Join Date: Apr 2004 Location: Atlanta, GA Ft. Walton Beach, FL
| what year model TAs came w/ fiberglass front fenders what year model TAs came w/ fiberglass front fenders on the LS1 TAs?
or are they only available as a non GM replacement panel?
I'm thinking paint on fiberglass is better than plastic since it's harder plus it's more durable. maybe a tad heavier and more costly?
any thoughts |
11-11-2008, 09:22 PM
#2 | | TECH Addict
| None came with fiberglass fenders. They are all plastic.
__________________
The UAW and the CEOs of the big 3 are all responsible for the big 3's problems.
Don't pin it on just one or the other. Both are at fault. |
11-15-2008, 12:19 PM
#3 | | On The Tree
| polyurethane fenders, right? wouldn't they look about the same as the paint on the doors? cause aren't the doors a fiberglass composite material?
__________________  1999 NBM Pontiac TA, T-Tops, MN6 w/Hurst short throw shifter, LSS, CAGS!, LG light-weight PS pulley, SLPs STB, SLPs SFCs, P/P MAF to 85mm, SLPs OEM Blackhawk Lid w/K&N Filter, CAI, BMR LCA Relocation Brackets,TB Bypass, EGR mod...more to come!!
Some People call it power wire...I Like to call it, Speaker Wire! |
11-16-2008, 08:58 AM
#4 | | Launching!
| it doesnt matter if its plastic or fiberglass the paint will be the same
and the doors are SMC, the fenders are polyurathene, plastic that is yellow is polyurathene, plastic that is black in color is TPO/TPE/TEO/PP/ABS |
11-16-2008, 11:48 AM
#5 | | TECH Fanatic
| abbreveations Quote:
Originally Posted by bdyman it doesnt matter if its plastic or fiberglass the paint will be the same
and the doors are SMC, the fenders are polyurathene, plastic that is yellow is polyurathene, plastic that is black in color is TPO/TPE/TEO/PP/ABS | sorry can't understand abbreveations.
I allways thought that paint on metal fenders looked better thats why top body men never use bondo on metal they use more metal.
I allways thought that paint on rubber bumpers looks crumie (differnt from metal or fiberglass).
I've heard (not here yet) that not all TAs had plastic fenders.
above being said paint will look better on a harder surface right?
?which year models had fiberglass fenders? |
11-16-2008, 12:08 PM
#6 | | On The Tree
| Quote:
?which year models had fiberglass fenders? | bdyman is right.
ive been painting for about 13yrs now and ive never seen anyone try to fix a dent with more metal always bondo, maybe 20+ yrs ago they used lead but rarely any more.
as far as paint on rubber bumpers goes it all depends on what paint you use, and a quick wet sand and buff will fix most of it.
ive worked at a chevy dealer for 13yrs and have never seen a fiber-glass fender on a TA or camaro.
and as far as paint looking better on metal that plastic, i would agree that it looks a little better on metal but with enough prep on plastic or fiber glass panels it can look just as good.
__________________ 01 Z28 A4, gm hot cam, ls6 springs, SLP dual dual exhaust and y-pipe, SLP maf, SLP smooth bellows and lid, and too many suspenion stuff to list. |
11-16-2008, 10:13 PM
#7 | | Launching!
| i think you watch to much tv,lol even the best out there use bondo, when i was at chip fooses shop there was a car out there with bondo work on it, todays bondo is water proof, corrosion resistant, doesnt shrink, doesnt bubble
and there not abbreviations that the type of plastic that is out there, types of plastic, TPO/TPE/TEO/ABS/PP/ polyurathene
and the dude above is right, as far as i know the f-bdoies always came with polyurathene fenders |
11-29-2008, 11:10 AM
#8 | | Registered User
| Can you use bondo on a polyurethane bumper I sanded down a couple spots in my polyurethane bumpers a few months ago. I didn't paint them right away (big mistake) and the sun has eaten/shrunk the polyurethane that was showing. Now that I primed them you can see a 1/16 inch deep indent where the spot was sanded. I tried polyurethane repair glue on one of the spots and it just made a mess. Can I use bondo to fair these with? |
11-29-2008, 10:35 PM
#9 | | TECH Regular
| smoking joe, sounds like its just not feathered out well before priming it, hard to tell without seeeing it though |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
