06-22-2008, 10:35 PM
#1 TECH Addict
Garage is empty, add now
code P1637 Any one had this code (P1637 H - Generator L - Terminal Circuit) or would like to give help how to fix it please do
__________________
Chevrolet LS1 Camaro 1999 M6 My FQuick
06-22-2008, 11:21 PM
#2 TECH Resident
It's the red exiter wire on top of your alternator. It doesn't give much slack and may be coming out of the connector. You can get a replacement connector with an extended wire for the lack of slack at the dealership. They might give you one with 4 wires, just cut the ones you don't need. It cost about $25-$30. Get it replaced. I ran the same code for a good while and then it snapped on me and left me stranded.................
__________________
99' BLK T/A
LME LS2 402 ,Scorpion 4150TB, Super Vic EFI, Lucas 42# inj.,EPS 24x/25x .64x/64x 111+4, AFR 225 68cc,FLT LVL 4,Circle-D 4C stall,NGKTR6/MSD Wires,TSP 1 7/8 LT,Custom ORY W/ Flowmaster 3-4 merge-Dynomax Bullit,Hal QA1 Frt shocks,BMR K-member,BMR Subframes,Hotchkis trailing arms,Random Tech. TA,MOSER 12 bolt, 3.73 Gears,Kyowa-Evolve 18x8,18x9 wheels. Patrick G tune= 502rwhp/461rwt........
06-22-2008, 11:30 PM
#3 TECH Resident
__________________
99' BLK T/A
06-23-2008, 07:57 PM
#4 TECH Addict
thanks for the feedback. where can i find this conector. where is its place located in the alternator.
thanks again pal.
__________________
06-24-2008, 01:02 AM
#5 TECH Resident
It's right on top, but you'll have to remove the alternator to get to it.................
__________________
99' BLK T/A
06-24-2008, 04:30 AM
#6 TECH Addict
The connector come with only one wire right ?
I have to cut the wire and connect the new connector right ?
__________________
06-24-2008, 02:42 PM
#7 TECH Addict
forgive me plz my brain switchiz of some times.
__________________
06-24-2008, 11:52 PM
#8 TECH Resident
Quote:
Originally Posted by
Engine_HP The connector come with only one wire right ?
Correct........Just cut and splice and your set................
__________________
99' BLK T/A
06-25-2008, 01:53 AM
#9 TECH Addict
__________________
08-31-2008, 02:46 PM
#10 TECH Addict
Fixed and code is gone
thanks
Dmoney .
im happy now lool.
__________________
09-01-2008, 12:08 AM
#11 TECH Resident
Glad to hear.................
__________________
99' BLK T/A
09-01-2008, 07:04 AM
#12 TECH Addict
it came back
other ideas ?
__________________
09-01-2008, 11:46 AM
#13 Banned
Engine_HP it came back other ideas ?
Read the voltage from that plug to a good ground with the engine running. Should be 10 volts or higher. If it's not getting anything take the pin out of C2 15 and ohm it out to be sure it's not a broken wire.
Please tell me you're not taking the alt off just to get this plug out.
09-01-2008, 04:28 PM
#14 TECH Addict
9000th01ss Read the voltage from that plug to a good ground with the engine running. Should be 10 volts or higher. If it's not getting anything take the pin out of C2 15 and ohm it out to be sure it's not a broken wire.
emmm ok ill scrach the wire and get my AVO meter and connect from the red wire to earth and see what the volts it gives.......
9000th01ss Please tell me you're not taking the alt off just to get this plug out.
loooool i had no other choice. its was hard to get my finger around.......
__________________
09-01-2008, 06:39 PM
#15 Banned
Engine_HP loooool i had no other choice. its was hard to get my finger around.......
I get it from the bottom with a short screw driver under the clip, pops right off
09-02-2008, 07:56 AM
#16 TECH Addict
9000th01ss I get it from the bottom with a short screw driver under the clip, pops right off
Cleaver man....... it didn`t work with me that way.....
it was much harder
__________________
09-20-2008, 09:17 PM
#17 TECH Addict
should i change the red wire from the pcm all the way to the alternator ?
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags 01 , 02 , 1637 , 2001 , camaro , circuit , code , fix , generator , hp , ls1 , ls1tech , p1637 , problems , tuners
Thread Tools Search this Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
