Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac Firebird 1967-2002
Old 11-12-2008, 08:18 AM   #1
95TAGary's Avatar
Trader Rating: 3
Default 98 WS6 vs 02 WS6
I'm looking to buy a 98 or 99 WS6 over the Winter and wanted to know if there's a difference in the 98 vs 02 WS6 as far as LS1 power or suspension or anything else that's important? I have a 95 but wanted a LS1 to mod. Don't know a lot about LS1's but would like to have more power. Has the Ls1 engine changed during 98-02? Thanks
__________________
"Custom 1995 TA Vert"
http://www.fquick.com/95TAGary
95TAGary is offline   Reply With Quote
Old 11-12-2008, 04:21 PM   #2
WS6 Rampage's Avatar
Trader Rating: 2
Send a message via Yahoo to WS6 Rampage
...You can do a search on this. Its been spoken about in several threads already. There are a few differences but nothing huge in the power department. Biggest differences (if not only) would be the use of the LS6 intake and a slightly smaller cam in 01-02s as opposed to the LS1 intake and standard cam in the 98-00s. I think the power bump is a meager 10-15 advertised hp. ... Personally, from what others have said I'd stay away from the 98. Nothing but problems from what I've heard. Plus, the 98 heads are an inferior design to the 99-02 heads.
__________________
_____The MILK-MAN's Chariot_____
Don't forget to Drink and Drive this Holiday Season!
WS6 Rampage is offline   Reply With Quote
Old 11-12-2008, 04:46 PM   #3
TheBlueKnight's Avatar
Trader Rating: 1
Send a message via Yahoo to TheBlueKnight
What he said ^^^^ Plus the 01'/02' cars got rid of the EGR, have an improved starter, have the upgraded LS6 hydrualics, and LS6 clutch which had 25% more clamping power than the pre 01' f-bodies. And as stated, 1998 trans ams are harder to find a tuner for.
__________________
2000 WS.6 M6 (Ported TB l SLP Lid l K&N Filter l Magnaflow CB)
Soon to come...LS6 Intake, SLP Long tubes and a Tune!
TheBlueKnight is offline   Reply With Quote
Old 11-12-2008, 06:34 PM   #4
1FASTBIRD's Avatar
Trader Rating: 12
Send a message via Yahoo to 1FASTBIRD
If I was you I would just go with a 01 or 02 because then you don't have to worry about the EGR tube that goes into the intake... Also I think cam thing is overrated as more then likely you will upgrade it anyway....
__________________
[QUOTE"So let me get this straight....your new Civic has 1.6 liters and my bottle of Mountain Dew has 2?" QUOTE]
For The Best Deal's And The Sickest Kit's Click The Link!!!!!
http://img135.imageshack.us/img135/4...500x100mj0.jpg
1FASTBIRD is offline   Reply With Quote
Old 11-13-2008, 01:26 PM   #5
Trader Rating: 0
Quote:
HP rating is only 5hp higher on the '01-'02 than the '98-'00 f-bods (305 vs 310 on Z28, Formula, T/A, 320 vs 325 on SS, WS6).
I don't think the '98s have had any significant problems vs the later years. True, the '98 requires a different tuner. But the only difference in the head design is a different cover bolt pattern (combustion chamber is the same), no way is that "inferior". Fuel injectors on the '98s are larger than '99+. Also, the '98-early '00 WS6 suspension contains more upgraded 1LE parts than the later '00-'02s (it was softened down a tad). And all the LS6 hydraulics in the clutch are a wash if you get an A4. The stock '98 WS6 SOTL exhaust flowed better than the '99+.
__________________
Johnny B - '98 Triple-Black WS6 'Vert - 6M - ASC#3030 (1 of 339)
DGM C/F Speedster Tonneau, Pro 5.0, HPP3, MTI C/F Lid & K&N, 160 T-stat, KBDD SFC, BMR STB
Custom 'Vert Sub-box (PM me for info)
JohnnyBs98WS6Rag is offline   Reply With Quote
Old 11-13-2008, 05:19 PM   #6
JD_AMG's Avatar
Trader Rating: 0
Quote:
Read all the stickies:
JRP's FAQ For Commonly Asked Questions
__________________
'01 WS6 M6 : SLP Lid, SB, flowcrapper, 160*, Lou's short stick, STB, Koni SA(4/3), Strano 35/22mm sway bars, Strano springs, more mods comming...
JD_AMG is online now   Reply With Quote
Old 11-13-2008, 05:43 PM   #7
jp74's Avatar
Trader Rating: 2
Yeah the stickies will give you all the info you are looking for. Not much difference at all. I have had a 98 for 3 years with zero problems and I run in the 11's without nitrous. Hopefully you can find a LS1 that has been well cared for, that is the more important. I bought my 98 for 7500 dollars with 56k on the clock. I was looking at a 2002 with 40k and they wanted 14500 at the time. I saved the 7000.00 and put some of it toward mods. Good luck
__________________
1998 Pontiac Formula Firebird
It's stock...ok I have a lid.
1991 Firebird 305... SOLD
1997 Trans am WS6... SOLD
DD- Mazda 626 v6 5spd
http://www.fquick.com/garages/Pontia...la/1998/14297/
jp74 is offline   Reply With Quote
Old 11-13-2008, 07:12 PM   #8
DVS99TRANS's Avatar
Trader Rating: 7
Well just to give you an idea of how they respond to mods. My plain jane 99 and 01 WS6 where dynoed with SLP Loudmouths only. My 99 put down 317whp/327wtq and my WS6 put down 309/320 on the same exact dyno with the same atmospheric conditions. They will make the same power and if you can catch a hell of a deal on a plain jane TA/Z28. You have to figure the intake manifold/clutch and hydraulics/air inlet(no lid) are better on the WS6. If you plan on big power, you'll end up swapping out the better parts that come on the 01 and 02 models. Just some food for thought.
__________________
1999 BLACK TA M6-MS3(114LSA)-PRC 5.3s-SSI built T56-S60w/4.10
2001 RED WS6 M6 #6101 -309whp/320wtq
2008 Black Trailblazer SS-RWD/daily driver
DVS99TRANS is offline   Reply With Quote
Old 11-14-2008, 04:51 PM   #9
2000Hawk's Avatar
Trader Rating: 2
I would shoot for 01-02 like everyone else has stated. LS6 intake manifold is a plus, especially when you have added a few bolt ons. The newer version slave cylinder is also a huge plus. Also the '01-'02 cars had the stronger connecting rod bolts from the factoty i believe. That and im sure you can find a low mileage LS1 for a very nice price. Not saying theres anything wrong with the '99 and '00, mine is a '00 and its great. But if you got the money then you might as well settle for the years that had the better factory equipment. The 98 were the first model year with the LS1 so they are prone to having more problems than other years. Nothing wrong with them either, but just so you don't go crazy when things are acting up.
-Joel
__________________
2000 Pontiac Trans Am WS6 - Black/Black
ASC# 132 of 8,421
2000Hawk is offline   Reply With Quote
Old 11-15-2008, 07:08 AM   #10
Bird Man's Avatar
Trader Rating: 0
Find an 02 --it's the last year model.
__________________
2002 Trans Am WS6 #5527
1st Place 2002 Trans Am Nationals Heavy Modifed
2nd Place 2004 Trans Am Nationals Heavy Custom
1st Place 2006 Great Lakes Firebird Gathering
3rd Place 2008 Trans Am Nationals Heavy Custom
C DAVE GO
http://community.webshots.com/user/silverbird43551
www.fquick.com/TheSilverSurfer
Bird Man is offline   Reply With Quote
Old 11-16-2008, 05:33 PM   #11
Texastransam's Avatar
Trader Rating: 4
My '98 is great! of course the GM crate LS6, two paint jobs, a new interior, suspension, wheels, hood, and other stuff helps. Yeah, maybe you should find a 2002.
Texastransam is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Speed South
LM Performance
Performance Oil Technology
Spohn Performance
American Racing headers
SLP
Patriot Performance
Midwest Chassis
Exotic Performance Plus
Advanced Induction
TomZ Wheels
Cunningham Motorsports
Maryland Speed
Wolfe Racecraft
Vengeance Racing
Speartech Fuel Injection Sys
CarsDirect
Redline Goods
Faster Proms
Tropi-Care
Nitrous Oxide Systems
TT Performance
WS6 Store
Straightline Performance
Century Transmission
West Coast Cylinder Head
PerformaBuilt Transmissions
Finish Line Performance
Quick Time Performance
Livernois Motorsports
Lonnies Performance
Air Flow Research
Trifecta Performance
Mast Motorsports
Race Proven Motorsports
Strano Performance Parts
Pavlock Performance
Total Engine Airflow
Racetronix Fuel Systems
Rapid Motorsports
Specialized Stainless
Competition Clutch
Late Model Engines
LG Motorsports
Auto Parts Firm Online
VFN Fiberglass
Late Model Racecraft
ByunSpeed
BMR Suspension
Finish Line Transmissions
Katech Engine Development
Discount Tire
Forced Inductions
MPH Motorsports
World Products
Burkhart Chassis
Speed Engineering
Yank Torque Converters
Scoggin-Dickey Parts Center
Tick Performance
Slowhalk
Nitrous Express
Speed Tweekerz
Painless Performance
Afterthoughts Auto
Circle-D Converters
Cartek Racing
Harris Speedworks
UMI Performance
Madman Racing
Kee Audio
Futral Motorsports
G-Force Motorsports
Car Shop Inc
New Era Performance
Performance Auto Fabrication
LSx Tune
School of Automotive Machinists
SJM Manufacturing
Nano Nitrous
Full Throttle Speed
Dyno Tune
Race Engine Development
Xtreme Horsepower
Southern Car Parts
Speed Inc.
Texas Speed & Performance
Nitro Dave's Nitrous Outlet
Canadian Performance
Nasty Performance
Kooks Custom Headers
Fast Toys
Diablo Sport
EFI Alchemy
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
