Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac Firebird 1967-2002
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-27-2009, 01:21 PM   #621
RealLiveMD's Avatar
Trader Rating: 0
Quote:
Originally Posted by Danny2tek View Post
Swap your modules around and see if the problem know goes to your passenger side.
where are the headlight module
RealLiveMD is offline   Reply With Quote
Old 10-27-2009, 03:47 PM   #622
FBodyPerformer's Avatar
Trader Rating: 8
Send a message via AIM to FBodyPerformer
Im trying to do the temp fix, I have it all the way down to the motor, but I cant get the black cover off the motor. Its completely sealed together, and unlike that video, I cant just slip a srewdriver in and just pry it apart. Ive already sent the screwdriver into my hand trying Any suggestions?
__________________
'02 WS6 M6
ASC #2803 9/5/01
Bolt-on 364rwhp 371tq
FBodyPerformer is offline   Reply With Quote
Old 10-27-2009, 11:24 PM   #623
Danny2tek's Avatar
Trader Rating: 1
Send a message via AIM to Danny2tek
Quote:
The two thin boxes mounted by the fuse boxes
__________________
[1999 Trans Am]
MTI Clear Lid,Pacesetter LT's with ORY,LS6 intake,Janzter TB,
Strano springs,UMI suspension,TTII's 17x9.5/17x.11,WS9 hood
Problems with your headlight?... READ MY STICKY!!
Danny2tek is offline   Reply With Quote
Old 10-27-2009, 11:25 PM   #624
Danny2tek's Avatar
Trader Rating: 1
Quote:
If your doing the "TEMP" fix you don't have to remove the gear cover.
__________________
[1999 Trans Am]
Old 10-28-2009, 10:45 AM   #625
Jersey Mike's Avatar
Trader Rating: 4
It looks like you posted this yesterday, so this may be too little too late, but you can just unattach the swing arm from the motor, then turn the 'knob' on the top of the motor until it has rotated 180*, then slide the swing arm back on. Voila.
Good luck.
Jersey Mike is offline   Reply With Quote
Old 10-28-2009, 01:29 PM   #626
Trader Rating: 8
Quote:
Good luck.
Yaaa, just a lil too late lol sent a screwdriver into my hand, thats nice. broke the motor cover. Cant align it right. I didnt even think about the knob at the top. Goin to pick up a new motor
__________________
'02 WS6 M6
ASC #2803 9/5/01
Old 11-02-2009, 06:05 PM   #627
Paul Bell's Avatar
Trader Rating: 4
Default 99 T/A headlights screwed up
The headlights on my 99 T/A are all messed up. With low beams on, all four lamps are lit but at ½ brightness. It’s certainly a ground issue but before I spend hours on a wild goose chase, can somebody point me in the right direction as to where’s the best place to start?
__________________
-1999 Trans Am A4, 2.73 rear, ZR1 wheels 17 X 9 & 17 X 11, UMI front end EVERYTHING, SSBC 13" 4 piston stoppers, truck coil conversion.
-71 Monte Carlo SS454 496 CID, 600HP
Paul Bell is offline   Reply With Quote
Old 11-03-2009, 01:06 PM   #628
Danny2tek's Avatar
Trader Rating: 1
Quote:
The harness underneath the headlights tends to develop serious corrosion. I would start there.
__________________
[1999 Trans Am]
Old 11-03-2009, 07:12 PM   #629
Paul Bell's Avatar
Trader Rating: 4
Thanks Danny, I'll start there.
__________________
Old 11-07-2009, 08:42 PM   #630
Danny2tek's Avatar
Trader Rating: 1
Well my Autozone replacement motor just stripped, not even a full year
__________________
[1999 Trans Am]
Old 11-09-2009, 09:31 PM   #631
Trader Rating: 0
I have a 95 Trans Am. It does the whole grinding thing when you turn the headlights off, but the passenger side light will not pop up all the way. If you wiggle the headlight it will move up and down but will not stay up. I have tried to manually raise the light, but every time I turn them off it goes back to the way it was before. Any ideas on how to fix this problem?
RyanBum is offline   Reply With Quote
Old 11-17-2009, 11:12 AM   #632
Mid
Mid's Avatar
Trader Rating: 0
Tell me about it. I'm probably on my 3rd from Orielly's.
Also, is there another solution rather than using black electrical tape around the arm? It slowly slips off, and causes issues.
__________________
2002 WS6 M6 #10975
MSD Wires, !AIR, Pacesetter LTs, TSP Y-Pipe, Hooker Catback, SLP Lid, SLP STB, BMR Extreme Race Rear Sway Bar, BMR Tubular LCAs, BMR Boxed SFCs
Mid is offline   Reply With Quote
Old 11-17-2009, 11:56 AM   #633
1999 Pontiac Trans Am
99'CajunFirehawk157's Avatar
Trader Rating: 26
Default Bought a new motor too...
Replaced a gear in one about a few months ago, then it started again, bought a new gm motor, all quiet again.
__________________
Click pic to see my F-Quick Garage
Click here to see My LS1Tech garage
www.cruisinthecoast.com
99'CajunFirehawk157 is offline   Reply With Quote
Old 11-18-2009, 04:25 PM   #634
homerunhtr21's Avatar
Trader Rating: 17
I just replaced both motors in my firebird. When I went back to assemble the headlight in the car I got everything bolted back up where it was supposed to be and tightened everything up. When you pull up on the headlight cover with the lights off they will come up probably half walf even with the car off. When I try to turn the lights off/on nothing happens. Brand new gears and You can see the motor turning but it just keeps hitting the stoppers. I have tried everything I know of but cant get them to go up/down at all.
Any Ideas?
__________________
02 Z28 Heads/Cam/bolt on/stall/etc...
Sold 00 Ws6 Cam/bolt on/stall..etc
homerunhtr21 is offline   Reply With Quote
Tags
1979, 1995, 2002, 79, 84, 98, adjustment, dont, door, firebird, fuse, gear, grinding, head, headlight, headlights, light, module, motor, motors, noise, numbers, pontiac, problems, protouring, rebuilt, reset, tranam, trans, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
