Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac Firebird 1967-2002
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 01-29-2006, 02:10 PM   #61
Danny2tek's Avatar
Trader Rating: 1
Send a message via AIM to Danny2tek
have you checked the fuse for that side headlight?
__________________
[1999 Trans Am]
MTI Clear Lid,Pacesetter LT's with ORY,LS6 intake,Janzter TB,
Strano springs,UMI suspension,TTII's 17x9.5/17x.11,WS9 hood
Problems with your headlight?... READ MY STICKY!!
Danny2tek is offline   Reply With Quote
Old 01-30-2006, 07:16 PM   #62
Trader Rating: 0
yea.. i checked the fuse and it was good...and there isnt any sounds comin from the motor...so i guess its the motor?
kliuzzo is offline   Reply With Quote
Old 01-30-2006, 07:38 PM   #63
Danny2tek's Avatar
Trader Rating: 1
take of the connector going to the motor and have someone turn on/off the headlights and see if you have voltage (using a vom) if you have +12 its time for a new motor.
__________________
[1999 Trans Am]
Old 01-30-2006, 10:18 PM   #64
TNTramair's Avatar
Trader Rating: 8
Send a message via AIM to TNTramair
Quote:
or... take the connector off the headlamp control module, fine the two pins that control the passenger side, one is a ground and the other power...run two wires from those pins, one to ground, the other just tap a 12 volt source (positive battery terminal), if the motor pops up, than you have a bad control module...if it doesnt, switch the wires around and try it again...if it still doesnt work, than you'll have to go to the connector at the motor and do what was said above to condem the motor itself...hope this helps...goodluck.
__________________
2000 Trans Am Ws.6 M6 402TT
1999 Formula M6 Hardtop stock
GO BIRDS!
TNTramair is offline   Reply With Quote
Old 01-30-2006, 11:40 PM   #65
Trader Rating: 0
u wont be believe this shit...i was just messin around lookin at the headlight motor, just tryin to figure out whats wrong with the headlight..and i just flipped the switch and out of no where it started to work. I tried it several more times and it still is workin.. I guess it was a pinched wire or something. thank god cause tomorrow i was gonna take the motor out..
Old 01-30-2006, 11:54 PM   #66
Danny2tek's Avatar
Trader Rating: 1
check for some corrosion in the connector
__________________
[1999 Trans Am]
Old 02-01-2006, 02:14 PM   #67
Trader Rating: 0
yea i spoke to soon...it failed on me last night..checkin for corrosion today
Old 02-08-2006, 09:25 AM   #68
Danny2tek's Avatar
Trader Rating: 1
any updates?
__________________
[1999 Trans Am]
Old 02-09-2006, 07:16 PM   #69
Trader Rating: 0
its gotta be a loose wire. its been workin for awhile now. lol but as soon as i got the one to work..my other bulb blew out
Old 02-09-2006, 08:21 PM   #70
Danny2tek's Avatar
Trader Rating: 1
damn!!!
__________________
[1999 Trans Am]
Old 02-14-2006, 10:10 PM   #71
nomadnate's Avatar
Trader Rating: 0
i did this on both my headlights today. but found a faster way. if you raise the headlight and remove the headlight bezel. then remove the motor shaft retaining nut (probably the rustiest one lol). !do not remove the actuator arm! lower the headlight. remove the 2 hinge bolts they are torques heads with 10 mm nut on them. have someone hold the loose light assembly up while you raise the light assembly. use a flat head screwdriver to pry the actuator arm off of the motor shaft. remove the headlight assembly. use the manual nob that raises the headlight to turn the gear 180 degrees. put it back together in reverse order. this shortcut is not for those that are not use to trying the faster way. i just did this to save time but it worked really good.
__________________
2000 Pontiac Firebird Formula WS-6 M6
lid, pacesetter long tubes and tsp true duals w/sweet thunders, custom tune, smooth bellows, descreened maf, bbk throttle body, ls6 intake 355 rwhp and 367 rwtq
1968 Ford Galaxie Fastback 302
nomadnate is offline   Reply With Quote
Old 02-21-2006, 04:32 PM   #72
Trader Rating: 0
im still havin problems with my headlight...when i raise it myself and wiggle the wires around the headlight works... but after a day or so it stops workin again. Could it be anything else besides the connections. And if its the connection how do i change it and where can i buy it
Old 02-27-2006, 01:27 PM   #73
B-MAN's Avatar
Trader Rating: 0
I got so sick of dealing with headlight problems, that I got a conversion kit for my car.
I think it looks better, and I haven't had any problems in the tree years I've onwed this kit.
trans-am-headlights-all-comments-questions-regarding-headlights-go-here-boris-launching.jpg
__________________
B-MAN
2001 White Trans Am
Motor by Eastside & Noyzee Racing.346cubic inches,TH400,mosier 12 bolt,QA1 suspension
576RWHP on a conservative tune & a 150 shot.
10.41@ 129.8mph & 1.53 60' time
2008 Black Cadillac CTS daily driver
2007 Silver Pontiac G6 GT coupe
B-MAN'S WEB SITE
http://img.photobucket.com/albums/v626/Sprspt/BmanNewsig.jpg[/IMG]
B-MAN is offline   Reply With Quote
Old 03-19-2006, 10:03 PM   #74
blackbirdls1's Avatar
Trader Rating: 4
Send a message via AIM to blackbirdls1 Send a message via MSN to blackbirdls1
how long do these headlight motors usually last?
__________________
2001 Black Formula
blackbirdls1 is offline   Reply With Quote
Old 03-19-2006, 10:51 PM   #75
Danny2tek's Avatar
Trader Rating: 1
Quote:
Which ones the stockers or the brass ones?
__________________
[1999 Trans Am]
Old 04-01-2006, 03:15 AM   #76
98BlackTransAm's Avatar
Trader Rating: 0
Send a message via AIM to 98BlackTransAm
just wanted to say thanks for the "quick fix" tip. i had that grinding headlight problem when it went down so i turned the gear 180 degrees (did this about a month ago) and it's worked perfectly ever since. hopefully it'll last for a while.
__________________
1998 Pontiac Trans Am (A4)
slp lid, pacesetter lts, ory, flowtech cutout, fuddle 3400 stall, B&M tranny cooler
98BlackTransAm is offline   Reply With Quote
Old 05-13-2006, 10:01 PM   #77
Trader Rating: 0
WD40 is fine and works great. Don't worry about rust. Its not that serious of a worry to only spray 2 spots. If it wanted to rust, it would be by now.
peteTA is offline   Reply With Quote
Old 05-19-2006, 02:00 PM   #78
Teebird's Avatar
Trader Rating: 0
Default headlight headache
I have a 1982 Recaro Trans Am. My headlights will go down just fine but they wont go up at all. If my motors work to close them but not to open them, can my motors still be bad? I have changed the headlight isolation relay but nothing changed.
Anyone had this problem before?
Teebird
Teebird is offline   Reply With Quote
Old 05-21-2006, 01:27 PM   #79
ACW
ACW's Avatar
Trader Rating: 0
Teebird
Hm. Have you seen the 3rd-gen section at the bottom of bfranker's page? http://www.bfranker.badz28.com/headlightfix/index.htm
That may not be what your problem is, but thought it's worth a look...
Quote:
3rd Gen Headlight Fix
1982 to 1992 Firebirds and Trans Ams
The bad news for you 3rd generation Firebird guys (1982-1992) is that I won't be offering brass gears for you guys. Now, the good news is that 99.9% of the problems associated with headlight problems for you guys is NOT related to the nylon gear failure! You guys are fortunate in that your problem can likely be fixed with less than a buck's worth of supplies from a common place such as Home Depot or any hardware store.
In the 4th gens, the shaft which turns to raise and lower the headlight is connected to the gear via a rubber piece which sets in the gear itself or, in the case of my brass gears with no rubber, the shaft is actually connected via tabs to the brass gear. In the 3rd generation Firebirds, this actual physical connection doesn't exist. Instead, in each light are located three hard "pucks". These pucks provide the mechanical connection between the nylon gear and the shaft which raises or lowers the headlight. Over time, these pucks will actually disintegrate into small granules and dust! The very good news for you guys is these pucks are nothing special. You can use just about anything you can get your hands on that is the proper size and will fit in the areas these three pucks "used" to be located at. I recommend using a thick rubber hose or tubing of the proper diameter and length (1/2" outside diameter and about 1/2" in length) but I have heard of one guy who didn't want to go out and buy anything but had a hot glue stick laying around so sliced off some pieces of that instead! I don't recommend that though since I don't know how long the glue stick will last in there Instead, slice three 1/2" pieces off your hose/tubing and drop them in place where your pucks used to be located. Once you do this you can put your light back together and you'll be good to go! Total cost for this fix is about $0.12 or there abouts
ACW is offline   Reply With Quote
Old 06-08-2006, 01:32 PM   #80
Trader Rating: 0
Default headlight problem
I have an 01 trans am...when I engauge or disengauge keyless entry headlights come up then down and make a roaring noise . The noise only comes from left headlight drivers side? Both lights come up though! Any idea? Is it the same thing I am seeing here about gears?
Thanks,
Tiffany
__________________
04 Yukon
Appearance 2/3 Drop on 20's, Escalade Running Boards, Escalade Roof Rack, Escalade Third Brake Light, Cowl Hood, Three piece Engine Covers Painted to match, Denali Projector Headlights, Truck Master Designs Front Air Dam, APC LED Tail Lights, Billet Grill
Performance Corsa Touring Exhaust, PaceSetter Long Tubes, and anything else you guys decide to spend my money on!
Yukon Pics
06 Roadglide The real Toy! Hi Flow w/Screaming Eagle Pipes, Road Tested to 120mph.
04Yukon is offline   Reply With Quote
Tags
1979, 1995, 2002, 79, 84, 98, adjustment, dont, door, firebird, fuse, gear, grinding, head, headlight, headlights, light, module, motor, motors, noise, numbers, pontiac, problems, protouring, rebuilt, reset, tranam, trans, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
