10-18-2008, 06:11 PM
#1 | | registered user
| Baselined the G8 at the track today. I got my G8 to the track today. Approximately 750 miles on it when I got there. Very nice day, around 50 degrees, little wind. I made 3 passes which looked like this:
1: I decided to leave it in D for the first pass. I did a very brief spin of the tires to clean them and lined it up. I stalled it to about 900 rpm and hit it on the last yellow.
60'......2.17
330'....5.83
1/8.....8.88
mph....81.38
1000'..11.49
1/4.....13.68
mph....102.15
The car seemed to be shifting into 4th as I was crossing the finish (stock shifts are lazy).
2: I started in sport shift mode and tried the 3rd gear trick. Same on the burnout as the first pass. I left off idle. When I hit the gas it felt like it spun a little and the pass looked like this.
60'......2.13
330'....5.84
1/8.....8.92
mph....80.79
1000'..11.54
1/4.....13.74
mph....102.68
The car stayed in 3rd when I requested it to shift back to second (the trick to keep it from shifting to 4th as it crosses the finish). It stayed in 3rd and my mph picked up slightly, but my ET was a tiny bit off.
Last run I did a 2 second burnout and staged. I used the 3rd gear trick like on the second pass. I left off idle and it seemed like it spun more this time.
60'......2.04
330'....5.72
1/8.....8.76
mph....81.88
1000'..11.35
1/4.....13.529
mph....102.92
I weighed the car after the last run and it was 3990 lbs without me and the race weight was 4180lbs.
Overall I was very impressed with the car. Very fun day and I can honestly say that the car is a mid 13 second car. It might be a while before the mods start, but now I have a baseline to work off of.
VIDEO: http://www.youtube.com/watch?v=FhEOOVNNjAM
__________________ -1994 Z28, Quasar Blue
A4, Cloth, T-Tops; ZR1 Wheels, Eibach Pro Kit, 3.42 LS1 rear, LS1 driveshaft, 1LE Elbow
Stock: 230 rwhp, 273 rwtq; 14.30 @ 97 mph
-2009 G8 GT, Liquid Red
A6, Leather, 19" Wheels; Stock
13.52 @ 102.9 mph
10-18-2008, 07:43 PM
#2 | | TECH Regular
| not bad.
__________________ www.myspace.com/summerwolfrunem Quote:
Originally Posted by ponygt65 Rollin' in G-T-O slouchin' like a master G homey in LAS VEGAS!!!...Woop Woop. | |
10-18-2008, 10:02 PM
#3 | | !MAF mod by GM
| Great times for a stock 4 door car, I'm leaning more and more towards the G8 as my next daily driver.
__________________ Jon94Z: be like what bitch, lt1 can hold its sauce son |
10-19-2008, 09:08 AM
#4 | | TECH Addict
| very impressive.
__________________ CAMARO SS 12.2@113
SILVER 05 GTO M6
FUTURE 5TH GEN 2010 CAMARO OWNER |
10-19-2008, 11:27 AM
#5 | | TECH Fanatic
| Not bad at all.
Get a tune and an intake on that bad boy and you will easily see low 13's.
__________________ 97 T/A Ram Air Convt - Typical Slow H/C/Nitrous LT1 2008 Pontiac G8 GT - Ignition Orange w/ premium & sport pkg TTP Tuned/Custom Intake/Pypes Axle-Back |
10-19-2008, 03:53 PM
#6 | | Launching!
| Nice runs man, 13.5 is damn quick for a stocker. And with only 700 miles on it you can expect it to get better as she breaks in. Did you go to Englishtown?
__________________ 1998 Jeep Grand Cherokee 5.9 Limited
K&N FIPK, 52mm TB, M1 Intake manifold, 3" catback exhaust with Flowmaster 50 and Carsound cat, Mopar Performance ECU, 2600 stall, ML Headers.
2006 Impala SS- K&N Aircharger, Dynomax Ultra Flo's, flipped motor mount. |
10-19-2008, 04:42 PM
#7 | | registered user
| I ran at Lebanon Valley. I would probably have hit a 13.4 or maybe even a 13.3 at Englishtown or Atco, but it's alot farther and the drive home usually sucks, lol.
13.52 @ 102.9 mph |
10-22-2008, 12:40 PM
#8 | | TECH Enthusiast
| So a stock G8 GT will run around a 13.20 @ sea level down here in Florida on a cool night ?I'm going to have to find a place that rents them and try it @ the local track when it reopens on Nov.8 all brand new. |
10-22-2008, 01:37 PM
#9 | | 11 Second Club
| Quote:
Originally Posted by blk/slvr02ss So a stock G8 GT will run around a 13.20 @ sea level down here in Florida on a cool night ?I'm going to have to find a place that rents them and try it @ the local track when it reopens on Nov.8 all brand new. | I don't know about that, I suppose it's possible. Atco is one of the fastest tracks in the country, if not the fastest I've seen, and I would guess ScreaminRedZ would have hit a 13.3-13.4 at Atco on this cold day we hit up LVD. His car is bone stock, straight off the showroom floor. The 13.4 would have happened, 13.3 definitely possible, 13.2 unlikely but I guess not impossible.
Then again we didn't go there, we went to LVD, so the 13.52 is what's currently on the best timeslip. Definitely post up your results if you do get one to the track.
__________________ Disclaimer: All street racing stories posted by me are ficticious. |
10-22-2008, 03:15 PM
#10 | | TECH Enthusiast
| I was told the lower you go in elevation the lower you times are the higher you go in elevation the higher your times are.So if that is true then its good for a few tenths. |
10-22-2008, 10:39 PM
#11 | | Launching!
| Pretty damn quick for a stock 4 door if you ask me. Get a couple mods on that thing and take it back.
__________________ |
10-23-2008, 09:34 AM
#12 | | TECH Senior Member
| Quote:
Originally Posted by blk/slvr02ss I was told the lower you go in elevation the lower you times are the higher you go in elevation the higher your times are.So if that is true then its good for a few tenths. | The # that matters is what is called.
Density Altitude. or DA
Thats calculated based on the actual eleivation, air temp and humidity, its a guage to tell how good the air quality is.
Atco is know for having the best in the north east and also the track prep is pretty darn good. Followed closly by E-town and then from there LVD is dead last in the DA dept. At best before LVD will show down for this year, we hit a best of -85 last Saturday. Most times in the fall its between 100-400. The actual elevation I think is 600ish feet.
Atco is at or just below see level. A Major advantage.
Ron's G8 will post a big # at Atco, id bet that anyday a week. http://en.wikipedia.org/wiki/Density_altitude (good example) http://www.pilotfriend.com/calcs/cal...rs/density.htm (example of a calculator)
__________________ 2002 Navy Blue Metallic Trans Am.
Vengence Racing VRx4 Cam, Ported 90/90, SLP Flow Pack, SLP U/D pulley, Dynatech SuperMaxx, Corsa, Textralia Oz-700 Z-grip, Moser 12 Bolt w/ 4.10's, 3" Steel DS, Tick Perf. Adjustible Master Cyl. and BMR Suspension.
12.339 @ 112.1 w/ 1.759 60' Pull both wheels! |
10-23-2008, 12:13 PM
#13 | | 12 Second Club
| wow that is fast, best I pulled out of my GTO was a 13.4 stock.
__________________ 06 GTO 457wrhp 421torque AFR 205's hellraiser comp cam, 1 7/8th kooks long tubes, catless mids, spintech catback, underdrive pully, MT's, Textrallia OZ700 clutch and GMM Rip Shifter, BMR Drag bags, BMR safty loop, Braided clutch line, Ling fuel pump, oil catch can, Lucus 42lb injectors...
On order: Fast 92 full port & TB
To come by spring, full race 8.8 with axles, stubs, shafts, and driveshaft.
Best e.t 12.35 @ 114.4mph with a 1.87 60, |
10-23-2008, 12:21 PM
#14 | | TECH Regular
Join Date: Apr 2008 Location: Delaware?/South Carolina:)
| Thats damn good for a heavy 4 door. Get a tune to firm up those shifts and a cai for a few more ponies and tell us how you like low 13s.
__________________ M6 06 GTO with the RaceProvenMotorsports mod |
10-23-2008, 11:20 PM
#15 | | TECH Resident
| damn fine runs for a stocker. Id love one for a DD, looked at the 6 cyl for the wife, well see...
__________________ 99TA - Terrmy Heads / MS3 / 90-90 / Full Exhaust / Suspension / DLS 9" / TNT F1 / Fikse FM-5's ![[SIGPIC]](http://www.ls1tech.com/forums/image.php?u=50228&type=sigpic&dateline=1227223309)
06 Kawi ZX10r -Yoshi carbon cans / Fren Tubo stainless steel lines / Vesrah pads |
10-24-2008, 12:05 AM
#16 | | registered user
| Thanks!
99WS7, I'd just go for the V8. It's only like $2000 more and only gets 1 mpg less on the highway.
Link added for video.
13.52 @ 102.9 mph |
10-24-2008, 11:31 AM
#17 | | TECH Regular
| So when do you think your gonna start modding it?
10-24-2008, 11:30 PM
#18 | | registered user
| I'll probably wait until after next season. I want to start now, but I have things I want to do to my other cars and it makes sense to start with the cars that don't have a warrantee.
13.52 @ 102.9 mph |
11-08-2008, 08:29 PM
#19 | | 11 Second Truck Club
| Quote:
Originally Posted by 99WS7 damn fine runs for a stocker. Id love one for a DD, looked at the 6 cyl for the wife, well see... | I agree good runs too!
Was that a mistype about the 6 cyl? I would expect my wife to possibly leave me if I brought her home a 6cyl G8.
Actually, maybe not but she would schedule me a doctor's appointment atleast.
__________________ -02 Chevy 2500HD DMax ECSB 2wd
-00 Formula M6 hardtop (DOC tuned)
-86 C-10 swb |
11-09-2008, 07:23 PM
#20 | | Teching In
| WOW good runs
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
