11-13-2008, 09:52 AM
#1 | | TECH Regular
| Is the G8 going to have a 6 speed Manual or.. is anyone installing a 6 speed?
Thanks. |
11-13-2008, 09:03 PM
#2 | | Launching!
| you'll be able to get the upcoming G8 GXP with a 6 speed
__________________ 1998 Z28:XS LT'S & ORY,KONI SA,STRANO SPRINGS,HAWK HPS,UMI PANHARD & LCA,BREMBO ROTORS,SS BRAKE LINES,SLP LID,K&N,SUPER 40,MSD 8.5,NGK TR55,HPH TUNE 312 RWHP & 328 RWTQ www.fquick.com/ls1der |
11-14-2008, 02:53 PM
#3 | | STF Veteran
Join Date: Oct 2003 Location: Greensboro, North Carolina
| Last I heard, the GT will not get the manual transmission.
__________________ Click my sig for a chance to win. |
11-18-2008, 12:24 AM
#4 | | Teching In
| Stupid of GM to not offer this in manual. If they truly want to compete with companies like BMW (who attracts driving enthusiasts) they need to offer a manual transmission. Hell they are cheaper then automatics anyways.
Decisions like this are the reason American auto companies are tanking |
11-18-2008, 01:20 AM
#5 | | On The Tree
| The reason GM does not offer a 6 speed in the G8 GT is because the L76 V8 has the DoD system. For some reason GM can't get the DoD and the 6 speed trans. to link up correctly. This is exactly why if you get a 6 speed in the 2010 Camaro SS you get the LS3, and if you get the auto you get the L76 engine. The only way you can get a 6 speed in a G8 is to get the GXP, which has the LS3.
__________________ 1996 "Mystic Teal" Pontiac Firebird Trans Am:
PS LT, ORY, !egr, !air, SLP LM2, K&N CAI, 160* t-stat, TB airfoil, Trickflow Elbow. Madtuner tune, etc... |
11-18-2008, 01:45 AM
#6 | | 11 Second Club
Join Date: Mar 2006 Location: Ali AB, Tallil, Iraq Kickin it in the sand..
| G8 models with the M6 are getting the Tremec T6060. |
11-18-2008, 10:26 AM
#7 | | Launching!
| Quote:
Originally Posted by 96tealTA The reason GM does not offer a 6 speed in the G8 GT is because the L76 V8 has the DoD system. For some reason GM can't get the DoD and the 6 speed trans. to link up correctly. This is exactly why if you get a 6 speed in the 2010 Camaro SS you get the LS3, and if you get the auto you get the L76 engine. The only way you can get a 6 speed in a G8 is to get the GXP, which has the LS3.  | Camaro A6's get the L99 engine. But you're right, the G8 GT doesn't come in a manual because the engine had DoD. DoD doesn't work with manual transmissions, the transition between 8 and 4 cylinders isn't smooth enough.
__________________ 98 Camaro SS M6, Hardtop
Lid, MAF, Ported T/B, Underdrive pulley, LS6 intake, TR 224 cam w/ 114 LSA, Pacesetter L/T, Magnaflow cat-back, 3.73's, LS7 clutch w/ aluminum flywheel, STB, SFC, LCA, TA, Panhard rod, BMR springs w/Bilstien shocks. |
11-18-2008, 10:08 PM
#8 | | Registered User
| Interesting |
11-18-2008, 10:17 PM
#9 | | On The Tree
| Quote:
Originally Posted by SS#1531 Camaro A6's get the L99 engine. But you're right, the G8 GT doesn't come in a manual because the engine had DoD. DoD doesn't work with manual transmissions, the transition between 8 and 4 cylinders isn't smooth enough. | That's why the G8 GT should get the the LS3, and the GXP should have either the LS7 or the LSA. lol
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
