10-09-2008, 08:08 PM
#1 | | Teching In
| How can i reset the oil life option??? help hi everyone
can someone plz tell me how to reset the oil life option???
thank u
__________________ 2000 Z28 A4
B1 CAM, LT's, Borla cat back, 3.42 gear, ls6 intake, k&n lid, BBK80 TB. |
10-09-2008, 08:24 PM
#2 | | TECH Senior Member
| It'll be in your cars manual
__________________ 1993 Firebird Formula A4 3.42 Torsen Posi
BBK 58mm TB | 24# SVO Inejctors | Coolant Bypass | Vortec Alu Elbow
Afro Engineering CAI | SLP Catback Dual-Dual | LS1 Rear Brakes | Self Tuned Chip | !EGR !AIR  Soon: Full polyurethane kit, IAT Relocation, "New" tranny w/ 2500 stall. "If your car doesn't run 12's, shorten the track" - Urban (x3Dfx Forum) |
10-09-2008, 08:29 PM
#3 | | TECH Fanatic
| In F-bodies, you just hold down your trip reset button until it flashes.. then you're good for another 5kmiles or whatever it's set for..
__________________ 2000 Silver Bird: W68 Y87, LS1 Swap and Tune by Bluecat |
10-10-2008, 03:01 AM
#4 | | Teching In
| i cant find it in the car manual
the car is a caprice ss 2007 from holden,,, it has the same computer system as the G8.
10-10-2008, 04:02 AM
#5 | | TECH Senior Member
| I'd be really surprised if it wasn't in the manual  What do they expect the do it yourselfer, or a oil change shop? That you take it to a dealer to have it shut off, or buy a programmer to reset it via the PCM? Don't know what car it was, but it was something like floor the gas with the key off, turn it all the way till BEFORE start, turn the key off and I think that then reset it. Could always try it  Or
10-10-2008, 04:22 AM
#6 | | Launching!
| If it's like most of the U.S. version GM's it's pretty simple. 1. with the car off, turn it to the on position (don't start it). 2. Within 5 second of step 1, fully depress the gas pedal to the floor 3 times. You should see the oil life monitor begin flashing telling you it's reset, or the display should read something like "Oil Life Reset"
It should work but It could be different than all GM's I've worked on at the dealership I work at.
__________________ 98 NBM Formula M6
98 Black PowderCoated C5 rims, LS6 Intake, Ported TB, Custom Grind Cam 224/228 .591/.591, LS7 Clutch/Flywheel, Ported LS6 Oil Pump Custum Catback dumped, 918 valvle springs, Manley Pushrods, PaceSetter LT/ORY, Hurst Billet/Plus Shifter, Ws6 Store Short Stick |
10-10-2008, 10:12 AM
#7 | | Teching In
| thank you benner i will try it today and see what happen
10-10-2008, 10:16 AM
#8 | | Teching In
| Quote:
Originally Posted by Formula350 I'd be really surprised if it wasn't in the manual  What do they expect the do it yourselfer, or a oil change shop? That you take it to a dealer to have it shut off, or buy a programmer to reset it via the PCM? Don't know what car it was, but it was something like floor the gas with the key off, turn it all the way till BEFORE start, turn the key off and I think that then reset it. Could always try it  Or  |
nothing in the manual about reseting the computer.
i will try Benner way if it dosent work i will call the dealar
thank u
10-10-2008, 11:42 AM
#9 | | 12 Second Club
| Benners way to reset it is correct. And PS it's in your manual under the iol-life section if I remember right. Don't remember where I found it, but it's in there.
__________________ Ign. Orange, 20% Tint, 19" Zinik Z27 Sofins, American Racing Header System, Powerbond Underdrive Pulley, 160 Deg. Thermostat,Throttle Body Port, NEP Induction, LMS Tune. GRRRR8 CAI Air Flow Mod, GRRRR8 Intake Cover Mod., Mobil 1 Synthetic, K&N Gold Oil Filter, VMS HSRK, NEP 228/240 Cam, 411HP and 383 Torque. 1/4 Mile 12.6841@114.74 MPH. Coming Soon: Pedders Suspension, LMS Stage II Heads and Ported Intake |
10-10-2008, 12:02 PM
#10 | | Launching!
| No problem at all.
10-10-2008, 06:33 PM
#11 | | Teching In
| it worked just as Benner said
i will read my manual again and see if i can find it
thank you again
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
