Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac G8 2008-2009
Old 10-10-2008, 03:07 PM   #1
dry_kill's Avatar
Trader Rating: 6
Send a message via AIM to dry_kill Send a message via Yahoo to dry_kill
Default G8 v8 question
i am looking for a engine for my truck and a buddy of mine said he found a v8 from a 08 pontiac G8, i was wondering if these engines were the same specs as say a ls1 and what not. because i know ls1, ls2, lq9, so on and so forth will fit in a silverado no problem, just not sure about this G8 engine. thanks fellas
__________________
02 gmc, rocking the dumped flowmasters!!!!!
dry_kill is online now   Reply With Quote
Old 10-10-2008, 03:37 PM   #2
.Gearhead.'s Avatar
Trader Rating: 0
It's an L76. Basically a detuned LS2. Same bore and stroke with some differences like active fuel management, variable cam phasing, and detuned to utilize 87 octane.
.Gearhead. is offline   Reply With Quote
Old 10-10-2008, 03:49 PM   #3
Johnnystock's Avatar
Trader Rating: 2
its more potent than the LS2 cause you have the L92 head stock on it!!! Flows over 300cfm stock!!Mod potential is crazy..
__________________
1998 SS
juiced H/C/I
Johnnystock is offline   Reply With Quote
Old 10-10-2008, 04:23 PM   #4
Trader Rating: 0
Yes, it's a very builable motor and even removing the DOD you can still retain decent mileage. I'm at 22-24 HW and 18 city. Not bad for over 400HP at the wheels.
__________________
Ign. Orange, 20% Tint, 19" Zinik Z27 Sofins, American Racing Header System, Powerbond Underdrive Pulley, 160 Deg. Thermostat,Throttle Body Port, NEP Induction, LMS Tune. GRRRR8 CAI Air Flow Mod, GRRRR8 Intake Cover Mod., Mobil 1 Synthetic, K&N Gold Oil Filter, VMS HSRK, NEP 228/240 Cam, 411HP and 383 Torque. 1/4 Mile 12.6841@114.74 MPH. Coming Soon: Pedders Suspension, LMS Stage II Heads and Ported Intake
MANOFSTEEL69 is offline   Reply With Quote
Old 10-10-2008, 08:13 PM   #5
dry_kill's Avatar
Trader Rating: 6
so i can just bolt it straight in to a 02 sierra? are there any type of wiring issues i would have to deal with? only thing i know i would have to change is the accesory brakets
__________________
Old 10-11-2008, 01:06 AM   #6
goober35's Avatar
Trader Rating: 1
Send a message via AIM to goober35
from what i hear you are gling to have to change the lifters. Hopefully someone will chime in and confirm this. I am an LS1/2/6 guy im not to hip on these motors.
__________________
Goober
Current ride 03 Dodge Smarty, Silverline SS 4in, willy's 6in intake, and 62/14 turbo
99 Trans Am.
Baskett Case Psycho Racing Forged 370 9.1CR w/ a little bit of spray.
SDPC LS6 66cc 2.00/1.55 heads w/ ms3
M6 and Twin disk.
Budget?? what the hell is that.
1/4 10.8
goober35 is offline   Reply With Quote
Old 10-12-2008, 09:21 AM   #7
HSV-GTS-300's Avatar
Trader Rating: 0
Quote:
It's an LS2 block (same size externally as LS1) and LS1 accessories will bolt on. It does not have variable cam phasing. It has a small .480" lift cam with a special AFM lobe set-up, 8 DOD lifters and 8 normal lifters. L92 heads,LS3 90mm intake, LS7 injectors, 90mm electronic throttle body.
It runs the same crank balancer as LS2 Corvette with corvette belt spacing away from the block.
Crank reluctor wheel is 58x (LS1 is 24x), Cam gear is 4x (LS1 is 1x).
To run it off an LS1 computer you'd need to drop the crank out to change the reluctor wheel to 24x, pull the cam (its a single bolt core) replace with a 3 bolt core so the new 1x cam gear will fit.
You'd also need to pull the heads to remove the DOD lifters.
Fit an LS2 valley cover to remove L76 DOD solenoids and blank off.
You'd need...Cam sensor harness extension,knock sensor extension harness, MAP sensor adapter harness, injector adaptor harnesses. 90mm cable TB...or an adapter harness if your truck runs 75mm ETB to suit 90mm ETB.
You'd be looking at about $2k in parts to make it suit an LS1 application.
HSV-GTS-300 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Auto Parts Firm Online
Car Shop Inc
Katech Engine Development
Six Speeds Inc.
Maryland Speed
Nasty Performance
Century Transmission
WS6 Store
Vengeance Racing
Forced Inductions
SJM Manufacturing
Trifecta Performance
Canadian Performance
Finish Line Transmissions
Midwest Chassis
ByunSpeed
Advanced Induction
Speed Inc.
Yank Torque Converters
Race Engine Development
Redline Motorsports
PerformaBuilt Transmissions
Xtreme Powersports
Comp Cams
Late Model Racecraft
Painless Performance
Harris Speedworks
UMI Performance
Texas Speed & Performance
Kooks Custom Headers
Performance Auto Fabrication
Speed Engineering
Lonnies Performance
Rapid Motorsports
Redline Goods
HP Tuners
Specialized Stainless
Livernois Motorsports
Edelbrock
Burkhart Chassis
Pavlock Performance
Fuel Air Spark Technology
Discount Tire
MPH Motorsports
Air Flow Research
Patriot Performance
Total Engine Airflow
LG Motorsports
Wolfe Racecraft
Exotic Performance Plus
G-Force Motorsports
Southern Car Parts
Kee Audio
Late Model Engines
Nitro Dave's Nitrous Outlet
Cunningham Motorsports
LSx Tune
Slowhalk
West Coast Cylinder Head
Tick Performance
Nano Nitrous
Shock Warehouse
Madman Racing
Performance Oil Technology
TomZ Wheels
Speed South
EFI Alchemy
Cartek Racing
Full Throttle Speed
Race Proven Motorsports
Competition Clutch
LM Performance
World Products
CarsDirect
Nitrous Oxide Systems
Racetronix Fuel Systems
Mast Motorsports
Afterthoughts Auto
Masport Speedshop
Diablo Sport
TT Performance
Dyno Tune
Scoggin-Dickey Parts Center
Fast Toys
BMR Suspension
American Racing headers
Nitrous Express
Horse Power Engineering
Spohn Performance
Tropi-Care
Faster Proms
Strano Performance Parts
Quick Time Performance
APS Turbo
VFN Fiberglass
CompStar Components
SLP
School of Automotive Machinists
New Era Performance
Finish Line Performance
Speartech Fuel Injection Sys
Futral Motorsports
Speed Tweekerz
Straightline Performance
Xtreme Horsepower
Circle-D Converters
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
