Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
Trans Dipstick install - Lokar 36" 6l80e
Old 11-14-2010, 10:58 AM
norm8332's Avatar
Default Trans Dipstick install - Lokar 36" 6l80e
I finally got around to installing this. The extra length compared to the 24" allowed it to be routed neatly and cleanly, far from the headers. Greg@paceperformance.com supplied it at a great price and had it to me very fast.
To address a previous concern about it coming out of the tranny, I made a custom bracket (pictured) to hold it in. after routing of the tube I used an existing bolt to mount the top/handle. It took about an hour of actual work not including waiting for paint to dry on the bracket. I'm Happy with it.
It took a bit if persuasion to route the tube, but the nice thing is it can be routed like a hose and you just have to avoid sharp 90* bends. It is long enough to be mounted in several locations under the hood. I just mounted it in a way that would not have required custom bracket because I used an existing bolt. You could easily make one and with hardware store parts. I may still relocate it if need be. BTW, The tranny is already full and fluid looks good. Glad to finally have a dipstick.
Pictures below:
Attached Thumbnails Trans Dipstick install - Lokar 36" 6l80e-t1.jpg   Trans Dipstick install - Lokar 36" 6l80e-t2.jpg   Trans Dipstick install - Lokar 36" 6l80e-t3.jpg   Trans Dipstick install - Lokar 36" 6l80e-t4.jpg
Old 12-14-2010, 07:27 PM
jay_lt4's Avatar
what was the part number of the tube,, us camaro guys need a dipstick also!
Old 12-21-2010, 08:21 AM
norm8332's Avatar
Lokar TD-36L80FM36 for The 36" (the one I used), and TD-36L80FM24 for the shorter 24".
Old 12-22-2010, 05:14 AM
Compg's Avatar
What was involved in the install of this? Did you have to drill anything or is there already a point on the tranny that this install to?
Tate
Old 12-22-2010, 11:55 AM
norm8332's Avatar
There is a hole in the tranny where it goes that comes with a removable plug installed. The only fabrication was the black bracket to hold it in as shown in the second picture. It originally just stuck in the hole. Didn't seem tight enough, hence the bracket. You could probably just use some zip ties if you wanted to make it easier.
Old 03-30-2011, 07:14 PM
norm8332's Avatar
Added pic - Uninstalled in package. TD-36L80FM36 for The 36"
Old 05-07-2011, 08:59 AM
rlwjr1's Avatar
I like this and a nice install. May be a stupid question but how is filling the fluid through this tube, looks a little small in diameter for a funnel or quick drainage.
Old 05-29-2011, 10:56 AM
Bill Bowling's Avatar
I need to do this mod. I can not believe GM did not put a dipstick on this car.
Bill
Old 05-29-2011, 11:33 AM
It has a special fill tube for a funnel. At least that is what I read.
Bill
Old 06-27-2011, 10:58 PM
realsquash's Avatar
The rubber tube in the bottom of the package here is the funnel adapter. I originally bought the 24" version, they didn't have a 36" at the time. Don't buy a 24" one
Andy
Old 03-16-2014, 01:01 PM
I have a new 24" if anyone needs one for cheap.
Bill
Old 03-26-2014, 08:09 PM
14 Second Truck Club
RS/SS 4.8's Avatar
Is the dipstick accurate being that its a universal one?
The following users liked this post:
thereason (08-05-2020)
Old 04-11-2014, 10:50 AM
Yes it is made for our transmission.
Bill
Quick Reply: Trans Dipstick install - Lokar 36" 6l80e
