10-19-2008, 08:26 PM
#1 | | 12 Second Club
| 2004 gto 6 speed DYNO impressed. some guys on ls1gto seem to be in disbelief
so here ya go! Very happy 2004 gto dyno...
__________________ 04 Torrid Red on red M6
SLP ML's,SLP LMII,catless mids,Iat relocation,160* Thermostat,msd 8.5's,P&P TB,Noltec diff bushing,descreened maf,coolent bypass,JHP tube with k&n and ported air box,tune,GMMS+LSS,c5 pads,nitto dr's,splitter
12.941@107.85 1.947 60FT BEST 60FT 1.82
361.99-hp 381.11-tq |
10-19-2008, 08:57 PM
#2 | | Launching!
| exh...no cats...p&p tb...and intake.
wow! is that corrected or uncorrected.
either way impressive #'s
__________________ |
10-19-2008, 09:20 PM
#3 | | TECH Regular
| That seems to be the normal for our cars in the STL area. I dyno'd similiar with similiar mods.
__________________ www.myspace.com/summerwolfrunem Quote:
Originally Posted by ponygt65 Rollin' in G-T-O slouchin' like a master G homey in LAS VEGAS!!!...Woop Woop. | |
10-19-2008, 09:35 PM
#4 | | 12 Second Club
| Quote:
either way impressive #'s | here is what the owner said...
corrected using SAE correction factor. the info on the bottom of the dyno printout tells the conditions. some dyno shops use STD corretion factor which will show a little higher numbers than SAE, but SAE is probably used more often.
10-19-2008, 11:41 PM
#5 | | On The Tree
| that is high for an 04... with headers and intake i made about 360/361 on my 06.. But it was on a mustang dyno and i ran 12.30's at 112-113 |
10-20-2008, 02:26 AM
#6 | | TECH Regular
| Yeah.....but you can drive better than the average bear Vic. Now that I have 400+ with my car you could probably pull some fuckin 11's if I let you drive, lol.
10-20-2008, 10:52 AM
#7 | | On The Tree
| lol I think its the location... hows the car? |
10-21-2008, 12:54 AM
#8 | | TECH Regular
| Its pretty decent....the heads/cam and 6.9 RPM limit really woke it up.
10-24-2008, 12:20 AM
#9 | | 12 Second Club
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
