Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac GTO 2004-2006
Old 10-20-2008, 06:05 AM   #1
bigfatls6's Avatar
Trader Rating: 17
Default Looking into buying a M6 GTO (2006) what usually breaks first?
I am looking into buying a m6 2006 gto with the ls2. If I mod the car with say heads and cam what will break first? Are the rear ends week on the GTO like the fbodys? also what problems do I need to watch for when buying one? The one I am looking at has a little under 30k miles.
bigfatls6 is offline   Reply With Quote
Old 10-20-2008, 08:50 AM   #2
06black6spd's Avatar
Trader Rating: 0
Send a message via Yahoo to 06black6spd
I have a head cam GTO, first thing you want to do is replace the clutch and shifter and get a braided line for the clutch. I did not mod it last year and noticed it very hard to not heat the clutch up too fast. They dont handle modd's very nicely. I have done probably 40 passes on the car since the head/cam work and the drivetrain does handle it. I am not doing 5k launches with Mickeys yet but I am going to do a full built rear end from driveshaft back this winter. The sub axels and the driveshaft are probably the weekest link. If your not going to drag it hard core the rear end set-up is a overkill. You could just do stub axles and be fine for heavy street abuse. There are guys running serious power with stock everything too though.
__________________
06 GTO 457wrhp 421torque AFR 205's hellraiser comp cam, 1 7/8th kooks long tubes, catless mids, spintech catback, underdrive pully, MT's, Textrallia OZ700 clutch and GMM Rip Shifter, BMR Drag bags, BMR safty loop, Braided clutch line, Ling fuel pump, oil catch can, Lucus 42lb injectors...
On order: Fast 92 full port & TB
To come by spring, full race 8.8 with axles, stubs, shafts, and driveshaft.
Best e.t 12.35 @ 114.4mph with a 1.87 60,
06black6spd is offline   Reply With Quote
Old 10-20-2008, 01:27 PM   #3
It's not mine! woo hoo!
demonspeed's Avatar
Trader Rating: 0
Shocks/struts/springs/mounts all start sagging around 20k miles causing uneven tire wear.
I think everything else is pretty solid like the other GM LSx cars. The reply above is about right for the rear.
demonspeed is offline   Reply With Quote
Old 10-20-2008, 04:31 PM   #4
jmdgto's Avatar
Trader Rating: 0
everything
__________________
couple of mods
jmdgto is offline   Reply With Quote
Old 10-20-2008, 10:13 PM   #5
Trader Rating: 0
the bank/wallet
socal gto is offline   Reply With Quote
Old 10-21-2008, 11:48 AM   #6
ArklaTexan's Avatar
Trader Rating: 2
I had to upgrade my Driveshaft and Beef up my T-56 because of my TT
__________________
2004 Pontiac GTO
Coming Soon: Forged 408 and 19psi
ArklaTexan is offline   Reply With Quote
Old 10-21-2008, 12:37 PM   #7
LS2Greg's Avatar
Trader Rating: 0
Quote:
A lot happens when you're putting down 678rwhp! lol
__________________
LS2Greg is offline   Reply With Quote
Old 10-21-2008, 04:32 PM   #8
06BOMGTO's Avatar
Trader Rating: 0
Like everone else has said the stubs and axles, if you making good power with good traction. Clutch is somewhat week and the shifter gets sloppy when your on it hard.
Do some suspension mods to help you get the power to the ground.
__________________
'06 GTO M6. 12.97 @110 2.02 60' on KDW2s
'02 Silverado 2500HD 6.0
06BOMGTO is offline   Reply With Quote
Old 10-23-2008, 12:13 PM   #9
LSWONGTO's Avatar
Trader Rating: 0
Do full boltons and suspension mods first. Then Get a good clutch. Now you can do H/C/N20!!
__________________
M6 06 GTO with the RaceProvenMotorsports mod
LSWONGTO is offline   Reply With Quote
Old 10-23-2008, 12:43 PM   #10
KrautBurner's Avatar
Trader Rating: 4
Send a message via AIM to KrautBurner Send a message via MSN to KrautBurner Send a message via Yahoo to KrautBurner
funny,
my car must be super tough,
it's not been breaking much.....
my stock clutch lasted over 35000 miles,
over 300 passes down the 1320
a dozen or so auto-x events
(10k miles and 100 passes were with mickey thompson ETstreets and 100 shot of nitrous, cutting 1.6x 60' times with 500rwhp and 600rwtq)
only thing i replaced was the cv shafts and axle stubs (didn't break them, but one stub had twisted splines from my 1.55 60' launching)
of course with my LS7 clutch, I can't get my launch down
done at 36000 miles, because I wanted to (it wasn't dead yet)
had to do brakes at 45K miles tho
__________________
lincoln is on the $5 bill, washington is on the $1 bill now that obama is our next president we finally have somebody to put on food stamps.
"Racing is life. Anything before or after is just waiting." -Steve McQueen
2005 Pontiac GTO (LS2 M6) Phantom Black Metalic (new dyno numbers coming soon)
Cam: 226/226 591/591 112lsa, Kooks Long Tubes with Cats, Borla Cat Back, Nitrous Outlet LS2 Plate system
KrautBurner is offline   Reply With Quote
Old 10-25-2008, 12:11 PM   #11
Phantom_LS2's Avatar
Trader Rating: 1
Well, I would have to say clutch. For the simple reason that mine is now slipping on me at the track. Also, the suspenion on these cars tends to wear out rather quickly.
__________________
Phantom_LS2 is offline   Reply With Quote
Old 10-25-2008, 12:31 PM   #12
Trader Rating: 0
I went through 3 rears and 3 times I broke the 3rd gear Syncro....I even broke the actually shifter handle LOL....My mods...K&N drop in filter...Granted I was powershifting 2 out of the 3 times 3rd went...The rear would start to wine on me every 6-7K miles...I only made 2 passes on my MT's DR's and sold them so the car didn't see sub 2.0 60' often at all.....Othet than that...the motor did wonders to be honest....a joy to drive in sub 70F air....
__________________
GONE BUT NOT FORGOTTEN!!
2005 Quicksilver M6 w/stock 18's with 245/40/18's-ATCO
Bone stock on street tires-12.974 @108.80,2.027 60'
best 60'-2.022
K&N drop in filter/MT DR's(stock 17" wheels)
Best ET-12.961
Best 60'-1.957
Best MPH-109.58
jumbojet is offline   Reply With Quote
Old 11-10-2008, 10:52 AM   #13
Trader Rating: 1
Quote:
Your "will" to hold back on Mod's looking for more rwhp!!!
ejb04yj is offline   Reply With Quote
Old 11-10-2008, 11:43 AM   #14
Trader Rating: 0
Send a message via AIM to chadaclysm
Quote:
How much does it cost to replace all that? Nothing performance special, just for a DD car.
__________________
LOOKING TO BUY: LS1 - prefer Trans Am or Formula, but will consider an SS or Z/28. MUST BE 6-speed and ttop - pm me! Now considering all 6-speed LS1 GTO's also.
-1970 Ford Torino Cobra "N" code 429 - 4 speed - driveable project car
"My car has so much power that when I'm going 55, I can pass someone who is going 65." (a completely serious quote from a tard I know about his 2 door '89 accord)
chadaclysm is online now   Reply With Quote
Old 11-10-2008, 11:45 PM   #15
demonspeed's Avatar
Trader Rating: 0
Quote:
www.rocksandracingllc.com
Old 11-10-2008, 11:55 PM   #16
Trader Rating: 0
Ouch! Thanks for the bad news.
__________________
Old 11-11-2008, 12:49 PM   #17
Trader Rating: 1
I have an '05 and the first thing that usually breaks is your bank account. Parts for the GTO's are not cheap.
Seriously though..........clutch, rear diff, axle stubs, cv joints.
__________________
2005 GTO
KWIK SS is offline   Reply With Quote
Old 11-12-2008, 11:34 PM   #18
Trader Rating: 0
haha, first true broken part on mine after 25k miles was the #7 piston ringland :-(
but it brings upon fun things.... creditors, bills, long hours at work, 800rwhp
Atomicwedgy is offline   Reply With Quote
Old 11-13-2008, 01:23 AM   #19
Trader Rating: 3
dont listen to anyone else .......................I KNOW BETTER THAN ANYONE WHAT BREAKS FIRST,.........................no one else will be honest but my personal experiance with my own car and running a club i can tell you first hand the first thing you will break is your PIGGY BANK TO MOD....LOLOLOLLOLOLOLOL
__________________
official member of the 600+RWHP club...with a magnacharger,on my 4480lb goat...
tha joker is offline   Reply With Quote
Old 11-13-2008, 04:27 AM   #20
Trader Rating: 4
Quote:
this is true
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Performance Oil Technology
Patriot Performance
VFN Fiberglass
Redline Motorsports
Nitrous Express
APS Turbo
Speed South
Slowhalk
Southern Car Parts
Fuel Air Spark Technology
Century Transmission
American Racing headers
TT Performance
LSx Tune
Futral Motorsports
G-Force Motorsports
Afterthoughts Auto
Lonnies Performance
Shock Warehouse
Nano Nitrous
Racetronix Fuel Systems
Cunningham Motorsports
Edelbrock
Masport Speedshop
Forced Inductions
World Products
SJM Manufacturing
Discount Tire
Madman Racing
Painless Performance
MPH Motorsports
Fast Toys
LM Performance
Strano Performance Parts
Dyno Tune
New Era Performance
CarsDirect
Maryland Speed
Harris Speedworks
Speed Inc.
HP Tuners
Kooks Custom Headers
Pavlock Performance
Speed Engineering
Horse Power Engineering
Livernois Motorsports
Finish Line Performance
Burkhart Chassis
Rapid Motorsports
Air Flow Research
Race Engine Development
Competition Clutch
Exotic Performance Plus
West Coast Cylinder Head
LG Motorsports
Diablo Sport
Canadian Performance
Katech Engine Development
Total Engine Airflow
Tropi-Care
ByunSpeed
Comp Cams
Six Speeds Inc.
CompStar Components
Scoggin-Dickey Parts Center
Trifecta Performance
Late Model Racecraft
Cartek Racing
PerformaBuilt Transmissions
Auto Parts Firm Online
Xtreme Horsepower
Nasty Performance
Kee Audio
Specialized Stainless
Late Model Engines
School of Automotive Machinists
Xtreme Powersports
Finish Line Transmissions
BMR Suspension
TomZ Wheels
Spohn Performance
Nitro Dave's Nitrous Outlet
Speed Tweekerz
Circle-D Converters
Speartech Fuel Injection Sys
Vengeance Racing
Faster Proms
SLP
Race Proven Motorsports
Midwest Chassis
UMI Performance
Performance Auto Fabrication
EFI Alchemy
Tick Performance
Nitrous Oxide Systems
Straightline Performance
Full Throttle Speed
Texas Speed & Performance
Wolfe Racecraft
Advanced Induction
Quick Time Performance
Redline Goods
Mast Motorsports
Car Shop Inc
Yank Torque Converters
WS6 Store
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
