Quote:
Originally Posted by crewpig what's up guys i have and o6 goat, and i just go some pacesetter lt headers. I was just wondering if anyone has any tips or tricks to making this an easy install? |
Quick tips that may make this easier for you.
1. Soak all bolts with PB Blaster the night prior to removal
2. Pick up an extra 02 sensor in case one of the OEM sensor's is cross threaded.
3. Use OEM gaskets for best results.
4. Secure the steering wheel (ignition lock or bungee cord).
5. Mark steering rack alignment with an awl/screwdriver - it will help with proper alignment when you bolt it back into place.
6. If your headers are coated, wrap them in plastic wrap (available at Lowes). This will help keep the coating from getting nicked up during install.
7. A crowsfoot wrench (16MM & 19MM) are handy for the PS lines
Research first, take your time, and enjoy!
