Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac GTO 2004-2006
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-09-2008, 03:41 AM   #1
Jeff@TotalPerformanceEng's Avatar
Trader Rating: 6
Send a message via AIM to Jeff@TotalPerformanceEng
Default Official TPE/Kenne Bell Twin Screw Blower Thread!!!
UPDATE 10/20/08 PICTURES BELOW!!!!!!!!!!
After years of "Thinking" about it, we have finally decided to pull the trigger on the project.
Effective immediatly, we will beging the development and install of our Total Performance Engineering Twin Screw Blower kit for the 2004-2006 GTO, as well as the new G8..
You wil be happy to know, we are already approximately 80% complete with the project itself. The blower, lower manifold, heat exchanger, cooling system, coolant tank, and all electronics are already finished and in production.
Our inlet manifolds are scheduled to come in next week. The inlet manifold is designed to accomodate anywhere from a 75mm throttle body, all the way to 110mm's. So restriction will be a thing of the past...
Althouh, we are not at liberty to release all information, I will tell you that it will be an intercooled system, that utilizes an oversized water to air heat exchanger, as well as a high flow 4" cold air intake tube, and sealed cold air intake box in the factory location.
It will still utilize a strut tower brace, and not require body modifications. It will also be a COMPLETE bolt on application that can be done at home with standard hand tools.
We will be offering the system in 3 different finishes. It will be available in black annodized, full polished, and black/polished.
Like any high end system, it will be offered in 2 different blower sizes. The base system is a 2.6L high output blower capable to over 750rwhp/750rwtq. The "Big Bore" 2.8H system is designed for 400+ cid motors, that are trying to push 1000+rwhp..
Our target, is a 525-550rwhp/500+rwtq out of the box system on a bone stock car. With a cam swap and headers, were seeing 600rwhp, 550rwtq.
The BEST part of all is price.. Although this is NOT set in stone, we are attempting to keep the complete system in the $6,000 dollar range COMPLETE.
Unlike the 3000+ dollar upgrade on the maggie, the upgrade from the 2.6 to 2.8H will be right around 500 bucks..
We begin installation this week, so we will update as we go on..
Please try to keep the PM's to a minimum. I'd love for this to be an open discussion. So, if you have suggestions, this is your chance to have a DIRECT influence on the design and implementation of the kit.
Lastly, Although we are the worldwide distributor of the Kenne Bell Supercharger systems, Kenne Bell has decided they do not have any intrest in the "Other" GM lines.
Total performance Engineering has no intrest messing around with their mustang kits. We have reached an agreement to build the tuner systems for the other GM vehicles.
So although this WILL utilize a Kenne Bell headunit, this is a Total Performance Engineering Twin Screw Blower System. NOT a Kenne Bell system. These systems will be not be available through Kenne bell. They will be available through our company, as well as the MANY TPE authorized dealers around the country. We are currently in talks with all of your favorite shops on LS1tech.
So be looking out for some 9 seceond TPE twin screw cars hitting the streets soon.
Once released, TPE will be investing in a contingency program for you hard core guys. So once this kit hits the market in the next few months, we want the biggest, baddest gto's in the country racing our product.
We look forward to build the hardest hitting, fastest GTO's in the world..
Kind Regards,
Jeff
Owner
702-568-8321
Jeff@TotalPerformanceEngineering.com
BTW, Here is an example of a 2.8H on a 9.5:1, LS2 402 at 16psi, on pump gas and single stage methanol. C5 Corvette (6spd)
Jeff@TotalPerformanceEng is offline   Reply With Quote
Old 10-09-2008, 10:17 AM   #2
Steel Chicken's Avatar
Trader Rating: 2
"Jesus Christ" /Mr Slave
hmmmmm upgrade from a mp122 to a 2.8H KB? mmmmm hmmmmmm!
As far as suggestions, hood clearance issue is an issue. Magnuson has a tendency to "exaggerate" how easily their setup fits. I had lower my engine 1/2" to get the mp122 to fit...even with a banshee "maggie friendly" hood. I assume there will be no jackshaft going to the back of the blower? that will help as well for firewall clearance.
How will the 2.8H work on a heavily modded stock cube LS1?
Throttle body clearance is also a big deal...what are your thoughts/info on this subject?
Obviously the LS1 and LS2's come with different TB's, I assume the kits will have the ability to mount both TB's?
__________________
2004 GTO : 655/598 HP/TRQ - Maggie 122 @10PSI, ETP 225 heads, SW LT's, electric cut-outs, magnaflow catback, 224/236/116 EDCam, RPS clutch, Meziere. NW 90mm TB. Pedders Track II/Konis & Hotchkis. GMM Ripshift. Banshee hood. Corn juice fed and 2 bar Self-tuned. Chock full of evil.
Steel Chicken is offline   Reply With Quote
Old 10-09-2008, 01:32 PM   #3
Trader Rating: 2
Send a message via AIM to 01SOMm6
Ill upgrade from the Maggie to the 2.8H in a heartbeat. Just curious how it would act on a 402 with 10.8:1 compression
__________________
2001 SOM WS6 M6 349rwhp/364rwtq(sold)
2001 SOM Z28 A4 570rwhp/590rwtq(sold)
2004 PBM GTO M6 Magnacharged 403 with nitrous 674rwhp/694rwtq
Something New in The Works
01SOMm6 is offline   Reply With Quote
Old 10-09-2008, 01:32 PM   #4
Trader Rating: 6
Forunately, we designed our 2.8H to be roughly 1/4" shorter that the MP112 (1.8L). So (according to out measurements) it should work just right. But we'll see.
One of the reasons the maggie cant go larger than an MP122 (2.0L) is the size of the headunit has to get MUCH larger. On our twin screw, we just move the discharge port, and add a little bit of length. We can then shorten the drive to keep everything in check.
Old 10-09-2008, 01:37 PM   #5
Trader Rating: 6
The 2.8H is not within its efficiency reange unless its spinning enough to make 13-15psi) If you were set on 10.8:1, I would go with the 2.6. You could then throw moderate boost at it and make upper 700's all day long. (without needing nitrous)
But I have to admit, we've never ran a high compression twin screw..So I'd startthe boost low and work up. The 2.6 hits so hard, youd be within 20rwtq of max torque from 1800rpms to 5200+ rpms.. Its no different than spraying a single 500 shot out of the hole..
Old 10-09-2008, 04:56 PM   #6
Fatbum's Avatar
Trader Rating: 1
OMG!!!!
Jeff...I love you...
Maggies didn't make enough power for me..Turbos are great..but a Twin Screw for 6k...!!!
Now I need to forge my motor before this thing comes out!
SO excited!
__________________
http://i9.photobucket.com/albums/a54/fatbum41/GTO/siggy-1.jpg
2005 Pontiac GTO Mods: Complete Cam Package by Ed@FTI, Full Pedders Suspension w/Coilovers,Wilwood BBK, SLP UDP, Vigilante 3200 Stall, B&M 24k Trans Cooler, 1 3/4 Pacesetter Headers w/Catless mids, Lingenfelter CAI, Ported TB, FAST 92, IAT Relocate, NGK AFX wideband, JP Double Roller, Drift Rs 19 x 8 w/235/35/19s and 19 x 10 w/265/30/19, BMR Drag Bags,
Fatbum is offline   Reply With Quote
Old 10-09-2008, 05:36 PM   #7
Fatbum's Avatar
Trader Rating: 1
Some quick questions.
On the stock 364ci LS2. You recommend the 2.6L for the 10.8:1 correct? Will the stock engine be able to handle that? With supporting fuel mods? Will you have a Fuel Package available as well?
__________________
Old 10-09-2008, 06:06 PM   #8
Trader Rating: 2
very nice !! i like the idea of a shorter nose , it adds in the strength of the snout to keep flexing down , and easier on the bearings
__________________
04 5.7 auto 1 of 273 12.300 @ 110.953 1.74 60ft , 11.49 @ 120 on da bottle , formerly BMR's gto
http://i161.photobucket.com/albums/t...LS1techsig.jpg
s/c'd cav is offline   Reply With Quote
Old 10-09-2008, 06:24 PM   #9
Going diesel!
thunder550's Avatar
Trader Rating: 62
Send a message via AIM to thunder550
Holy bajeezus! Will this kit be coming with the 8 rib Innovators West pulley setup pictured above?
__________________
2001 Silverado ECSB
2006 GTO M6 Brazen Orange
2006 Silverado CCSB Duramax
thunder550 is offline   Reply With Quote
Old 10-09-2008, 06:25 PM   #10
Trader Rating: 0
When its done I'll be selling my 122 maggie and putting this on my forged 402. Thanks for doing this guys
__________________
05 GTO M6 Black/black
forged 402 with F1A procharger and E85
GTO Fan is offline   Reply With Quote
Old 10-09-2008, 06:28 PM   #11
1INSANEGTO's Avatar
Trader Rating: 4
Send a message via AIM to 1INSANEGTO Send a message via Yahoo to 1INSANEGTO
Looks like the wife will be getting a KB for xmas not a maggie 122 However I think there is going to be alot of 122's forsale for cheap
__________________
2004 GTO 408ci F-1R Procharger underway.
2004 GTO 408ci and a lil shot-Wifes Car
2007 Harley 1200 Sportster
1967 Camaro TT5. Budget Turbo build comming.
2004 Mazda 6s Beater
1INSANEGTO is offline   Reply With Quote
Old 10-09-2008, 06:41 PM   #12
Fatbum's Avatar
Trader Rating: 1
Quote:
Haha you can count on that!
Theres going to be SOOOO many S/Cd Goats running around it will be NUTS!!!
__________________
Old 10-09-2008, 06:46 PM   #13
Trader Rating: 0
tw1nny03 is offline   Reply With Quote
Old 10-09-2008, 06:51 PM   #14
Trader Rating: 0
Send a message via MSN to 1STV8 Send a message via Yahoo to 1STV8
oh my GOSH!!!
i think you just made up my mind about which FI I want to go with!
and for around 6K...WOW!!! hopefully i can save this up quick while I'm away in the service!!!
1STV8 is offline   Reply With Quote
Old 10-09-2008, 07:26 PM   #15
luisvelasco02's Avatar
Trader Rating: 0
I'll be watching this closely.
__________________
2004 GTO 408 D-1SC Monster
754rwhp
642rwtq
All work done by Gil Nevarez @ NRP Nevarez Racing Products in Las Vegas
http://nevarezracing.com/
luisvelasco02 is offline   Reply With Quote
Old 10-09-2008, 10:31 PM   #16
chance575's Avatar
Trader Rating: 0
i too will be watching closely
__________________
2005 gto, sts 67mm, performabuilt lev 3 w/ 3000 hd billet stall, meth, victor jr and some bling bling crap
chance575 is offline   Reply With Quote
Old 10-09-2008, 11:00 PM   #17
04BlackGmc's Avatar
Trader Rating: 5
so nice
__________________
2004 red m6 gto..bolt on's and cammed..
RIP
http://img.photobucket.com/albums/v5...073_o-Copy.jpg
09 white hot G8GT premium/sport onyx/red
1/4 12.997 @ 106.48 1.9860ft best trap 107.5
tuned by ME,roto-fab,HSRK,LPM mod,ICR mod,Hood vent mod,160*,reso&mid muff deleteW/Xpipe,GXP mufflers.344.7hp 361tq
09 honda fit tinted
04BlackGmc is offline   Reply With Quote
Old 10-09-2008, 11:02 PM   #18
sergo's Avatar
Trader Rating: 0
highly interested...
__________________
05 GTO YJ M6 with engine removal mod
sergo is offline   Reply With Quote
Old 10-10-2008, 12:03 AM   #19
LS2tiger's Avatar
Trader Rating: 0
In on one.
__________________
Vengeance built 454 LSXtreme
LS2tiger is offline   Reply With Quote
Old 10-10-2008, 01:12 AM   #20
goatnstang's Avatar
Trader Rating: 0
hot damn
__________________
05' PBM-Pacesetter LT Headers-L92 Heads-L76 Intake-Comp Cam (222/234 .566/.576 112LSA)/ NICD Tuned
414rwhp/391 rwt
goatnstang is offline   Reply With Quote
Tags
21, 240sx, bell, boost, corvette, engineering, hole, hood, kenne, performance, rating, sale, supercharger, total, tpe, turbo, vegas
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
