Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > WEBSITE ACTIVITY FORUMS > Racer's Lounge
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-28-2009, 09:26 AM   #21
turbowhistle86's Avatar
Trader Rating: 5
swap in the LC2 turbo 3.8 from the Grand Nationals.....my little V6 threw down over 650 ft lbs and runs 28 PSI all day long. If it can drag a 3600# Buick to an 11.30 on street tires, just imagine what it would do in a lightened F-body.
__________________
02 Z28, 86 T Type WH1, 04 Grand Cherokee 4.7 Ltd
turbowhistle86 is offline   Reply With Quote
Old 03-28-2009, 12:46 PM   #22
WarShrike's Avatar
Trader Rating: 2
Quote:
Originally Posted by AronZ28 View Post
Only way I'd go forced induction on a V6 is if I got a car with a blown motor for dirt cheap. Put a forged bottom end on it and crank up the boost.
Just curious, but how much of a difference is there in the 3.8 V6 in the fbody vs the 3.8 turbo V6 in a Grand National?
Forged bottom end isn't necessary. The stock cranks on the 3800 Series II is known to handle serious power, including cars that have run single digits with big forced induction builds. The stock 3.8 can handle quite a bit of boost, but you're playing with fire. You have to keep an eye on your fueling, and make sure that anything over 5psi is intercooled and even running meth injection or race gas. First sign of detonation on stock pistons will net you a blown motor, and the magically disappearing piston.
The GN 3.8 is way different, older technology, and the newer 3.8 L36 (NA) and L67 (Supercharged) have a few refined points, but there's still some things left for want. There are many things within the architecture between the two motors to prevent any useful hybrids of the two.
__________________
2000 Firebird A4
●Whisper Lid●60*Inc. Heads & Intake●Intense S1X Cam●YT 1.7 RR's●FFF LT's●TCI 3800 stall●TSP Rumbler●
WarShrike is online now   Reply With Quote
Old 03-28-2009, 01:08 PM   #23
WarShrike's Avatar
Trader Rating: 2
Visit www.fullthrottlev6.com if you haven't already. Some of the information the guys here will give you is good, some of it is useless prattle and does not pertain to the 3800 Series II. What works on an LSx motor doesn't always work on another platform, or isn't needed (like a forged bottom end).
Otherwise, here's what I recommend.
Quote:
Originally Posted by Pontiac-Prodigy View Post
so the question is can a V6 have a super charger or turbo?
i have a 1999 Pontiac Firebird and comments or suggestions would be greatly appreciated! thanks
Yes, you can have a supercharged or turbo'd V6 Camaro. It has been done, and a few guys have done so with serious results. Considering how little aftermarket support the V6 F-body has, it is pretty impressive.
Once you start going with a boosted motor, you need to figure out what your initial goals are and what you're capable of doing. Make a budget for the parts, labor etc. and then double it. Cause when you start making power, the weak links are going to start showing up and breaking.
You'll need a few basic things on the V6:
Electronics/diagnostics:
HPTuners VCM suite + Wideband (Best way to get the whole setup dialed in)
Other gauge gee-gaws if you want to be showy about it
Fueling:
High volume Fuel Pump
Larger injectors (L67 aka GTP injectors are a start)
Might need a 1:1 Fuel Pressure Regulator, depending...
Motor:
If you're going with just stock motor, nothing over 5psi, then no need
You'll need to re-route the PCV and install a valve cover breather with a catch can. You'll blow out your dipstick if you don't take care of it.
Above 5psi safely:
Forged Pistons & Rings (Stronger pistons hold up to the stress of FI, rings can help cut down on blow by)
Hardcore motor:
P&P'd heads, intake
High effort Camshaft spec'd out for your desired goals
Higher tension valvesprings
Stainless oversized valves
titanium retainers
You can get away with the OEM Lifters, just get some replacements from SDPC.
Forced Induction side:
For a turbo, you'll need to do a few things.
Intercooler (especially over 5psi) Air to Air is simplest, Water to Air is where it's at, but more complicated in some aspects.
Meth injection (only when over 5psi)
Hot side turbo manifolds fabbed
Cold side routing
Oiling routed for turbo(s)
Supercharger:
Check some V6 boards for sponsors, there's one I know that is working on a bracket for a P1SC, otherwise find a kit.
Oiling routed for Supercharger if needed. Some are internal.
You can use the supercharger from a GTP car. But it is very involved and gains aren't really great. It's a nightmare as you have to do some serious fabbing and wiring to get everything to fit properly in an F-body.
Transmission:
If you are a manual transmission car, say goodbye as the M5 trans in our cars aren't up to snuff for boost, there's a few gears that just can't handle it even in a built trans.
Auto:
Stall (spec one out for your cam, gearing and something tight that will handle the boost and not flash up beyond what it is rated for)
Trans Cooler
Get it built, personally. Performabuilt is a sponsor here and on a V6 board and their transmissions have held up pretty well.
__________________
2000 Firebird A4
Old 03-28-2009, 02:35 PM   #24
supernova1972's Avatar
Trader Rating: 0
Quote:
Originally Posted by Luvthis View Post
a few years back i saw a guy at the stip with a charged 6cyl camero going 12s. But i also remember him saying he had a e engine couple $$$$ in the engine also
You arn't allowed to do that.
__________________
1996 Caprice Classic - LE2 355 in the works
1972 Chevy C10 Short Bed-LSx swap project
I Bleed Blue and White
supernova1972 is offline   Reply With Quote
Old 03-28-2009, 02:40 PM   #25
Trader Rating: 1
Send a message via Yahoo to Sarge_13
Quote:
__________________
2007 CBR1000RR
Quote:
Originally Posted by ae13291 View Post
you sir are a fucking moran!!
Sarge_13 is online now   Reply With Quote
Old 03-28-2009, 03:12 PM   #26
1gt2nv's Avatar
Trader Rating: 2
ZZP has a very nice turbo set up for the 3800 v6. They built my turbo gp. A cam+ turbo on a 3800= pure sex. They sound bad ass with a open dp. Email them and they'll help you out with all your turbo needs! Go on club gp. Lots of v6 turbo info there.
__________________
1999 A4 Z/28= SLP Lid/ported tb/free mods/pacesetter headers&ory/msd,ngk/LM1 catback/tune by frost.
1999 Grand Prix GT= Intercooled, T-70 turbo, meth inj..SOLD
2004 GTP Comp G= DD/ Bolt ons, 3.5 pulley.
1gt2nv is online now   Reply With Quote
Old 03-28-2009, 03:18 PM   #27
WarShrike's Avatar
Trader Rating: 2
They've got a kit for the W-body, but not the F-body
__________________
2000 Firebird A4
Old 03-28-2009, 06:10 PM   #28
1gt2nv's Avatar
Trader Rating: 2
Yes they do. If you email them they'll hook you up!! There are a few on club gp who had zzp build them for there 3800 maro. There was a company from Can, but I think they shut the doors. Could never get ahold of them.
__________________
Old 03-28-2009, 07:49 PM   #29
gnictry's Avatar
Trader Rating: 2
http://videos.streetfire.net/video/8...uns_135494.htm
http://videos.streetfire.net/video/P...a-V6_19446.htm
http://videos.streetfire.net/video/T...g-V6_39825.htm
http://videos.streetfire.net/video/1...-For_41233.htm
http://videos.streetfire.net/video/F...r-V6_19710.htm
__________________
Ls6 intake, slp lid/maf, pp tb,OBX lt, hooker catback, egr/air !, built trans, 3200 fuddle stall, 3.73 richmond gears, cooler, 228 txsp cam with double springs and hardened push rods, strut bar, sfc,street tires/mt et streets on 16s, auburn and some cosmetic stuff…more coming soon!
gnictry is offline   Reply With Quote
Old 03-28-2009, 08:12 PM   #30
kidcamaro98's Avatar
Trader Rating: 7
Quote:
Originally Posted by plaf713 View Post
my friend had a 98 v6 camaro with a turbo on it, put down around 350rwhp i believe, i think his user name is kidcamaro98 on here if you want to pm him
awww man thanks....I didnt know we were friends! lol jk
anyways, OP...It can be done. Dont listen to these guys telling you to sell your V6 and get a V8. I was in the same exact boat as you. I bought my v6 from a dealership when I was 17 because insurance I simply couldnt afford a V8 since I was paying for the car and insurance on my own. I kept it around for a while and started modding it...then modding fever really hit me and I ended up making 3-4 different designed turbo kits myself with home tools in my driveway while the car sat on jacks until I was happy with my kit. I had a turbonetics T72 on it, pushing 15psi daily on a BONE STOCK motor...upgraded fuel system obviously but the car was boosted for nearly 2 years without a single problem..then finally less then a year ago the turbo itself shit the bed so I parted the car out and have my SS now....I am 22 now and can afford the insurance but honestly, insurance really wasnt that big of a difference...20$ more a month..
anyways, I have lots of pics, videos and details on it. Check out www.fullthrottlev6.com in the F/I section...also, heres my Fquick...
www.fquick.com/kidcamaro98
and heres some pics...
Quick video of my car...
Turbo+Camaro+vs.+Grand+National+vs.+SRT+Jeep
__________________
01 Arctic White Camaro M6 SS # 10997 412rwhp, 381rwtq
MS3 cam,Bolt Ons, 4.10's, Lowered/full spohn suspension, Ruff racing 280's etc....
http://www.youtube.com/watch?v=uOaax_AhUnc
kidcamaro98 is offline   Reply With Quote
Old 03-28-2009, 08:23 PM   #31
SlvrV6Camaro's Avatar
Trader Rating: 1
Send a message via AIM to SlvrV6Camaro
Please do not buy a powerdyne...huge waste....your better off building your own turbo setup. The 3.8l has quite a bit of potential in the motor...they can make some serious power but will take some cash....as stated above check out www.fullthrottlev6.com
There are quite a few pretty dam quick 3.8s out there...this is a V8 site so you wont get much help here other then people telling you to sell it.
__________________
2002 Sunset Orange Firebird
SlvrV6Camaro is offline   Reply With Quote
Old 03-28-2009, 09:49 PM   #32
WarShrike's Avatar
Trader Rating: 2
Quote:
Really? Are you talking about Stattama? ZZP never did seem to advertise that they offered F-body kits, but you can have special projects done for the right price...
Force Fed Fabrications offers turbocharging solutions for the F-body and their doors aren't closed. I think they're a sponsor here, not for sure. They're also Texas based, so that'll be better for the OP as he's in El Paso.
Seriously, go to www.fullthrottlev6.com, some of the other boards cater mostly to the W-body and other FWD platforms.
__________________
2000 Firebird A4
Old 03-29-2009, 01:30 PM   #33
1gt2nv's Avatar
Trader Rating: 2
^Stattama and ZZP are in the same building now! They work great together.
Your right, money talks! lol
__________________
Old 03-29-2009, 06:52 PM   #34
Moderator
davered00ss's Avatar
Trader Rating: 4
There are some sick v6's out there with turbo kits. Many that would kick my A$$.
__________________
davered00ss is offline   Reply With Quote
Tags
1999, 2008, 38, camaro, charger, fabricate, facing, firebird, forward, headers, impala, kit, sc, turbo, v6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
